Molle panels that will work with Bakflip Tonneau
Discussion in '4th Gen. Tacomas (2024+)' started by DarthTaco_, Jan 13, 2025.
  1. Jan 13, 2025 at 9:38 AM
    DarthTaco_
    DarthTaco_ [OP] Member
    Paul
    2024 TRD Sport
    Rough Country support says that the RC molle panels are not compatible with the Bakflip Tonneau cover. Anyone have suggestions of molle panels that will work in a 2024 Tacoma with a Bakflip tonneau?
    Appreciate it.
  2. Jan 13, 2025 at 10:38 AM
    Taco001
    Taco001 Well-Known Member
    24 OR
    You might check SXTH Element. I dont know if will work or not but maybe you can check.
  3. Jan 13, 2025 at 6:29 PM
    Lutznutz
    Lutznutz Member
    Plant City, FL
    2024 Tacoma Limited 4x4 Underground Grey
    I have the RC panels. I used blind nuts for the top mounting points, pointing the Z brackets upside down from what RC has when you install them under the bed rail. Installed the Z brackets into the same mounting holes on the panels. Basically, I installed the tops just like you would the bottom bracket.s
    I also had to trim off the finger on the driver side panel to fit around the bed power/USB door correctly.
    I csn get you some pics tomorrow if you want to see.
  4. Jan 13, 2025 at 6:42 PM
    DarthTaco_
    Paul
    2024 TRD Sport
    Wow, thanks so much for this information. I would love some photos if you are able. I will be doing the same modifications you did.
    In the meantime I'll be studying up on what a blind nut is :)
  5. Jan 13, 2025 at 7:22 PM
    Lutznutz
    Lutznutz Member
    Plant City, FL
    They're useful for when you can only access one side of a panel, like a truck bed. you drill a hole, tap one in, and use a tool to expand it so it expands and locks into the hole. Remove the tool, and you can insert a bolt.
  6. Jan 13, 2025 at 7:39 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    It would be more helpful to use the search term, rivet nut.
  7. Jan 13, 2025 at 8:20 PM
    snickers
    https://www.youtube.com/watch?v=K_jf9IwPyCE
    Not sure why RC would say their molle panels don't work with the Bakflip. RC's molle panels fit under the bed rail. Bakflip mounts on top. So there doesn't seem to be a conflict there. I would say the drain tubes can be routed over the front molle panel.
    Now molle panels that mount on top of the bed rail, like Caliraised, might clash for space on top of the bed rail.
    As well, Rago Fabrication and Toyota both have molle panels that mount behind the bed rail.
  8. Jan 14, 2025 at 6:29 AM
    Lutznutz
    Lutznutz Member
    Plant City, FL
    in my experience, mounting the brackets behind the rail made the space between the rails too narrow, and the Bakflip wouldn't drop and snap in.
  9. Jan 14, 2025 at 6:30 AM
    Lutznutz
    Lutznutz Member
    Plant City, FL
    they're known by a lot of names. Why you didn't chastise me for not calling them half-blind, since they aren't fully blind.
  10. Jan 14, 2025 at 7:40 AM
    snickers
    None intended. They are commonly sold as rivet nuts in the US. The intention was to help the OP, not bruise any egos.
    dneal likes this.
  11. Jan 14, 2025 at 12:55 PM
    Henry K
    Henry K New Member
    Henry K
    4th Gen i Force Max
    Hi,
    New here, but I can assist on the Molle panel issue. The tonneau attachment brackets provided when installed by Toyota cause the bedrail to sit 1/4" out and 1/4" down from the original factory bedrail mounting location, so you loose clearance you would have otherwise. The Rago, Victory, and various Amazon provided versions all rely on the rail being positioned in the original position. Getting the factory tonneau cover makes it a DIY project to get the Molle panel systems to work.
  12. Jan 15, 2025 at 8:05 AM
    DarthTaco_
    Paul
    2024 TRD Sport
    Thanks! I purchased and installed the Bakflip Tonneau from Rough Country. I just assumed their molle panel would be compatible. But I was wrong :(
  13. Jan 15, 2025 at 8:09 AM
    DarthTaco_
    Paul
    2024 TRD Sport
    Thanks for the reply. I believe the RC molle panels aren't compatible with the RC Bakflip because the Bakflip clips/latches use the existing bedrails. If you mount the RC molle panel as designed, the mounting brackets sit behind the existing bedrails causing them to be in a different location. Then the RC Backflip panels don't latch when you close them.
  14. Jan 26, 2025 at 8:21 AM
    Lutznutz
    Lutznutz Member
    Plant City, FL
    here's some pics of how I got it installed. https://imgur.com/a/u3AV93g
