Moisture under mats
Discussion in 'Detailing' started by Airwreck, Feb 17, 2012.
  1. Feb 17, 2012 at 12:55 PM
    Airwreck
    Airwreck [OP] Member
    Tacoma
    I just bought a brand new Tacoma Access cab. Yes, it has been raining lately, but still, one should not find dampness under the floor mats in a brand new vehicle.
    Has anyone else noticed this??
  2. Feb 23, 2012 at 5:45 AM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Is it under both front mats? Is the carpet really wet? If so I had the same problem with mine. Took it to the dealer and they found that the rubber seal on the back window was not installed right from the factory. Instead of the water staying outside of the truck, it was running down the rear of the cab and then running down the floor to the front floor mats. Carpet was all mildew underneath, so they replaced the entire carpet and install a new rear window seal. No problems since.
  3. Feb 23, 2012 at 6:01 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Some used to have issues with it getting in the fresh air thing in the cowl.
  4. Feb 23, 2012 at 6:01 AM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    ^ This. Could be the gaskets around the door too. I've seen this on my F250. It was also mentioned in another thread that your evaporator may be clogged. Not sure about that just bringing it up because someone mentioned it in relationship to damp carpets in these trucks. Hope you isolate the cause.
  5. Feb 23, 2012 at 8:58 AM
    BamaToy1997
    Bill
    Navarre, FL
    Lots of correct input so far. Look at your rear window seal, door seals, windshield seal, and check to make sure your AC drain (located on your firewall, near the passenger's side) is not clogged. One thing to look at also is that your fresh air intake drain is not clogged. Your fresh air intake area is the cowling at the bottom of your windshield. That vent looking thing is the inlet. There are two drains, one on each side of the truck, to drain off the water. If they are clogged, then rain builds up and eventually comes into your interior.
    The best way to check for sure is look in the back floor area. Is it wet? Then you have a high chance(but not 100%) that you have back-glass problems. Is only the front wet on the passenger's side? High chance the AC evap drain is clogged, fresh air intake is clogged, or a windshield seal is leaking. Look underneath the dash area on the passenger's and driver's side. See how far up it is wet. If it is only wet low, then most likely it is a AC drain clog. Higher up chances are greater that your windshield or fresh air vet drains are the problem. Let us know what you find.
  6. Feb 23, 2012 at 9:38 AM
    Madjik_Man
    Colorado Front Range
  7. Feb 23, 2012 at 10:35 AM
    BamaToy1997
    Bill
    Navarre, FL
    Whatever it is, it isn't normal. A 2012 should be under warranty, so just take it back to the dealer and ask them to investigate.
