Mods per water depth
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JGJ, Sep 29, 2011.
  1. Sep 29, 2011 at 3:08 PM
    JGJ
    JGJ [OP] Well-Known Member
    Can you guys tell me what mod needs to be done to our tacoma per certain water depth?
    For example:
    Stock tacoma can safely travel through X inches of water.
    Diff Breather mod can allow you to safely travel through X inches of water.
    Snorkel mod can allow you to travel through X inches of water.
    Thanks for the help.
  2. Sep 29, 2011 at 3:11 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Well there is no mathematical equation for it. All depends on how it splashes up in your intake, constant momentum will reduce the chance of getting water in the cab,
    General rule:
    If you can't walk across it, Don't Drive across it!
  3. Sep 29, 2011 at 3:12 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    unless i know whats under the water i wont go through it,even then i wont drive through anything deeper than mid wheel
  4. Sep 29, 2011 at 3:47 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2 on that
  5. Sep 29, 2011 at 3:54 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    just use common sence. i have bad water to the top of my tires
  6. Sep 29, 2011 at 4:13 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i disagree with that statement sir..... if cant walk across it i will attempt to get across it in the truck lol:D
    ive had water up to the top of the hood....
  7. Sep 29, 2011 at 4:20 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I've had water above the hood touching the windshield, side windows, and mirrors. I will never do it again I got water all over the inside of my door. It ruined my speakers shorted out anything that was connected to the radio in some way. Water started seeping into my cab and got some of the carpet wet. I'm luck it didn't hydro lock on me as the entire intake was surely under water for about 10 seconds maybe more. Never cross water if you don't know how deep it is. And for me I won't go above the rocker panels.
  8. Sep 29, 2011 at 4:32 PM
    ANGUS
    ANGUS Well-Known Member
    Beckley, WV
    06 SR5 4cyl
    3in rough country, front adj bilstiens 5100s, volant cold-air intake, magnaflow exhaust, optima yellowtop, 4.56 motive gears rear, 4.56 nitro gear front with v6 front diff carrier, brute force fab front bumper, 6k hid, 1.25" wheel spacers, 15% window tint, cab lights, color matched bushwackers, trd hood
    General rule:
    If you can't walk across it, Don't Drive across it![/QUOTE]
    thats the whole reason im drivin cause i dont wanna walk. when in doubt, throttle out!
  9. Sep 29, 2011 at 4:36 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    amen brotha!^
  10. Sep 29, 2011 at 4:47 PM
    theduck911
    Max
    Locked and Geared!
    Water that high can cause serious problems not just engine wise but in electrical and other components. Enough speed though & if you don't get stuck you'd be fine:cool:
    Not saying it can't be done, just more likely to run into problem and such.
  11. Sep 29, 2011 at 5:07 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    1/2 up the wheels for me. If anyone here is walking in the water I want a picture!
