Moisture on passenger side floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ackxix, Apr 25, 2017.
  1. Apr 25, 2017 at 12:31 PM
    Ackxix
    Ackxix [OP] Member
    Allen
    2011 tacoma TRD V6 quad cab
    None
    Can anyone give an idea why I continue to get moisture on passenger side floor? It's under the Mat right beside the tranny tunnel. Is there a penetration in the floor or transmission tunnel right in that area that could be allowing water in? I.e. wire entry, rubber seal plug etc.
    Thanks
  2. Apr 25, 2017 at 12:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    AC drain is clogged and the case is spilling condensate into the floor.
    Heater core is leaking.
    A hole has rusted through the floor.
    Your kid spilled his Mickey D poision juice there.
    My bet it's one of those. Not all.
  3. Apr 25, 2017 at 12:35 PM
    RBTaco
    RBTaco Well-Known Member
    2013 RC 4X4
    Trac rac, tow hitch, fog lights, tonneau cover, Texas Edition rims, custom console, weathertech floor mats.
    I would probably check your windshield seal. I was getting water pouring down after a crappy windshield install and the water was dumping down on my cabin filter and in that entire area.
  4. Apr 25, 2017 at 12:36 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    You underestimate
    GPsevinSixx likes this.
  5. Apr 25, 2017 at 12:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    So I should be a contractor or a mechanic? :D
  6. Apr 25, 2017 at 12:38 PM
    inwood customs
    Dave
    Def not engineer, you didnt take 100 pages to diagnose
  7. Apr 25, 2017 at 12:41 PM
    Ackxix
    Ackxix [OP] Member
    Allen
    None
    Only happens when it rains and is always in a specific area. No sign of it coming from above I.e. windshield. So my guess is coming up from floor.
  8. Apr 25, 2017 at 12:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    I managed engineers a few years. Hardest thing was to
    a) get them to produce reports I needed
    b) get said reports in salient terms of brevity, as opposed to waxing on with what if's
    c) having anything with more than 2 syllables that was not a technical term spelled correctly.
    But seriously. The best engineers I ever worked with were ones who fixed their own cars, maintained their own houses and other 'practical' matters. The textbook kids struggled too much in the world we worked in. Not everyone gets to be theoretical.
  9. Apr 25, 2017 at 12:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    It can still be the AC drain line. Cowl can leak into the evap box and if the drain is clogged have nowhere to go.
    From the floor should be easy to find. Crawl under the truck and look.
    Better yet, pull the carpet back and look. You probably need to get the funk that's forming under there sanitized, regardless of the source.
  10. Apr 25, 2017 at 12:47 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I would recommend using a tissue next time.
  11. Apr 25, 2017 at 12:56 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Probably because of the slimy beavers that your sick truck causes.
  12. Apr 25, 2017 at 3:54 PM
    Ackxix
    Ackxix [OP] Member
    Allen
    None
    Will take a look at all possibilities mentioned.
    Many thanks.
  13. Apr 25, 2017 at 4:00 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    I had the issue during rain and car wash. Toyota changed the cowl under warranty for a new version they made which corrected the issue. Mines a 2011 also.
  14. Apr 25, 2017 at 4:17 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    What drivesector said. I remember around the time I joined there were some threads or I found some threads where people were having your issue. It was getting in through a cowl over the fresh air intake for the hvac system and collecting there on passenger floor. If you do some tatgeted searching you might find those threads or posts.
  15. Apr 29, 2017 at 9:28 AM
    Ackxix
    Ackxix [OP] Member
    Allen
    None
    Ok, pulled and snaked a/c condensate hose, no blockage. Collecting moisture rain or shine is this leading up to the heater core issue? And why in a 2011 should the core be blown? Any thoughts?
    Thanks
  16. Apr 29, 2017 at 9:42 AM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    If it is the heater core, I expect you would smell antifreeze.
  17. Apr 29, 2017 at 9:45 AM
    Ackxix
    Ackxix [OP] Member
    Allen
    None
    No smell of antifreeze, carpet smells icky from what ever is creating it. Other thoughts?
