Moli Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SedonaTRD, Nov 14, 2024.
  1. Nov 14, 2024 at 2:49 PM
    SedonaTRD
    SedonaTRD [OP] Member
    2012 Tacoma TRD 4x4
    None
    Does anyone out there run Moli oil in their high mileage Taco??
  2. Nov 14, 2024 at 2:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Interested to know.
    b_r_o and spitdog like this.
  3. Nov 14, 2024 at 3:09 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    You should run Valvoline Restore and Protect. The stuff is amazing at cleaning out the oil control rings on higher mileage engines.
  4. Nov 14, 2024 at 4:14 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I put in a small bottle of the moly additive @ 150K.
    Interestingly;
    "moly" (molybdenum disulfide, MoS2) would have been considered a good additive for engines in World War 2, particularly in aircraft, as it provided emergency running capabilities even if the engine lost oil due to damage, allowing pilots to make emergency landings; this property was recognized and utilized by military forces during the war.
    moly in WWII:
    • Function:
      When added to engine oil, moly forms a solid lubricant film on metal surfaces, which helps prevent excessive wear and allows the engine to run for a limited time even with significantly reduced oil levels.
    • Military application:
      Pilots in World War II sometimes added moly to their aircraft engines to ensure they could land safely if their oil tank was hit during combat.
    • Post-war development:
      The company "Liqui Moly" was founded based on the concept of using liquid molybdenum disulfide as an engine oil additive, and its origins are linked to the use of moly by the US military during and after World War II.
    We won that one by the way.
    Steves104x4 likes this.
  5. Nov 14, 2024 at 10:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Hang tight they'll be along shortly
    ridefreak and kidthatsirish like this.
  6. Nov 15, 2024 at 2:13 PM
    TacoTuesday1
    FL
    I have moly oil free from work.
    Put it in don’t really care don’t really notice a difference
    if I get free oil I put it in
    If it’s not free I go buy some affordable decent oil with or without moly. And I put it in.
    2024OffRoad likes this.
