Mods to improve gas mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ssramage, Apr 8, 2012.
  1. Apr 18, 2012 at 11:57 AM
    #61
    squashroll
    squashroll taco tuesday
    NorthWest
    sold '90, waiting for 3rd gen
    If new tires are needed choosing a set with low rolling resistance would be cost nuetral...
  2. Apr 18, 2012 at 4:50 PM
    #62
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I do believe nearly everyone who purchased the v6 manual instead of the auto has felt the mpg buttpain. The inverse is true for the 4 cyl folks.
    Trucks with my tranny with the mileage capabilities it's shown are ...rare.
  3. Apr 18, 2012 at 5:11 PM
    #63
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Tragically it is all on Toyota for choosing a terrible OD gear ratio for the 6-speed. They could have made the stick better than the auto with the right gear choice. I'm usually not a conspiracy fan but in this case I think Toyota sees more profit not selling sticks in the US.
    Your doing pretty good with your combo though. :cheers:
  4. Apr 18, 2012 at 5:17 PM
    #64
    worthywads
    Careful what you choose, I made the mistake of buying Michelin's green-x low rolling resistance marketing on their Hydro-Edge series and find them to be a lot worse than the oem Firestones. I get minimum 2mpg less with the Michelins. Worse yet they are 90K tires so I'm stuck with them for way to goddamned long. :frusty:
  5. Apr 18, 2012 at 5:37 PM
    #65
    squashroll
    NorthWest
    Lame sauce! Is there any standard rating system on rolling resistance? How do you know if you are getting a good tire or not?
  6. Apr 18, 2012 at 5:46 PM
    #66
    DOUBLEJTACOMA
    DOUBLEJTACOMA Active Member
    Jeremy
    Jasper, Alberta
    Blacked out SR5
    -Black Halo Projector Headlights with HIDs -Black Billet Grille -Night Shaded Tail Lights -Exhaust (Magnaflow) -URD 2.7L Supercharger (soon, may need help)
    You could install a lowing kit from Tundraracing.com. That would be a mod that would increase mpg. Looks good too!
  7. Apr 18, 2012 at 5:51 PM
    #67
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    best mod, less skinny pedal.
    /thread
  8. Apr 18, 2012 at 6:16 PM
    #68
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Dunno yet... it just showed up today and I haven't even opened the box.
  9. Apr 18, 2012 at 7:15 PM
    #69
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Horseplay is always fun until someone gets hurt. That's good that the child or the horse wasn't hurt.
  10. Apr 18, 2012 at 7:38 PM
    #70
    iroh
    michigander
    tonneau
    Tabbed browsing sure is awesome isnt it
    First time hint: when you plug it into the OBD2 port it'll start searching for the ECU's protocol; you have about 10-15 seconds after that to turn the key to the ON position or it'll miss it, and you'll have to turn key off, unplug, and start over.
    That one made me upset for a while until I figured out what was going on
  11. Apr 18, 2012 at 8:30 PM
    #71
    Rich91710
    Rich
    Los Angeles
    08 Base
    I guess the EM1 is different.
    I plugged in with the key in my lap and watched it for a good 3 minutes waiting for it to display the Canbus information.
    Just did:
    ****** SCANNING *****
    With the stars narrowing and widening.
    Finally started the engine and it immediately reported 11-bit.
    It says that the fuel level sensor is not found... is this normal and it only goes by the injector data?
  12. Apr 18, 2012 at 8:38 PM
    #72
    iroh
    michigander
    tonneau
    Lucky bugger. Mine is finicky!
    That's normal. Actually it's by MAF and not injectors. Even if it could see fuel level it wouldn't be accurate anyways (the only thing it would really use it for is auto tank fill).
    Holy balls they want $200 for my UG! Guess it's been made obsolete.
  13. Apr 18, 2012 at 8:41 PM
    #73
    Rich91710
    Rich
    Los Angeles
    08 Base
    Now, if I unplug this thing, it is going to lose or reset data?
    I was planning to install it this weekend, but needed the 40 numbers from the self test for the rebate, so right now it's plugged in, cord draped over the steering column and it's resting in the cubby under the AC controls.
  14. Apr 19, 2012 at 10:11 AM
    #74
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I got 20.5 mpg over the last 300 or so miles . This prior tank was filled with 93. I drove the truck how I wanted...when hitting a hill I got harder on the gas to get a downshift. Slow moving traffic??..passed 'em. That kind of thing. This was my best mileage.
    This week I'm using 93 again, and trying the use the Prius glide foot technique as much as possible...and also get back into reading ahead and coasting as much as possible.
    One doesn't need an ultragauge to monitor realtime mileage... if you can imagine a horizonatal bargraph that is at 100% efficiency when your coasting at a speed above 20mph with your foot off the gas, 50% efficiency with your foot about 1/8 of the pedal's travel, 25% with your pedal between 1/4 to 1/2 of travel, and 0% when its any further than that, then you have a pretty good visual on how those monitoring devices work. Basically if your foot is depressed, your pulling your mileage way down! If your coasting with your foot off the pedal, or gently gliding it, your boosting your mileage!
  15. Apr 19, 2012 at 10:59 AM
    #75
    squashroll
    NorthWest
    please expand :confused:
  16. Apr 19, 2012 at 11:03 AM
    #76
    worthywads
    He's saying the stick is better mpg with the 2.7l vs the automatic. EPA says so and that seems to be correct, even thought the automatic has a slight advantage with the OD gear the 4spd automatic must not be as efficient.
  17. Apr 19, 2012 at 1:00 PM
    #77
    squashroll
    NorthWest
    is it a significant difference?
  18. Apr 19, 2012 at 3:23 PM
    #78
    iroh
    michigander
    tonneau
    Mine doesn't. It saves everything, including gauge positions, calibrations, and alarm settings. Once I moved it from my Honda to a Toyota 1MZ to do some code checking and when I put it back, lo and behold, my averages were trashed, but everything else was intact.
    If you were comparing with someone who knows how to drive stick for mpg, yeah I bet it is. Also anything in town sucks when it comes to autos (fluid pump drag, torque converter drag at stoplights, etc).
  19. Apr 19, 2012 at 3:28 PM
    #79
    squashroll
    NorthWest
    Damnit, people have been telling me the auto is just as good in the 05-current for the 2.7L. I sure do hate pumping a clutch in town...
  20. Apr 19, 2012 at 3:43 PM
    #80
    iroh
    michigander
    tonneau
    I seriously doubt it's as big a difference mileage-wise as between the V6s. Maybe none of the stick shift driver doesn't know what DWL is. If ya hate pumping the clutch, get the auto. It's a 4 speed and kinda slow compared to the 5 speed manual but it gets the job done. Actually EPA mileage on the auto is 1 mpg higher than the manual (I checked reg cab 4x4) for what it's worth.
    I just always seem to default to the stick shift no matter what so I may be a little biased.
