Modifying Icon add-a-leaf
Discussion in 'Suspension' started by xmikedentx, Jun 16, 2016.
  1. Jun 16, 2016 at 10:17 AM
    xmikedentx
    xmikedentx [OP] Well-Known Member
    Yucaipa
    2016 TRD OR White (sold)
    I plan on installing the 3 leaf pack on the rear of my '16 Tacoma, but I don't want the full 1 1/2" lift. I only want about 3/4" of lift. Is there a preference to which leaf to pull out, or has anyone done this before? I was planning on dropping out the very bottom leaf, and installing the other 2 and see how it works, then I thought about removing the upper leaf. Not sure which is best.
    Any ideas?
    TIA
  2. Jun 16, 2016 at 6:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    To get 1.5" in the rear you have to remove the overload. You are then talking about removing additional leafs from the pack to reduce lift. Seems like a possible risk to inverting the springs. If you did it I would remove the bottom leaf.
    These springs claim .75" rear lift and increased load carrying capacity, but some have reported getting more lift:
    http://www.northwestoffroad.com/parts/2stage.php
    I'm sure there are others.
    What is your end goal? Increased spring rate? Just wanting .75" lift, while not wanting to lift the front? Are you jumping like your avatar pic? If so spring inversion seems likely.
  3. Jun 16, 2016 at 9:22 PM
    xmikedentx
    Yucaipa
    LOL, no, that's my old race truck, it had 2" negative arch, good enough for the deavers to last one season. I actually installed the front lift tonight, (ICON stage 4) and the truck sits perfectly level, which acutllay looks like its 1" higher in front. So now I'm thinking I only want 1/2 lift for the rear. My goal is to remove the overload and install the add a leaf, cause I hear they ride better, but I don't want all the lift. Mabe install the whole leaf kit and get a lowering shackle.. i dunno
  4. Jun 16, 2016 at 9:26 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    After time the icon aal will settle to 1"
  5. Jun 21, 2016 at 2:32 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    just put the icon 3 leaf on my pro,, with overload out 1 inch differance front to back......better ride,,
