Molle pouch recommendations for Seat Jacket MMP panels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JTScribe52, Dec 20, 2022.
  1. Dec 20, 2022 at 9:25 AM
    JTScribe52
    JTScribe52 [OP] Well-Known Member
    Dan
    2018 SR5
    Did a search but my Google-fu must be weak. Some of the MMP panel reviews I’ve seen have said that the gaps are too small for snap-button attachments on surplus Molle bags. Is this accurate, and if so, can anyone recommend appropriately-sized storage pouches? Thanks!
  2. Dec 20, 2022 at 12:46 PM
    EasyDoesIt
    EasyDoesIt DesertDoesIt.com
    Las Vegas, NV
    2011 Dbl Cab TRD Offroad
    Icon C/O's
    Hey Dan,
    Some folks have found the bigger snaps wont feed through our slot pattern. If that is the case you can always strap around the panel. The honeycomb design is functional in the sense it should limit side to side movement of your straps.
    The slots are .26" tall so if your nylon strap snaps are under that you should be good. If they are taller then you can strap around the entire panel (1.5" at the low point of the honeycomb and 2" at the high part).
    I hope that helps,
    Desert Does It
