Modified OEM shifter reduced height (9 1/2") Shifter for 4WD
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Coupe, Nov 27, 2016.
  1. Nov 27, 2016 at 9:23 AM
    Coupe
    Coupe [OP] Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have been modified worn out shifters on XRU for several years. I have also done them for a few members here.
    I buy old shifters and refurbish them. I remove the old worn out internal rubber bushings and replace them with a polyurethane epoxy. This will make the shifter very firm and will far outlast the stock shifter. In this process, I usually cut the height of the shifter down 1 ~ 1 1/2 inches.
    Today, I have a shortened OEM shofter (9 1/2") for a 4WD. This one is approximately 9 1/2" from the bend (Stock is about 11 1/2"). Stock rubber inernal bushings have been removed and replaced with a polyurethane epoxy. This will shift much firmer than a stock shifter. This works best when paired with an URD SS.
    Price is $120 shipped + your old oem shifter. I ship the shifters with a new white tip bushing.
    This nex pic shows the difference between a stock height shifter (top) and the 9 1/2" shifter (below). Both are 4WD shifters.
    Kuntrykid likes this.
  2. Nov 27, 2016 at 10:27 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Is there a limit to how short or how much you can cut off?
  3. Nov 27, 2016 at 3:12 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I can cut them down to 8 1/2" That is usually the limit.
    If a woman drives the truck, I would not go less than 9 1/2".
    As the shifter gets shorter, the travel is less, but you also loose leverage.
  4. Nov 28, 2016 at 7:46 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Why is that bout woman? Lol I get the leverage thing
  5. Nov 28, 2016 at 7:51 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have a petite wife who works out on a regular basis. She has enough upper body strength to shift 8 1/2" shifter into reverse. If you have been curling 12 oz cans instead of 30lb weights, let the 9 1/2" be your limit.
  6. Dec 26, 2016 at 5:48 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Bump.........
  7. Dec 26, 2016 at 8:22 AM
    mahon
    mahon Well-Known Member
    Eric
    I have a 9.5 in my truck and I wouldnt go much lower. It isnt hard to get into if you know where it is. However ive had multiple coworkers ask me to drive my truck. They all drive stick, I tell them if they can get it into reverse they can. So far out of 6 only one has been able to. Keep in mind i tell them where reverse is.
  8. Dec 31, 2016 at 12:05 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have one left.
  9. Jan 10, 2017 at 7:03 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Bump...........
  10. Jan 18, 2017 at 12:30 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Bump.........
  11. Jan 20, 2017 at 2:43 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    This has sold.
  12. Oct 16, 2018 at 3:52 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @Coupe Do you still make these? Have any in stock?
  13. Oct 16, 2018 at 4:18 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I do not stock them anymore.
    I build them when someone asks for one.
