Mods for 'light' offroading
Discussion in 'Off-Roading & Trails' started by Sgtaco911, Jan 18, 2019.
  1. Jan 18, 2019 at 2:52 PM
    Sgtaco911
    Sgtaco911 [OP] Member
    2016 TRD OR
    Hi all, I have a 2016 stock TRD and want to get into light wheeling. Light meaning more than a trail through the woods. Not really interested in rock crawling or anything hardcore yet. In saying that, what are some mods I should have? Besides new tires... have 30k on stock and will replace with duratracs. Thanks for your help!
  2. Jan 18, 2019 at 2:53 PM
    Sgtaco911
    2016 TRD OR
    Hi all, I have a 2016 stock TRD and want to get into light wheeling. Light meaning more than a trail through the woods but not really interested in rock crawling or anything hardcore yet. In saying that, what are some mods I should have? Besides new tires... have 30k on stock and will replace with duratracs. Thanks for your help!
    ChadsPride likes this.
  3. Jan 18, 2019 at 2:56 PM
    Ossaris
    Ossaris A Bad Person Doing Good Things
    Aliens
    SoCal
    2016 TRD OR 4x4 w/ 6112s & 5160s
    Lights for days! Sasquachified!
    Just grab some recovery gear for piece of mind and hit the trails. Based on what you're comfortable with and your dedication towards doing it, that'll tell you a TON about what investments to make, if any are needed.
    STgen3, Sgtaco911[OP] and Paul631 like this.
  4. Jan 18, 2019 at 3:04 PM
    Sgtaco911
    2016 TRD OR
    Thanks. What type of recovery gear do you recommend?
  5. Jan 18, 2019 at 3:05 PM
    Ossaris
    Aliens
    SoCal
    Where are you going? How technical are you planning to do?
    I'd just start simple - a shovel, maybe a crowbar and, if you're feeling ambitious, grab a hi-lift and recovery kit
  6. Jan 18, 2019 at 3:13 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    My suggestion would be an air compressor for airing up tires. Having one so you can air down your tires to like 20psi makes a huge difference and can make the truck feel smoother and more capable off road.
  7. Jan 18, 2019 at 3:15 PM
    Shellshock
    Iowa
    STgen3 likes this.
  8. Jan 18, 2019 at 3:20 PM
    Bishop84
    Bishop84 Well-Known Member
    Agree with above, compressor (get a battery clamp style with metal housing, no cigertte socket style) so you can deflate to around 20psi, better traction on rough trails and waaaaaay easier on your back.
    A good recovery strap with d rings. A shovel. Some good boots go a long way too.
    Sgtaco911[OP] likes this.
  9. Jan 18, 2019 at 3:25 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You don’t even need a fancy compressor, something inexpensive like this will work fine, I’ve used this one for 5+ years.
    Slime 40026 2X Heavy Duty Direct Drive Tire Inflator https://www.amazon.com/dp/B005Z8HAUK/ref=cm_sw_r_cp_api_i_p-LqCb2S153Q8
    Plus a recovery strap, the kind with loops not hooks. Also get something to attach to your receiver to give you a pull point from the rear as the trucks don’t have rear recovery hooks.
  10. Jan 18, 2019 at 3:27 PM
    Ossaris
    Aliens
    SoCal
  11. Jan 18, 2019 at 3:29 PM
    PcBuilder14
    Brent
    Nor Cal
    Some good points made. Recovery gear is a really good idea as well. Since you're new to wheeling I highly suggest going out with experienced people to help you see what your truck is capable of. You'd be surprised at what it can do completely stock.
    If you're like me and enjoy going out by yourself sometimes then I suggest either a winch or some traction boards along with a shovel. It's never fun being out in the middle of nowhere by yourself and making a simple mistake of getting stuck.
    Ossaris likes this.
  12. Jan 18, 2019 at 4:00 PM
    Ossaris
    Aliens
    SoCal
  13. Jan 18, 2019 at 4:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Ossaris[QUOTED] likes this.
  14. Jan 18, 2019 at 4:03 PM
    Ossaris
    Aliens
    SoCal
    You da man!
  15. Jan 18, 2019 at 8:07 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    None. Do not waste your hard earned money. Go drive some dirt roads, find some easy trails. These trucks are perfectly capable offroad when 100% stock. THe more you drive, the more you’ll figure out for yourself what mods YOU need/want. We can tell you all the crap we’ve done, but that may not be useful for your style, budget, etc...
    It’s better to drive with another truck, so that if one gets stuck, you can pull them out with the other (obviously you need a tow strap or a snatch strap).
    If you insist on driving alone, read through the recovery section, as you really need to be more prepared. Winches, or other more complex recovery gear is definitely recommended. Also if going alone a way to let people know when and where to start looking for you if you don’t show up.
    Other tools you should think about are a shovel, personal safety (1st aid), gloves, and really, anything else you think you might need. There are lots of tool lists, search around, but just remember those tool lists arent always going to directly apply to your needs, but hey give a great starting point.
    Go. Drive. Have fun!
    mjs90 likes this.
  16. Feb 6, 2019 at 5:19 PM
    BrianPVan
    BrianPVan Well-Known Member
    Brian
    BC
    2017 DCSB OffRoad
    Rock sliders... Saves the rocker panels more then you'd know ;-) (other then what has already been suggested)
  17. Feb 13, 2019 at 11:36 AM
    jbrandt
    Justin
    Even though I put sliders on before skid plates, I would argue that skid plates are more important. Toyota doesn't even call them skid plates (iirc they are called "deflectors" or something), and leave the transmission completely unprotected.
    A dent in your rocker panel is cosmetic, while a rock through your transmission oil pan is a deal breaker.
  18. Feb 15, 2019 at 6:20 PM
    Ole Free
    Ole Free Member
    Jeff
    Phoenix, AZ
    2019 Tacoma TRD Off Road Double Cab Long Bed
    None yet but that's why I'm here. I hear nothing but great things about this forum
    There's a ton of videos on You Tube about the basics, I've heard a millions times from a million sources, Rock Sliders and some recovery gear, stay mild and don't get squirrely. The First Aid Kit thing is a great idea too. You'll figure out pretty quick what you'll need next because you didn't get squirrely your first few times out. the trails will tell you what you need to get more aggressive quick. I've been running stock with a Pre-Runner so I pickup my new TRD Off Road Thursday. Get the idea?
    good luck, be careful and have fun.
