Mods to fit 8.4" differential in elocker housing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turboencabulatr, Aug 10, 2016.
  1. Aug 10, 2016 at 3:13 PM
    Turboencabulatr
    Turboencabulatr [OP] Member
    Los Angeles
    2007 trd prerunner
    I know that the normal pumpkin with an LSD will not fit into an e-locker diff but I want to see if anyone knows what mods can be done to make it work?
    From pictures it looks like if i knock out/ remove 2 studs I should be able to bolt that sucker in there. Can anyone confirm?
  2. Aug 10, 2016 at 3:14 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    i dont think its that simple...or even possible for the matter
    honestly i would just throw an arb or detroit locker into the 8.4 diff and call it a day.
    lets ask someone with some knowledge @MonkeyProof
  3. Aug 10, 2016 at 3:18 PM
    Pigpen
    Dan
    Northwest Montana
    Swap axles. They're both 8" diffs. Toyota just calls the non e locker diff an 8.4 because it's stronger. The e locker doesn't allow for the stronger supports of the "8.4". There's no way to do what you want to accomplish with an e locker diff.
  4. Aug 10, 2016 at 4:38 PM
    Turboencabulatr
    Los Angeles
    2007 trd prerunner
    I specifically want an lsd and not a locker. By suports do you mean studs for the 3rd member?
    Yes an axel swap is on the table but not preferred.
  5. Aug 10, 2016 at 4:51 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    oh shit my bad...i thought you wanted to swap your lsd to locker lol
  6. Aug 10, 2016 at 4:58 PM
    Pigpen
    Dan
    Northwest Montana
    I forget the exact details, but the internal parts supporting the gears are stronger in the "8.4". The e locker housing doesn't leave enough room for the extra strength.
  7. Aug 10, 2016 at 5:08 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    This can be done and their is a thread on here showing a couple small notching cuts in the upper portion of the opening to allow for it. However, I think the guy that did it had a lot of time on his hands and it didn't really turn out to be worth it in the end. There are enough non-Elocker housings in junkyards to just swap out instead. I will look for the thread and post it up if I can find it again. I came across all of this when I was trying to research the difference in the inappropriately titled 8.4/8.25 vs 8" third members. As previously stated, they are both 8", but the non-Elocker is a bit beefier.
    The last I will say is that the current TRD OR models won't have the Auto LSD feature even with a current model third member axle and housing. The Auto LSD is an electronic LSD controlled at the brake pad and not a mechanical version inside the pumpkin with clutches. If you swap axles with a current model and don't install a lunchbox or some other LSD then bone stock will only provide for an open differential without the electronic control module. Toyota stopped building mechanical LSDs OEM in 2009, I believe. These are hard to come by, but aftermarket is easier and probably better quality at this point with technology.
    Pigpen likes this.
  8. Aug 10, 2016 at 7:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    why in the world would you want to get rid of your locker?
  9. Aug 10, 2016 at 7:31 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I personally prefer LSD rear and locker front. When i crawl it pulls me over and when i am on the street i have all around traction. It also is cost effective to buying another locker. The OP, of course has a stock locker and I have no experience of any electric actuator failure or additional maintenance.
  10. Aug 11, 2016 at 8:18 AM
    Turboencabulatr
    Los Angeles
    2007 trd prerunner
    Going for aftermarket lsd. Locker does ya no good driving a supercharged truck on the street.
    zippsub9 likes this.
