mods to help me get better mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cre814u2c, Feb 21, 2013.
  1. Feb 21, 2013 at 1:23 PM
    cre814u2c
    cre814u2c [OP] Member
    Tom
    Oxford, PA.
    2013 Tacoma trd sport
    2013 double cab trd sport ,automatic v6
    I don't want to spend money that's gonna take 5 years to recoup.
  2. Feb 21, 2013 at 1:26 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Don't add a lot of weight. Only use highway tires. Keep it waxed and clean. Use synthetic oil and use regular gas, which ignites the easiest. Also, drive with a light foot. Don't ask too much of it.
    There aren't many mods I have found that work.
  3. Feb 21, 2013 at 1:26 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Don't drive it
  4. Feb 21, 2013 at 1:27 PM
    Tylerm5000
    Tyler
    Oregon
    And congratulations on your new truck! I can't wait to buy myself a new vehicle someday. Urg. I still love my truck.
  5. Feb 21, 2013 at 1:27 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    New muffler will help a bit. well it did on my first gen
  6. Feb 21, 2013 at 1:28 PM
    eric3187
    eric3187 Well-Known Member
    drive no faster than 65mph. stay off the brakes and allow the truck to coast (requires less gas pedal to get back up to speed when traffic opens back up)
    keep up on tire pressure.
    different truck but i took a 4.0v6 ford ranger and could get 26mpg out of it when doing the above... mind you it was mostly highway driving, but the same route doing 75-80mph would put me around 18-19mpg
  7. Feb 21, 2013 at 1:28 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Scanguage, proper air pressure, and be strict about your rpm's, drive 60 instead of 65 on freeways etc
  8. Feb 21, 2013 at 1:43 PM
    cre814u2c
    Tom
    Oxford, PA.
    Usually ride my harley everywhere but the cold is really gettin to me. The ride to work is at 3am .
  9. Feb 21, 2013 at 1:44 PM
    Larry
    Larry CARL
    CARL
    my 2012 dc sport = 18 mpg's
    my 2010 dc sr5 = 20 mpg's
    only differance are the tires/wheels...and the TuRD stickers.
    I removed the stickers, but the mpg's have not improved. :D
  10. Feb 21, 2013 at 1:44 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good driving habits is the best thing you can do for MPG.
  11. Feb 21, 2013 at 1:45 PM
    cre814u2c
    Tom
    Oxford, PA.
    Larry , that good lol
  12. Feb 21, 2013 at 1:47 PM
    cre814u2c
    Tom
    Oxford, PA.
    Thank you
  13. Feb 21, 2013 at 1:48 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    The hood scoop adds horsepower, remove it and get better mpgs :D
    Edit: i misspelt skewp
  14. Feb 21, 2013 at 1:51 PM
    cre814u2c
    Tom
    Oxford, PA.
    I have good driving habits , been driving a tractor trailer for 26 years. I understand what you're saying and I am very lite on the pedal.
  15. Feb 21, 2013 at 2:09 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    get a better job so you can afford the gas
  16. Feb 21, 2013 at 2:16 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  17. Feb 21, 2013 at 3:54 PM
    forcefedsupra
    forcefedsupra Member
    Dustin
    Broken Arrow, OK
    2009 4x4 V6 manual
  18. Feb 21, 2013 at 4:00 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Premium gas on my 4.0L is cheaper if it's $0.20 more. I lose 2-2.5 degrees of ignition timing at highway speeds if I run regular grade and it does make a minor impact.
    I picked up a little average mileage when I put redline 75w85 GL5 in the differentials but as my truck was used I'm not sure if it had the factory Toyota 75w85 Diff Oil LT or if the previous owner had switched to another viscosity. My dad believes his tundra picked up a little mileage with that gear oil.
    Tonneau cover is good for crosswind days or at the highway speeds where mileage is crappy anyways, but then again you're talking 5 year recoup.
    Here's one that's cheap... trim the front mudflaps! They're like sails and flop around at speed when they're ankle-length anyways.
  19. Feb 22, 2013 at 8:25 PM
    shen
    shen 09 TRD Sport 4x4
    Coppell, TX
    2009TRD Sport 4x4
    Always something
    I know there are mixed reviews on air filter, but I do believe minor gain could be have on using the AFE dry filter.
    And most important is time....your truck is brand spanking new. After few thousands miles, I'm certain your mpg should will go up....plus by then, we should be out of this winter gas.
  20. Feb 22, 2013 at 8:44 PM
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    Yup, the gas pedal mod works really good (light on the pedal with your foot). I do however like to drive spirited here and there.
