Moderate Lift on a Moderate Budget
Discussion in '1st Gen. Tacomas (1995-2004)' started by Michael05, Mar 21, 2023.
  1. Mar 21, 2023 at 5:28 PM
    Michael05
    Michael05 [OP] Not-Known Member
    2003 Prerunner
    Driver Skill Mod
    I plan on lifting my prerunner this summer. Is this ambitious considering I only have $300 to my name as of now? Yes. Do I care? No haha.
    The plan is simple, do things right the first time so I don't have to redo in 3 years. I do not plan on spending 4k on suspension for a truck that is worth 10k like 40 year olds in a midlife crisis with too much money for Fox suspension. I also do not plan on spending 200 bucks for spacers like some trashbag teen in a squatted silverado.
    The writeup for the Parts:
    Not unreasonable by any means, just trying to make the most of my hard earned money. Totals out to around $1300. May be more if I need a shop to assemble shocks, but I don't know yet. By the way, this is roughly a 3 inch lift. Feel free to mention anything I forgot because I am a 17 y/o who is pretending to know what I am doing.
    Student of Mountains likes this.
  2. Mar 21, 2023 at 5:41 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    What front coils are you planning? You've got upper control arms twice. Are you planning on putting in an add a leaf for the back?
    Understand you might get 3" more distance from the ground to your frame rail, but springs settle and it'll lessen over time. Bigger tires are the only thing that actual lift the vehicle
  3. Mar 21, 2023 at 5:43 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Thank you, I linked the wrong thing. Yes I know springs settle. I have a rake, so I took into account the rear not rising as much to level the truck out. I do plan on bigger tires too, this is just for me to keep track of the suspension components.
    Abeyancer[QUOTED] likes this.
  4. Mar 21, 2023 at 5:50 PM
    Abeyancer
    Jimmie
    PNW
    I'd also think of maintenance items. Do whiteline bushings in the lower control arm, and new lower ball joints if they haven't been done recently/regularly.
    Michael05[OP] likes this.
  5. Mar 21, 2023 at 5:52 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Is that something I can do on my own or do I need a shop to do it. Preferably on my own so I can learn to do it and replicate again in the future(aka low budget don’t wanna pay shop).
  6. Mar 21, 2023 at 6:03 PM
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    That all depends. I'd say generally all the suspension work on these trucks is very doable for the average DIY'er. But keep in mind certain jobs will require a bit more than the average set of sockets and wrenches, so buying tools can quickly increase your total budget (unless you've already got access to a wide array of tools).
  7. Mar 21, 2023 at 6:09 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Fortunately since I am still in highschool I can leech off of some of my dads tools (extensive amount because he’s an engineer). But I still have my own set and will look into more tools as I go through the process.
  8. Mar 21, 2023 at 6:21 PM
    Abeyancer
    Jimmie
    PNW
    There are some thorough youtube videos for doing these things on our exact trucks. I suggest watching a bunch of em and seeing if it's something you feel confident as DIY.
    The other thing I thought of is new top hats and paying a shop to assemble the coil over... watch failed spring compressor videos on YouTube and you'll understand why I say that.
    EDIT This is what I mean by tophat
    Michael05[QUOTED][OP] likes this.
  9. Mar 21, 2023 at 6:23 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Thank you so much. The link you sent has an option for extended studs. I don’t need that unless I were to put a spacer up there right?
  10. Mar 21, 2023 at 6:25 PM
    Abeyancer
    Jimmie
    PNW
    Not to my knowledge no. You will need to have those front shocks set at the lowest setting with those 883s. Do NOT stack lifts.
  11. Mar 21, 2023 at 6:31 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Yes of course. I was planning on the springs doing the lifting and not the shocks. The other way around sounds like premature wear. I think I was just making sure I just need the non extended studs. The only spacer I’m considering is a 1/4 on the front wheels for 15’s if they don’t clear calipers.
  12. Mar 22, 2023 at 9:34 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    What's your reasoning behind replacing the upper arms? Unless you need to replace the bushings in the upper arms, and it's easier for you to just replace the whole arm (and ball joint) instead, the OEM arm is fine. There is a big misconception that you NEED to replace the upper arms with a lift. I am unsure how that started, but it's not true. I ran OEM arms for 20 years with 2.5" of lift. You only need to replace the arms if you can't get a proper alignment (which really comes down to the tech doing the job).
    There is also a MevoTech part number that is the same as the SPC arm for a much lower cost. So you might want to do your research on that, and hit rock auto for those rather than pay more money for the same part. (edit, those part numbers are: CMS861192 and CMS861193, but they don't appear on rock auto anymore, but it does look like you can get them elsewhere)
    In general though, skip the arm unless you need it.
  13. Mar 22, 2023 at 10:20 AM
    manapiko
    manapiko Well-Known Member
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
    i feel seen. :rofl:
    04TRDV6 likes this.
  14. Mar 22, 2023 at 10:28 AM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Check Hellbent Steel. Com for front spacer. Less than $100. Spacer blocks for rear. People dont like them but cheap along with shackles.
  15. Mar 22, 2023 at 10:40 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    You can get by without the UCA's. I did this exact lift without new UCA's and it worked fine. You may want to get new OEM, lower and upper ball joints, tie rod ends, and look at a poly bushing kit for the steering rack (they don't cost much).
    The OME coils are good but I prefer the Eibach springs like these. They don't have the harshness of the OME's.
  16. Mar 22, 2023 at 10:59 AM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Thank you I don’t really want UCAs I just hear ppl say I do. Have you had both springs?
  17. Mar 22, 2023 at 11:20 AM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    I've had both. They are both better than stock, but I like the ride of the Eibach's better than the OME's. Just my impression
  18. Mar 22, 2023 at 12:03 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Thank you, is there a big price difference?
  19. Mar 22, 2023 at 12:21 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I'd pass on the SPCs.
    And is there no kit you can buy that would save you from buying these individually? There was a few years ago when I did it..
  20. Mar 22, 2023 at 1:12 PM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    The Eibachs in the link I posted looked like they are a little cheaper than the OME's you listed in the original post.
