Modding the supercrewsound box
Discussion in 'Audio & Video' started by chaos316, Oct 26, 2011.
  1. Oct 26, 2011 at 8:17 PM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    285/75/16 BFG KO2 Ditch Lights
    I don't want to cut any brackets, so I was wondering if it would be a good idea to mod the box from supercrewsound.com. Maybe drill a 2-3" hole or use a jigsaw to make it fit, then patch it back up on the inside using a few pieces of mdf.
  2. Oct 26, 2011 at 8:22 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Hole saw
    Find appropriate size plastic cup
    Seal over hole by any means possible.
  3. Oct 26, 2011 at 9:24 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    You don't think it wouldn't hurt the way the sub sounds?
  4. Oct 27, 2011 at 4:22 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    No, it wont mess with the sound. make sure your sub will fit with the modifications.
    I would probably do the hole saw, then cover with a square piece of 1/2" MDF if it will fit.
  5. Oct 27, 2011 at 5:40 AM
    ItalynStylion
    Steven
    DFW, Tx.
    How much space is needed for the protrusion into the box? Meaning, how far in is that metal piece needing to go?
  6. Oct 27, 2011 at 6:17 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    What do you think you have to cut to mount it anyways? I have the a SCS box in my 09 and did not need to cut anything.
  7. Oct 27, 2011 at 7:05 AM
    mattg43
    Texas
    08 Prerunner SR5 DC
    I figured he was talking about the little bump out where the plastic bins attach, about 3/4 of an inch...
    OP, got a pic?
  8. Oct 27, 2011 at 7:21 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    That's probably it, but those don't need to be removed unless you have some excursion interference problems and/or removing/trimming the seatback plastic is not an option.
  9. Oct 27, 2011 at 6:36 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    I'm talking about the several separate brackets that come up about 3/4" that bolt the storage plastic pieces up to the cab
  10. Oct 27, 2011 at 10:30 PM
    ItalynStylion
    Steven
    DFW, Tx.
    ABOUT 3/4" or is it exactly 3/4"? Measure it.....really, go do it now.
    If it's 3/4" then just use a hole saw or a jig saw to punch out an area that's that size (assuming the thickness of the box is 3/4"). Then do as Matt said and just glue a small piece of wood over it. If it's bigger than 3/4" then you'll need a bubble or something more creative.
  11. Oct 28, 2011 at 6:19 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Good advice if you want to fix it for real, but the box fits nicely without removing those brackets. Might want to try the fit first and check for box and sub clearance before you start cutting on the box itself.
  12. Oct 28, 2011 at 11:58 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    I haven't even ordered the box yet. Just seeing if it would be a good idea. Il go ahead and order it
  13. Nov 2, 2011 at 9:10 PM
    bigswoleone
    bigswoleone Well-Known Member
    Craig
    Birmingham, AL
    11 DC PreRunner TRD Sport
    Alpine CDA-117 HU DLS Ultimate UP6i 6.5" comps Polk 6.5" coaxial rear-fill Polk MM series 10" sub Kicker ZX700.5 amp
    I ordered the supercrewsound single 10" box and am using a Polk MM1040. The mounting depth of the sub is only 4.5" and it doesn't quite fit due to the indention in the back of the box that is cut out for the raised piece of sheet metal that runs across the back wall of the truck.
    Anybody know what I can do to make it fit.
    So far, I think my options are:
    1) take a dremel tool and shave some of the wood off the back of the box (from the inside of the box). probably would need to shave a piece of a couple of inches wide and about 1/4" deep.
    2) use some sort of spacer of the outside of the box to make the sub sit a little further away from the box itself. If I do this what would be the best material to use. Once again I need about 3/16" to 1/4" clearance.
    Thanks.
