Monroe Quick Struts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco John, Mar 19, 2013.
  1. Mar 19, 2013 at 9:08 AM
    Taco John
    Taco John [OP] Well-Known Member
    Illinois
    4X4
    Does anyone have experience with these? I'm thinking about them to replace the 4600s I have that are shot after 50k miles. It is 99.9% on road use. They are cheaper than replacing the OEM shocks and all the associated hardware with the bonus of not having to disassemble everything. When I have done struts in the past, I have always replaced all the bearing mounts and associated hardware but not sure I really need to in a truck since it has upper control arms to carry the load.
  2. Mar 19, 2013 at 9:10 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I have to think your ride would suffer and they would wear out faster.... If you want quality, get Bilstein 5100's, if you care more about price, maybe the Monroes are what you want.
  3. Mar 19, 2013 at 10:18 AM
    Taco John
    Illinois
    4X4
    I can't say I was impressed with the life of the OEM Bilsteins so that is part of my hesitation to buy another set. I'm just over 50k of old man pavement driving. Over the last few weeks, it wants to dance all over the road on any less than perfect asphalt.
  4. Mar 19, 2013 at 10:58 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    5100's /= OEM replacement... 5100's are much better, everyone and their mother around here runs them.
  5. Mar 19, 2013 at 11:08 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I have first hand experience with the quick struts, I foolishly put a set on my 1st gen before trading it for my 09. They are cheaper than 5100's because they are cheap (not in a good way). It was my 2nd time installing struts, the first time I used spring compressors and bought all the separate parts so this time around I wanted to do it quicker.
    No good.
    I did everything I was supposed to, torqued everything down to the correct levels and made sure it was all perfect, but the first time I drove them something was clunking whenever I went over any large bump and especially when I was turning and went over a bump. I never did figure it out but from what I've read the QuickStruts often come untorqued or mistorqued so the center nut might be loose. I don't know if that's what was wrong with mine but even without the clunk I wasn't impressed with the feel and the ride.
    If you don't want to mess with a spring compressor you could buy the parts and pay a shop to assemble it, or if you can afford it you could buy new ones pre-assembled from wheelers offroad. Either way, I really don't think the monroe's are worth the money.
  6. Mar 19, 2013 at 11:11 AM
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    Switched to 5100's and can't say anything bad about them they are much improved over stock and Bilstein stands behind them.
    GENERAL AFTERMARKET WARRANTY DETAILS
    ThyssenKrupp Bilstein of America warrants its gas pressure shock absorbers against defects in workmanship and materials for as long as you, the original purchaser, own your car.
    If a shock/strut malfunctions and Bilstein determines it to be defective, we will either replace it or repair it depending on the term of the warranty based on the assembly's model type.
    Note: If your vehicle was equipped with Bilstein from the factory (original equipment), warranty claims must be directed to the vehicle manufacturer.
    WARRANTY DETAILS FOR TC (B4) / C / HD (B6) / Sport (B8) / BTS (B12) / PSS (B14) / PSS9 & PSS10 (B16) / 5100 (Application Specific) GAS PRESSURE SHOCKS
    LIMITED LIFETIME WARRANTY
    Bilstein warrants to the original retail purchaser that, for the life of each Gas Pressure Shock, this product shall be free from defects in material and workmanship. Proof of purchase is required process warranty. Please return product to the original place of purchase.
  7. Mar 20, 2013 at 5:46 AM
    Taco John
    Illinois
    4X4
    Thanks for all the feedback. I am not interested in cheap for cheap sake, but I was interested in lowering the time and labor as well as not having to mess with spring compressors. I would rather not have a shop do the work because when I have in the past, I have always been disappointed in the quality of the work.
    I guess I will just need to plan a little extra time to do the job.
  8. Mar 20, 2013 at 6:07 AM
    Taco John
    Illinois
    4X4
    It looks like there are a few vendors on here that carry the 5100s. Any recommendations regarding price and customer service experiences?
  9. Mar 20, 2013 at 6:15 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    As stated above you can buy a set pre-assembled if you don't mind paying a little extra. I definitely would consider it if I ever change out my 5100s for something different. Wheeler's and Downsouth Motorsports are excellent vendors.
