Modifying driver seat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mako86, Mar 2, 2012.
  1. Mar 2, 2012 at 5:50 AM
    mako86
    mako86 [OP] Member
    Nova Scotia
    09 trd sport 4x4 dclb
  2. Mar 2, 2012 at 5:59 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    Im 6'1 and the sport seats are pretty good length wise for me
  3. Mar 3, 2012 at 5:26 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Using aluminum as the op did in that thread wouldn't have the strength the steel had. The possibility of mount failure would be greater in a collision imo. Steel would be safer.
  4. Mar 3, 2012 at 7:54 AM
    mako86
    mako86 [OP] Member
    Nova Scotia
    No turning back now. I did the mod yesterday. I cut the legs off the back of the seat rails with a recip saw and drilled out the rivets. I then cleaned them up with a grinder. I used 1/4" flat bar for the new legs and bolted them on with 1/4" bolts. The only problem I had is when I bolted it back in the truck the seat wouldn't go back all the way. It was hitting the mounting bolt on the floor, so I had to put 2 washers between the rail and the new legs. I'm going to have to put another piece of flat bar where I have the washers now. Monday I going to take the seat back out, have the bar welded to the rails and paint them. Never drove it yet but just seating in it feels much better.
  5. Mar 3, 2012 at 7:57 AM
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    Props for hacking up the seat frame!:eek: That's a mod that would not have occured to me...
    I'm 6'1" and am very comfy in my DCSB... I even have the seat forward 2 clicks... :anonymous:
  6. Mar 3, 2012 at 8:12 AM
    mako86
    mako86 [OP] Member
    Nova Scotia
    I have the seat more than 2 clicks forward. That's the problem, I have to have it forward to reach the wheel comfortably but then my legs are bent at such an angle that the back of my thighs are not touching the bottom cushion. I wish the wheel telescoped more than an inch. I was in a Jetta GLI a couple of days ago and couldn't believe how far the wheel telescoped. Must of been a good 4".
  7. Mar 3, 2012 at 8:13 AM
    badger
    badger Well-Known Member
    07 SR5
    I've modified my seat mounts, dead pedal, clutch pedal, and shift lever to get the ergonomics correct for me. I spend too many hours driving to have it all wrong. I wish the manufacturers cared more about ergomonics. What they sell is the equivalent of selling shoes in size 10 only. Too big? too small? = tough luck. The effort that it takes to make a vehicle fit is one reason I keep mine a long time. I don't want to go back through all that on the new one. All the important adjustments for proper fit could be made adjustable or at the very least replaceable with the right parts. It affects control of the vehicle, and visibility out of the vehicle in addition to comfort. With airbags involved, the situation can actually become hazardous for smaller drivers. It sucks.
    Nice solution OP :)
  8. Mar 3, 2012 at 10:19 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    very surprised when i found out the seat wasn't height adjustable. I have spacers to angle the seat more forward. I'm 5'8".
  9. Mar 3, 2012 at 11:08 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Agreed on the horrible ergos of the stock cab.
    Compared to my '95 Suburban... seat all the way back, comfortable foot/leg position, and the bottom edge of the wheel was in my lap.
    Taco? 2 clicks forward, comfortable reach to the wheel and my legs are bent.
    Seat all the way back, legs are comfy but I can't reach the wheel or dash controls comfortably.
    Toyota must have found a guy with gorilla arms to design the cab around.
  10. Mar 3, 2012 at 11:18 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Check the build
    x2 have the exact same problem. in order to get it to the right position, something is being compromised, and on long drives, it starts to take a toll
    good work op
  11. Mar 3, 2012 at 12:01 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Crazy... I'm 6'4" and I'm very comfortable in my taco. I've got the seat a couple clicks up from the farthest setting...
  12. Mar 31, 2013 at 11:53 AM
    HB2010
    HB2010 Member
    2005 TRD sport package double cab
    I am 5'-11" but would like to have the seat higher (maybe a couple of inches).How did you add the spacers and where? Is there any ways to raise all four mounts?
    If you may include pictures, would be greatly appreciated.
  13. Mar 31, 2013 at 2:11 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Japanese truck is not designed for fat americans ;)
  14. Mar 31, 2013 at 2:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I beg to differ.
    Newer vehicles, including Toyotas, I have a problem where when I move the seat far enough back to have comfortable leg room, I can not comfortable hold the wheel and reach the dash controls.
    My '94, seat all the way back, everything fit nicely.
    My '95 Suburban, the wheel was a little cramped with the seat all the way back, but not bad... I just couldn't hold a drink cup between my thighs.
    The '03 Tundra was pretty good... nice balance like the '94, maybe a little too much room... I didn't run the seat back all the way, but leg/arm room was well balanced.
    The '08 Taco, I'm 6'3" and I've got the seat 2 clicks forward and there's still plenty of "headroom" in my lap.
  15. Mar 31, 2013 at 2:58 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    05 prerunner trd off road DC
    Red hot glass pack muffler dumped preaxle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front and modified zuk mod coil spring lift for about 2" in rear paired with 5100 also. C channel front bumper. Maxxis bighorn 255/85/16
    Japanese truck only in name. Taco is one of the most American trucks out there. Motors made in huntsville al and Texas I believe also, assembled in ca and baja Cali but not much from japan. And since America is the only place to find tacomas id say theyre prolly designed for us.
  16. Mar 31, 2013 at 3:02 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    California production plant shut down in 2010 (and became a Tesla production facility).
    Tacoma's are made in San Antonio now.
  17. Mar 31, 2013 at 8:21 PM
    ouyin2000
    Arlington, Virginia
    '11 DCSB TRD Sport
