mods to help me get better mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cre814u2c, Feb 21, 2013.
  1. Feb 22, 2013 at 8:47 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    It's a truck. What you buy is what you get. Want better mileage, buy a prius.
  2. Feb 22, 2013 at 11:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Duct tape an egg to the accelerator and don't break it.
    Gadgets and additives don't do much.
    Those that might do something do not do enough to EVER pay for themselves.
    The only thing that might help would be an Ultragauge or a Scangauge. Simply tools to help you drive more efficiently.
  3. Feb 23, 2013 at 12:09 AM
    Usmcsantosj
    Usmcsantosj Well-Known Member
    Jovani
    Orlando, Florida
    2013 TRD Sport
    By order: Tinted windows, WeatherTech liners added, NFab's, bar caddy center console, plasti-dipped emblems and rims.
    :rofl:
  4. Feb 23, 2013 at 12:36 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    you already have the hood scoop op, thats +2 mpg +5 hp right there!
  5. Feb 23, 2013 at 8:57 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Fill Ur tires with helium instead if air, don't forget to spare. That should net u a weight loss of close to 100 lbs and add to about 1% increase. Get a two speed rearend with 4.11 and 3.23 low in city high in hwy. Don't let Ur truck idle. Get a horse and a carrot and a rope tie him up and put in nuetral.
  6. Feb 23, 2013 at 11:59 AM
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    Only drive downhill. I will guarantee your MPG will increase. :rolleyes:
  7. Feb 23, 2013 at 12:06 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    best answer.
  8. Feb 23, 2013 at 12:24 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Properly inflated tires=35psi not what's listed on the door jam
  9. Feb 23, 2013 at 2:26 PM
    Larry
    Larry CARL
    CARL
    it is a small truck. it should perform better mpg's. the tecnology is probably available to squeeze more mpg's out of a 4.0 v6. maybe the next gen will.
    actually...I wish my Tacoma was a hybrid, or a straight plug-in.
  10. Feb 23, 2013 at 2:46 PM
    miniceptor86
    Jim
    McGregor,IA
    Direct injection would be the next logical step to improve mileage, maybe in 2014 or 15. No hybrids/plug ins for me, can image pulling a TT to Texas and back with either, Even with a hybrid the gas motor would be running all the time and the mileage would be the same. If I were doing the big city commute, stop and go, short distances, warm climate, an hybrid or plug in would be great and if that were the case I wouldn't be driving the PU to work and a easy to park in a small space prius, yadda yadda hybrid would be my choice.
  11. Feb 23, 2013 at 3:11 PM
    tacotruck 2.7
    tacotruck 2.7 Well-Known Member
    Katy TX
    09 cab and a half 2.7
    Kiwi.com chek out their mpg monitor . alone it wont save gas however the fact that it gives you real time and avg mpg read outs temp,rpm,scancodes,mph and other stuff for +/- 45 $ is worth a try. Ive been using it a year and ive probably gained 2 mpg from jus changing habits think of it as a driving coach. Plugs rite into your obd 2.
  12. Feb 23, 2013 at 3:22 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yeah I was gonna say, ride your motorcycle. I wont be able to get mine out until spring, but my Harley gets great mileage, 57mpg is the best so far. With the truck, just drive it like grandma is all I can say.
