Moles
Discussion in 'Off-Topic Discussion' started by nd, Apr 21, 2011.
  1. Apr 21, 2011 at 5:02 PM
    #81
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Molarity x Liters
  2. Apr 21, 2011 at 7:01 PM
    #82
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Soooooo............ I've never seen Caddy Shack, thats probably before my time eh?
  3. Apr 21, 2011 at 7:08 PM
    #83
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    10-4 Rubber Ducky
  4. Apr 21, 2011 at 7:31 PM
    #84
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Dammit! Now i HAVE to get off my ass and go watch it....
  5. Apr 21, 2011 at 7:38 PM
    #85
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    supposedly moles love juicy fruit...so if you can figure out how to bait traps with that...you should get rid of them temporarily
    go after the grubs though for a long term solution
  6. Apr 21, 2011 at 7:41 PM
    #86
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I am pretty sure this is the only guaranteed way to not have to deal with them.
    If you have females, which it sounds like you do if you have seen babies, they rarely (if ever) move.
    I had one in my yard several years ago.. I researched like crazy to figure a way to get rid of it. Nothing I did helped. Believe me, I was obsessed with getting rid of that thing. I tried every suggestion anyone gave me (traps, smoke bombs, hose, firecrackers, poison, some kind of bobcat urine that you spray, owl statue, stakes you put in the ground that send out shockwaves, you name it) nothing helped. Luckily it was a male and moved on. I really hope you find a way to get rid of them, but I was unsuccessful.
    Good luck!
  7. Apr 21, 2011 at 9:58 PM
    #87
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    juicy fruit gum does work, not just any gum, juicy fruit, works better on woodchucks though
    try castor oil or castor pellets to repel them , it works
  8. Apr 21, 2011 at 10:00 PM
    #88
    fsbrain03
    fsbrain03 Well-Known Member
    Plasti dip those little suckers!
  9. Apr 22, 2011 at 7:05 AM
    #89
    nd
    nd [OP] Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    do you like bill murray and chevy chase? if so you haven't seen their best work until you've seen this. i dont usually like older comedies (i hate 70's and 80's production value, it makes things hard to watch sometimes) but caddyshack is timeless (except for the super short shorts on the guys. i cant believe that was every acceptable)
  10. Apr 22, 2011 at 7:11 AM
    #90
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Tunnel rats and a 45. Works most of the time!!
  11. Apr 22, 2011 at 7:22 AM
    #91
    DSMissed
    DSMissed Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    I'm not sure if this is legal, or if you can even get ahold of this stuff cause you need a pesticide license for it, but for prairie dogs we use these poison pellets that when the ground is moist, it releases some nasty chemicals that kill them. Do every hole one time, and guarantee your underground death toll will be insane.
    As far as a controlled burn, it doesn't work as well as you would think, there are too many air pockets underground. We've had fires go over P dog towns, and it never phased them.
  12. Apr 22, 2011 at 7:34 AM
    #92
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    On the farm that I grew up on (20 acres of cattle and hay pastures) we used sulfur chips and a propane torch to kill gophers and moles. You can buy farm grade sulfur at a farm supply store (Ag West out in Oregon). We would dig out the hole a little bit, enough to make a nice pocket that led directly into the tunnel network. Then place 1 to 2 cups of sulfur chips into your pocket and burn it with the propane torch. The sulfur burns and emits a toxic gas that fills the tunnel network.
    We found this to be the cheapest and most effective method. Sulfur stores easily, and propane is usually readily available and cheap. We only had to do this once to twice a year because it killed everything in the tunnel networks. The key is making sure that you get to every tunnel network the day that you do it. Leave some behind and they will re-populate your problem.
  13. Apr 22, 2011 at 7:37 AM
    #93
    nd
    Nate
    Greenville, SC
    for all of you who have given advice but i haven't singled out, thanks again for your input. i'm not trying to ignore you but i got way more responses than i was expecting :)
  14. Apr 22, 2011 at 7:40 AM
    #94
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Said Toxic gas is called Hydrogen Sulphide (H2S) and Sulphure Dioxide (SO2). Both of which are actually lethal to humans in very low doses. I work in industry where these are prevailent and have seen people go down. From a shear safety standpoint, i'd say don't do it. Or be smart enough to know wind direction and hold your breath.
    Those points aside, since your burning it, hot gas rises, so it would more likely rise out of the hole then anything anyways.
  15. Apr 22, 2011 at 7:44 AM
    #95
    nd
    Nate
    Greenville, SC
    dont you tell me what to do. i'm gonna inhale that shit on purpose just to teach you a lesson. you'll be sorry you ever told me what to do
  16. Apr 22, 2011 at 7:47 AM
    #96
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    PM me your password before your do, then everyone will think your reaking online havoc from beyond the grave :D
  17. Apr 22, 2011 at 7:49 AM
    #97
    nd
    Nate
    Greenville, SC
    i like the way you think
  18. Apr 22, 2011 at 7:50 AM
    #98
    Hunter.V.White
    Hunter
    Fairbanks, AK
    It is a bit "harsh" if you breath it in :) but we did hold our breath when we could to prevent it. We got it to travel into the hole by digging a pocket that was level in depth, or just a bit lower than the tunnel network (usually 12 - 14"). We then used the "thrust" from the propane torch - a two handed torch attached to a BBQ tank - to push the gas into the tunnels. If you run the torch for a few minutes, the sulfur has no where else to go but into the tunnels; it usually wouldn't float up to where the operator could breath it in. If it does, then you are probably doing it wrong (wrong angle of the torch, the more level the better). Also, speaking from a basic chemistry knowledge (help me out here), wouldn't the small amount of SO2 that escaped the thrust of the torch diffuse by the time it reached 5 ft about ground level (or possibly 6 ft to the operator)?
    Speaking from experience, we never got more than a bad cough or two if we breathed it in, and it rarely happened. If you start to cough, move, or turn the torch off.
  19. Apr 22, 2011 at 7:52 AM
    #99
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    If i die and no one uses my name to haunt people, i'll be quite offended
  20. Apr 22, 2011 at 7:53 AM
    #100
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When you die, or disapear from the site, your name will be given to a "New guy" who will be known as Marcell teh gay.
