Modifications I can afford- that work
Discussion in 'Technical Chat' started by Lightfoot76, Sep 18, 2020.
  1. Sep 18, 2020 at 10:18 AM
    Lightfoot76
    Lightfoot76 [OP] New Member
    2015 Tacoma TRD Sport
    Non YET
    I just purchased a 2015 Tacoma. It is getting on average 16 miles per gallon even out on the highway. Is there anything I can do without spending thousands of dollars? Does a K&N intake work? Does a different exhaust system work? I have watched videos about how to get better gas milage and each one counters the others. What really works?
    six5crèéd likes this.
  2. Sep 18, 2020 at 10:20 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Your user name is the best "lightfoot" be easy on the skinny pedal :thumbsup:
  3. Sep 18, 2020 at 10:21 AM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW. Save your money on those mods, use it for gas money instead.
    16 to 17 is about as good as it gets in a 2nd gen unless you are going down hill in neutral or have a great tail wind pushing you.;)
    Rock Lobster and six5crèéd like this.
  4. Sep 18, 2020 at 10:31 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    A: stock size highway terrains.
    B: Anticipate your stop - learn to coast more. Red light or intersection up ahead? Let off the gas a full 1/4 mile before.
    C:Learn to cruise at a constant speed through traffic. Every time you jump on the brakes in heavy traffic you just wasted the gas that brought you up to that speed in the first place. Put a big space in front of you and cruise it.
    D: Dont buy in to the bullshit claims of the aftermarket crowd. If anything, that will make it worse.
    Welcome to TW.
  5. Sep 18, 2020 at 11:01 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Rock Lobster has the right ideas. I found that increasing the tire size to LT265R16 made the speedometer/odometer more accurate. Still got better than 25mpg in normal driving with a 4 banger and manual transmission.
  6. Sep 18, 2020 at 1:54 PM
    Lightfoot76
    Non YET
    Thanks you all, Honest advise is greatly appreciated.
  7. Sep 18, 2020 at 2:06 PM
    su.b.rat
    su.b.rat broken truck
    on some tires a higher pressure can improve mileage. my tires are an example of that. i can change the average 1-2mpg by setting the pressure from 28psi up to about 40 which is as high as i like to go on E range. you can go higher but you'd want some load for that.
  8. Sep 18, 2020 at 2:09 PM
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    Remove your tailgate, roll up your windows, don’t turn on the air. :anonymous:
  9. Sep 18, 2020 at 4:44 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    A bed cover will do a lot to reduce drag.
  10. Sep 18, 2020 at 8:06 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I average combo 18-20 with 285s. Imo the best thing is always good maintenance. Plugs are in good shape, airfilter clean, tire pressure correct, regular injector cleaning etc. That mileage is driving posted limits, when I wear my heavy shoes mileage can take a beating.
  11. Sep 18, 2020 at 8:20 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Wow 16mpg? Driving style and tires (PSI too) are the biggest mpg factors. I averaged 21-22mpg before I put on 265/75/16 duratracs, then I started to get 18mpg. Then I did a lift, steel bumpers, winch, steel skids, roof rack...still at 18mpg. I keep it around 70mph, keep it in overdrive even if it means losing some speed up hills, shifting into 4 in the city, etc. K&N intake and exhaust would be a waste of money if you are doing it for mpg improvement IMO
    gotoman1969 likes this.
