Mods to increase fuel efficiency?
Discussion in '1st Gen. Tacomas (1995-2004)' started by S-Type1, Aug 13, 2018.
  1. Aug 13, 2018 at 9:52 AM
    S-Type1
    S-Type1 [OP] Active Member
    Mark
    2004 Toyota Tacoma Xtra Cab RWD 2.4L
    This might sound boring, but are there any mods that will increase fuel efficiency? I’m running the 2.4L
  2. Aug 13, 2018 at 1:10 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Not really. Otherwise the dealer would have done them. Run 35 PSI in tires front and rear.
    Stock air intake is best. Not K& N.
    mattrussmill and BikerinBlak909 like this.
  3. Aug 13, 2018 at 1:11 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    A good tune up to make sure it's running 100% is about all you can do. Nothing else will really make enough of a different to make it worth the money
  4. Aug 13, 2018 at 1:12 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    old spark plugs, old air filter, dirty MAF, dirty throttle body will all cause progressive losses in MPG as they age and get worn/dirty. I would start here. I agree that tire pressure also plays a big role. However, if you want even treadwear then you may have to deal with that aspect. Removing weight will also help MPG. Finally, if you really have a lot of miles on your truck, replacing the fuel/air sensor may net you an MPG gain. A new PCV valve may also be in order, but not sure it has any effect on MPGs. The easiest way to save on MPGs is to use the AC sparingly.
    mateo_roberto likes this.
  5. Aug 13, 2018 at 2:02 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Get rid of any unnecessary weight as well, extra tools and stuff you have in the bed can add up
  6. Aug 13, 2018 at 2:04 PM
    taco21122
    taco21122 Taco2.7
    North Carolina
    2002 tacoma DC Prerunner 2.7l
    5% tint 32” LED bar New DEPO headlights Pioneer radio Kicker speakers Bilstein 5100’s 20x10 fuel turbos 295/55/20 toyo rts
    Tire pressure :thumbsup:
  7. Aug 13, 2018 at 2:42 PM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Depending on when your upstream o2 sensor was changed last, it might have a positive impact. Mine was the original with only 109k on it, but it was also 23 years old. Saw about 2-3mpg increase all around.
  8. Aug 13, 2018 at 3:13 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    The most effective thing you can do for your truck's mpgs is get a daily driver. My truck and my motorcycle combined get 35mpg.
    I would caution against a motorcycle though. They're not for everyone and a car is going to be safer.
  9. Aug 13, 2018 at 4:01 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    The more you know
    otis24[QUOTED] likes this.
  10. Aug 13, 2018 at 4:08 PM
    otis24
    Mark
    California
    Someone posted on another thread about trying to keep your RPM’s below 2K. I saw this about 3-4 weeks ago and have been giving it a go. It’s improved my mpgs from about 15.5 to as much as 17.
    My biggest problem for my fuel economy is how much stuff lives in my truck and all the armor etc it carries around.
  11. Aug 13, 2018 at 4:15 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Slow down. Get smaller tires.
    BikerinBlak909, ThunderOne and otis24 like this.
  12. Aug 13, 2018 at 4:16 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    A topper or tonneau cover helps gain around 1mpg, less air resistance as well as improved ride quality at high speeds
  13. Aug 13, 2018 at 4:20 PM
    jowybyo
    Joe
    Baltimore, MD
    In my experience the tonneau cover was about neutral on fuel economy. Topper cost me about 1 mpg.
  14. Aug 13, 2018 at 4:33 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    studies have shown that an open bed sans tailgate gets the best MPG. albeit by 1-2 mpg "at most" depending on other factors
    Luv my yota likes this.
  15. Aug 13, 2018 at 4:38 PM
    jowybyo
    Joe
    Baltimore, MD
    Yea. An aeroshell is the best option but as far as I know they are all custom jobs.
  16. Aug 13, 2018 at 4:45 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    This will not always increase mpg, lugging around outside of the power band can sometimes actually hurt economy because the engine is working harder than if it was up into the actual power band.
  17. Aug 13, 2018 at 4:52 PM
    jowybyo
    Joe
    Baltimore, MD
    The power band is where the motor makes the most power. Engines make power by burning fuel. If you’re making more power then you’re burning more fuel. Power required from the engine is proportional to the velocity cubed. To all but the most extreme extent, lagging the motor does save fuel. That’s why most automatics shift to top gear quickly and refuse to downshift unless you floor the gas pedal. Toyota’s seem to all have this “feature”.
    VenomDriven likes this.
  18. Aug 13, 2018 at 4:53 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I've read that removing the tailgate can actually decrease fuel economy.
    Just googled it- Mythbusters actually tested two of the same truck, side by side. Tailgate up won.
    Keeping the speed down is the biggest thing I've found. I drive a '15 TRD OR DCSB, loaded with tools, and a giant Yakima skybox on top. I'm getting about 20 mpg in combined city/hwy driving, just by keeping it below 70 MPH. I imagine a 4 cylinder could do much better.
    frizzman[QUOTED] likes this.
  19. Aug 13, 2018 at 6:03 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I stand corrected, thought it was "removed" that was better
  20. Aug 13, 2018 at 6:23 PM
    Thatbassguy
    James
    This could also vary from one truck to another, or depending on cruising speed. Just thought it was interesting.
    Another thing for the OP to consider is building an aero shell. Not sure if I have the right terminology there. There's probably a thread on here about them. Kinda ugly (IMO), but I've ready about some significant gains in fuel economy. I actually thought about building one for longer road trips.
    Sure, I could drive my Scion to Florida and get 30 mpg, but then I wouldn't get to take pictures of my Tacoma on the beach:cool:
