Moisture smell with A/C
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kolby, Jun 14, 2021.
  1. Jun 14, 2021 at 8:41 PM
    Kolby
    Kolby [OP] Active Member
    Kolby
    2015 v6 Tacoma 4WD Sport
    So I have a 2015 tacoma and whenever I turn on or off my A/C is smells went, not bad per say, just wet. The A/C gets down to about 48 degrees when the outside air is about 90. Is this 'normal' or is it something of concern? What needs to be repaired/ fixed if anything? Thanks in advance!
  2. Jun 14, 2021 at 8:50 PM
    Wannabe4x
    Wannabe4x Well-Known Member
    Conner
    EastCounty, SanDiego
    2nd gen TRD PreRunner
    Spindle lift, 285/70/17s, Methods
    Just got my AC diagnosed since it’s been clicking off intermittently.. that temp considering ambient air seems to be right around where mine is (normal I believe). My truck had that smell too but went away after I got a new cabin air filter. Where do you live? Humid climate areas I’m sure don’t help that musty smell
  3. Jun 14, 2021 at 9:02 PM
    Kolby
    Kolby
    I live in upstate NY and this happens anytime I use the A/C it could be 10 below or 100° it's smells funny. It's a carbon filter but I changes it about 15k miles /1 year ago. I'll see if it smells in the morning. Is that about how cold the AC gets? Or does it need a recharge?
  4. Jun 14, 2021 at 9:06 PM
    Wannabe4x
    Conner
    I got mine looked at not too long ago, I live in SoCal and it always about 80* out.. pretty positive the thermometer read around 40* which was up to par. If I were you I’d swing it by a shop to do a pressure check, they might even do it for free since it only takes seconds really.
  5. Jun 14, 2021 at 9:15 PM
    Kolby
    Kolby
    Thats what I was thinking of doing, im glad im not the only one haha, the smell doesn't bother me I know it bothers others. I sprayed a crap on of lysol in the air intake in the cowl and that just covered the smell didn't fix it so I suspected it had something to do with the A/C system.
  6. Jun 14, 2021 at 9:26 PM
    Waasheem
    Waasheem
    2007 xrunner
    Here’s my theory and solution. Moisture or condensation accumulates in the ducts when the ac is on. If you turn the engine off while the ac is still on, and has been on for some time, that moisture stays in there and can get moldy. So a couple minutes before I get to where I’m going, I turn the ac off and leave the fan blowing. Before I shut off the engine, I set the vents recirculating off so they’re open to outside air. All that helps evaporate the moisture in the ducts. Perhaps it’s my imagination, but it seems like the putrid smell isn’t there anymore. I’m no ac expert but it seems to work.
    BlkDakDave, Jimmyh and barf like this.
  7. Jun 14, 2021 at 9:41 PM
    Kolby
    Kolby
    I heard about this a few months ago and it helps ever so slightly but not all that noticeable, I live close to a highway that im often on for work and I try to turn off the A/C while still at highway speeds to really dry it out. It smells in the winter too when I defrost/ defog my windshield.
  8. Jun 14, 2021 at 9:45 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    I notice the stank goes away when I do this as well.
  9. Jun 14, 2021 at 9:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I do this too. It does work.
    Toyota uses this:
    https://www.amazon.com/GENUINE-APPROVED-SERVICERITE-EVAPORATOR-00053-00008/dp/B07D3B5JTZ
  10. Jun 15, 2021 at 3:44 AM
    cousincraig
    cousincraig Well-Known Member
    Craig
    2010 tacoma
    Change cabin air filter, fixed the problem for me. Mine used to smell musty and even shot water out at times
  11. Jun 15, 2021 at 6:38 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    This^
  12. Jun 15, 2021 at 6:46 AM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    Flip to "fresh air" when driving.
    Default is "recirculating" aka "Max cold air" but I only use that when I am behind a diesel (any particulate and I start coughing).
    Flip to fresh air to help prevent mold. That and change the cabin filter once a year. (Super easy, also good to clean out the glove box annually).
  13. Jun 15, 2021 at 7:58 AM
    Kolby
    Kolby
  14. Jun 15, 2021 at 9:39 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Yes. I did it to my truck and my cousin's Sienna and T100 along with changing cabin filters in the truck and van (non in the T100) and it made a noticeable difference.
    ETA- SAVE THE HOSE NOZZLE! You can use it on the less expensive cans of A/C cleaner from Lowe's, Home Depot, etc.
    Jimmyh likes this.
  15. Jun 15, 2021 at 9:45 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Confirmed - buy the cleaning kit and run it through the system and change your cabin air filter. The air recirculation automatically sets to internal recirc any time the truck is backing up. Quite often it will stay in that mode. Although it cools better by recirculating the cooler air in the truck, it does cause moisture buildup.
    1. Verify your drain is clear and working - The AC refresh it will clean out any of the nasties.
    2. On days you are running the AC, turn off the AC and run it with fresh air for about a minute before shutting down the vehicle. This will help reduce any condensation at the coil.
  16. Jun 15, 2021 at 9:58 AM
    SYTFUxMBRProjects
    SYTFUxMBRProjects Instagram: b00sted_b18c5
    Mark
    San Leandro
    2006 Super White Tacoma TRD-Sport Supercharged
    This is also suggested by Toyota: T-SB-0142-13 HVAC Odor Maintenance.
    Jimmyh likes this.
  17. Jun 15, 2021 at 2:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes, see the note above post # 14
