Mods to run 285s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBlood9, Jun 10, 2011.
  1. Jun 10, 2011 at 6:22 PM
    JBlood9
    JBlood9 [OP] Well-Known Member
    Jordan
    Baton Rouge
    Black 08 SR5 PreRunner
    Pesonal LSU plate. Flowmaster 40 Series BFG A/T KOs on TRD rims AFE Cold Air Intake (Pro Dry S) Weather Tech Digi Fits Sportsman Camo Shadowgrass custom seat covers. Custom Trailer Hitch receiver flag pole. Front and back matched tint. AVS rain guards. Pioneer CDE 123 head-unit. Derped Rims and Rear Bumper. Yellow Badges.
    I was going to stick with 265s to keep my cost of lifts, tires, etc down, but after looking and thinking about it more i'm leaning to get a 2"AAL and Billie 5100s at 2.5 up front. Would I have enough room to run 285s with this? TIA
  2. Jun 10, 2011 at 8:00 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    If you want some more lift out of the front set your billies at 0 and put 885 coils up on.
  3. Jun 10, 2011 at 8:00 PM
    JeenyusSB
    JeenyusSB Well-Known Member
    Same setup. All I did was trim a small amount.
    lynyrd3 likes this.
  4. Jun 10, 2011 at 8:05 PM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    Two things that come to my mind are:
    1) make sure the offset/backspacing/rim width of your wheels will be compatible with your setup -- some wheels can cause more rubbing issues than others
    2) you may end up needing new UCA's, again depending on your wheels, and depending on whether or not your alignment shop can get your caster in spec with the stock UCA's. I had problems getting my caster in spec with just 1.75" of front lift.
  5. Jun 10, 2011 at 10:45 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Exactly what they said ^^
  6. Jun 10, 2011 at 11:22 PM
    larry2375
    larry2375 Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    Just switched from 265/70 to 285/70 tires. I even have both front mud flaps on. Kinda had to modify the mud flaps a little. It keeps debris from scratching the sides of the truck
  7. Jun 11, 2011 at 9:47 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i see a cab mount chop coming soon also, i had some major trimming even after removing mud flaps. 7089 pro comps 17 x 9 with 285 70 17 km2's. i am lifted at 3" in the front. i am not sure of back spacing as i these were bought off craigslist.
  8. Jun 11, 2011 at 11:23 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    That's a great looking truck.
  9. Jun 11, 2011 at 12:38 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Just reading through different posts on forums about running 35's, and the information obviously applies to tires smaller than that but bigger than stock. It appears to me that where most folks go wrong on fitting larger tires is with their rims. They run rims that are two wide with too little backspacing. You will notice on many posts people say I run tire size X with no rub, then you have someone else pipe up no way cuz I have that size tire and it rubs like crazy. But rarely do people talk about their rims. I think if you are running larger tires and you have less than 4.5'' backspacing you are going to be contending with more issues than if you had run at least 4.5''. I'm not saying that is perfect for every application just making an observation based on many threads and posts regarding fitting larger tires.
  10. Jun 11, 2011 at 12:58 PM
    Frankie_G
    Frankie_G Well-Known Member
    Frankie
    West Seattle, Wa
  11. Jun 11, 2011 at 8:44 PM
    JBlood9
    Jordan
    Baton Rouge
    Thats set up looks bad ass. I'd be very happy with that look!
    But anyway, I appreciate all the input info. I'm sketchy on trimming out and a mount chop. I may just have to stick with 265s for a while if that is the case. I just dont want it to look dumb picked up and small tires.
    Also, I was wondering about why some said that they will run with minor trimming and some guys respond with a total different take on it. Rims and backspacing are a great point. What would be the optimal rim sizing then to run the 285s with minor if any trimming?
    Thanks again.
  12. Jun 11, 2011 at 11:45 PM
    RichardTRD
    RichardTRD Well-Known Member
    Richard
    Oregon City Oregon
    2011 Tacoma TRD OFF ROAD 4X4
    285's on 17x9's with -6mm offset. Some trimming was needed around the inner fenders, had to removed the front mud flaps for sure. I have no contact with any parts of the frame or mounts. ​
