MOLLE Panel (Behind Rear Seat)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by N minus 1, Dec 13, 2021.
  1. Dec 13, 2021 at 12:52 PM
    N minus 1
    N minus 1 [OP] Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    Just received a new batch, with powder coating now!
    For details check out:
    https://www.tacomaworld.com/threads/behind-rear-seat-molle-panels.746918/
    Hello!
    FITS: 2005+ Double cab and Access cab Tacomas
    Note: For 3rd gen Tacomas with the power rear window please specify when ordering. Does NOT fit with factory subwoofer.
    Some pre 2015 Access Cab panels require minor trimming to the plastic rear cab vent.
    MATERIAL: Aluminum
    FINISH: satin black Powder coat
    *Only available in black powder coating at this time
    WEIGHT: 12 lbs
    All mounting hardware included (access cab reuses upper 4 mounting bolts)
    PRICE: $325 + shipping
    Payment via PayPal through tacomaworld PM or credit card, apple pay and Google pay at
    www.ruffroaddesigns.com
    Local pickup to Santa Ana CA ($300)
    PM me for deliveries to Hawaii, Alaska or outside the US.
    Powder coated 2nd DC
    Powder coated 3rd gen power window
    Powder coated Access Cab
    Painted and Installed in a 3rd gen
    (no power window)
    Raw aluminum
    (With power window cut out)
    Painted and Installed in a 2nd gen
    Custom made shipping boxes to ensure the panels arrive damage free
    FAQ
    What if I have a factory subwoofer?
    I haven't had a truck with a factory subwoofer to measure yet so you will have to cut a hole to accommodate your subwoofer. An angle grinder with a cutting wheel easily cuts the aluminum.
    Do you make a panel for a single cab?
    Not yet but it is in the works
    How do I paint my panel?
    1: Sand it with 220-320 grit sandpaper
    2: Thoroughly clean the panel
    (Acetone works well)
    3: Spray 2 light coats of aluminum
    primer. Let dry
    4: Lightly wet sand any imperfections
    with a fine scotch brite pad or very
    fine sand paper (500+grit)
    5: Spray 2-3 light top coat layers of your
    favorite color.
    What paint is recommended?
    I use Rust-oleum professional aluminum primer and a Rust-oleum professional high performance enamel top coat.
    The enamel paint takes a long time to fully dry but seems to be more durable in the long term.
    Primer: https://www.rustoleum.com/en/product-catalog/consumer-brands/professional/aluminum-primer-spray
    Top Coat:
    https://www.rustoleum.com/product-catalog/consumer-brands/professional/high-performance-enamel-spray
    Slashaar likes this.
  2. Dec 13, 2021 at 12:54 PM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    is it just me, or are the pics not loading?
    N minus 1[OP] likes this.
  3. Dec 13, 2021 at 12:56 PM
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    Pics are not loading, but i'm interested!
  4. Dec 13, 2021 at 12:57 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    Hmm let me reload pics...please hold
  5. Dec 13, 2021 at 12:57 PM
    LongDistanceTaco
    Geoff
    California
    Loading now. I'll shoot you a PM
    N minus 1[QUOTED][OP] likes this.
  6. Dec 13, 2021 at 12:58 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  7. Dec 13, 2021 at 12:59 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    They loaded for me so I shared them
  8. Dec 13, 2021 at 1:46 PM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
  9. Dec 13, 2021 at 7:23 PM
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    I don't have his, but I have one from Nate and it's awesome. Don't think nate is still offering them. But it adds a good amount of space back to behind the seat to give you an idea a 50 cal ammo can will fit behind the seat now. The half sized ammo cans will clearly fit as well. You have to profile your set up right for the backs of the seats to click in but I have my fishing rod up near the top of the seats and it's fine wider stuff like my ammo cans and sleep pad down low.
  10. Dec 13, 2021 at 7:28 PM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    This is from when I took it out to change the flooring out to the all weather flooring by toyota. Could probably use a new coat of paint to be honest but being behind the seats I always forget about repainting it.
  11. Jan 8, 2022 at 7:48 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
  12. Jan 25, 2022 at 6:05 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
  13. Jan 25, 2022 at 7:36 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Anything for a 2011 access cab ?
  14. Jan 25, 2022 at 7:42 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    I just submitted an order for the 1st production run of access cab panels. Current ETA is 3-4 weeks.
    I can add you to the list of you'd like, there is a group buy page
  15. Jan 25, 2022 at 8:00 PM
    killerkeener
    2011 trd 4x4 manual
    None yet
    I have deleted my rear seats and would love to Rio the back plastic panels and bolt in a molley panel or millwakke packout panel do you cut packout panels ?
  16. Jan 25, 2022 at 8:33 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    I dont have a design modelled for the milwaukee pack out panel but what I've done in the past is either bolted stuff to the regular MOLLE panel or done 1/2 molle and 1/2 solid metal which allows custom hole locations to mount whatever
    killerkeener[QUOTED] likes this.
  17. Jan 30, 2022 at 8:12 AM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    Bump for only 1 left!
  18. Mar 12, 2022 at 2:50 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
  19. Mar 20, 2022 at 8:46 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    Sunday bump :bananadance:
  20. Jun 1, 2022 at 7:16 AM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
