Modified SR5 vs Off-Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bwise, Jun 18, 2025.
  1. Jun 18, 2025 at 2:09 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I'm a "capabilities" guy. Which means I would rather have it than not need it...... (you know the rest).
    OP: get yourself an OR and be done with it.
  2. Jun 18, 2025 at 2:12 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    100% this.
    Cetacean Sensation likes this.
  3. Jun 18, 2025 at 3:54 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't think that's the case but could be wrong, 8.0 on the SR5 and 8.8 on the OR.
  4. Jun 18, 2025 at 5:59 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    You very well may be correct. I'm finding misleading info.
    Tocamo and shakerhood[QUOTED] like this.
  5. Jun 18, 2025 at 6:56 PM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    Lot of that around here …. but try to put in an OR rear into an SR5 (non 22,23 Trail) and you'd be left hoping you can get your money back.
    shakerhood likes this.
  6. Jun 18, 2025 at 7:01 PM
    MGMDesertTaco
    IrishRed[QUOTED] likes this.
  7. Jun 18, 2025 at 8:09 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    If I had infinite choices for inventory, I would've bought a sr5 and then just modified it and added a ARB locker. However, TRD ORs were much easier to find in the spec I wanted, so I went with that. With the right rebates and dealer the price difference isn't drastic anyways.
  8. Jun 18, 2025 at 8:34 PM
    shakerhood
    Southern Ohio
    The MSRP between the SR5 and the Off Road in the same configuration was only like $1800 difference. For all the extra features in the Off Road it was a bargain for that small price difference.
  9. Jun 18, 2025 at 9:25 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Yeah, it was more in canada (I think like 4k in access cab config). I don't regret ending up with the TRD off-road, but the only thing left about it that is trd off-road is the electronics and rear locker.
    shakerhood[QUOTED] likes this.
  10. Jun 19, 2025 at 10:47 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The best thing about the OR is the manual transmission option.
    Also, while you can put a locker in a SR5, you’ll be very hard pressed to put off-road traction control in one.
  11. Jun 19, 2025 at 10:51 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    You've basically summarized exactly my position here. I've only used my locker a few times over the past few years, but it made things worth it on those occasions.
    It's also worth noting that an OR will likely hold its value better than an SR5, if future resale is something on your mind.
  12. Jun 19, 2025 at 11:22 AM
    paralysisXanalysis
    paralysisXanalysis Active Member
    Mesa, AZ
    2016 Tacoma TRD OR
    Auxiliary cooling fans, rebuilt takeoff TRD pro shocks, Airbags, Deavers, Trans Cooler, Fab Four rear bumper, 2wdLo mod, other dumb stuff
    I might be in the minority but I would not go back to another non-locker truck ever. They are an absolute godsend in the sand, mud and steep climbs. if I didn't get the OR I would have put a lockrite in it immediately (not my fav on short trucks tho). There is a reason why lockers are popular and a must for many builds. I think the stock OR and SR5 suspension are both garbage so don't let that sway your choice.
    My best argument is lockers make sand far easier with less stress on the motor (yes you still need to air down) and they are so much safer when trying to claw or crawl up steep rutted climbs. It almost eliminates the struggle in so many situations and if you aren't spinning tires your tires will last much longer (I always was chunking my tires in my 4th gen 4runner V8 trying to gently climb up things). It is a massive safety upgrade to me and so helpful offroad. I flip mine on about once a month due to a steep climb, deep sand or a little help getting through a water/mud crossing. It is a night and day difference.
    Tastes can change with capabilities, I used to drive a CJ7 and had no desire to go fast in the desert or FS roads, since then I've bought more capable rigs made this century and have enjoyed the capabilities. So if its in the budget get the locker so you can try new things, If it is not for you it is still good backup.
  13. Jun 19, 2025 at 11:35 AM
    gudujarlson
    Minnesota
    I have to disagree with this. I have found the rear locker plus off road traction control (ATRAC/MTS) to be an almost imperceptible upgrade over off-road traction control alone. The traction control however is a big step up from open diffs. The difference between traction control and locker is only perceptible to me in cases where I pick a rear wheel off the ground. In those cases, there is a slight delay in forward movement before traction control kicks in, but no such delay when using the locker.
    It would be interesting to compare traction control to having both front and rear lockers. 60% of traction in most cases is from the front axle (due to weight distribution), so a front locker should be a bit more effective I think maybe.
  14. Jun 19, 2025 at 12:07 PM
    paralysisXanalysis
    Mesa, AZ
    2016 Tacoma TRD OR
    That is wild! But I don't doubt you for your situations, and I get what you are saying about the traction control, I got soured on the A-trac on my 4runner cause I kept ripping lugs off of BFG KM2s with even the minimal wheelspin/throttle. the toyota traction control setup is great but for me it has not been sufficient for my needs. Maybe you are better at using traction control than I am. AZ is dry and tough to get traction and most all the rock out here is good at destroying lugs. I see you hail from Minnesota so maybe soil differences and trail conditions can account for your success? Also potentially you are just a massively better driver, who knows. I am not taking shots but just asking have you taken your truck to the dunes or some deep dry sand also how often are you lifting a wheel? Again you make valid points and perhaps the locker argument is use and location specific and not something that can be perfectly generalized? In my general experience not having a locker and wheeling with those that did I was not as capable and your general experience is different. I would be interested to see a situation where A-trac (or whatever the current acronym is) would out perform a locker? Maybe if you were sunk to the frame in sand and you set crawl control and let the computers do its wizardry?
    I still like lockers and still want them on my vehicles but you do you man
  15. Jun 19, 2025 at 12:14 PM
    #35
    FunknNasty
    San Jose
    2022 Pro
    I could live without the rear locker in my Pro, but I’m glad it’s there -if I want to actually drive. But I’m still in complete awe with the mts/crawl tech. I'd feel totally fine with my wife/daughter doing stuff with the traction control on that would otherwise scare the shit out of me with an old school front and rear locker.
    Now I also think the Tacoma SR5 limited slip only option is robust and pretty darn close to the rear locker, performance is wise.
  16. Jun 19, 2025 at 1:19 PM
    #36
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Definitely. There is no substitute for two lockers :D
    Really depends where you're trying to go off road... Lockers are almost mandatory if you're doing any rock crawling. For most other things though like, say, forest roads, I can agree the electronic LSD or "TRAC" (which is active for both front & rear) will get you through most stuff no problem.
    paralysisXanalysis likes this.
  17. Jun 19, 2025 at 1:23 PM
    #37
    FunknNasty
    San Jose
    2022 Pro
    Yeah, I was certainly leaving out the Rubicon and other very condition specific environments in my post.
  18. Jun 19, 2025 at 2:20 PM
    #38
    paralysisXanalysis
    Mesa, AZ
    2016 Tacoma TRD OR
    I get the stock empty weight distribution argument but..... in stock form EMPTY (on dead level ground) there is supposedly a 500-850lbs weight difference between the front and rear axles, so 500-850lbs is a potentially easy amount of weight to add or exceed and then we are looking at 50% or more of the weight on the rear tires. but I have never weighed my rig.
    Now I am not an engineer or physicist but...... as the slope the vehicle is on increases the weight distribution changes because gravity pushes straight down (always). this is one of the reasons why lockers are placed in the rear.
    Id rather have a rear locker over a front locker. But 2 lockers are better than one. there are some situational drawbacks but lockers are good and required for rock crawling and extremely beneficial in mud & sand & I am from AZ so I won't speak of snow freely
  19. Jun 19, 2025 at 2:35 PM
    #39
    4x4junkie
    So Calif. (SFV)
    Not sure where anyone argued anything about weight-distribution... But you are correct that some weight does transfer to the rear when climbing up a hill (of course the inverse is also true when pointed downhill). If you only have one locker, it's normally preferable to have it in the rear axle (another reason for this is the rear axle also is usually much more robust than the front, and can better-tolerate a locker).
  20. Jun 19, 2025 at 2:37 PM
    #40
    gudujarlson
    Minnesota
    I’ve never weighed my truck, but I read some specs somewhere that said a v6 DCSB 4x4 Tacoma has a 60/40 weight distribution. So:
    front: .6 x 4600 lbs = 2,760 lb
    rear: .4 x 4600 lbs = 1,840 lb
    It’s also intuitive me after years of driving front and rear drive cars in the snow that the front axle is has more traction than the rear on most front engine vehicles. A 2wd unloaded pickup is the worse vehicle for driving in snow.
