Montana Tacomas
Discussion in 'North West' started by Mondwa, Dec 29, 2009.
  1. Nov 1, 2011 at 2:41 PM
    #2341
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Nice. I really like my OME setup. The only thing is the paint chips off easily on the front struts. I don't know why? :notsure:
    Oh well, doesn't effect the way it rides so I'm not complaining.
  2. Nov 1, 2011 at 2:45 PM
    #2342
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Are you full OME? Leaf pack, 4 new shocks and all?
  3. Nov 1, 2011 at 2:49 PM
    #2343
    YellowDog01
    04 4x4
    Well I have Wheeler's Alcan 5 leaf pack in the rear and then all OME struts, coils, and shocks.
  4. Nov 1, 2011 at 2:55 PM
    #2344
    memario1214
    Colton
    Missoula, MT
    Yeah same thing... like it I hope
  5. Nov 1, 2011 at 2:57 PM
    #2345
    YellowDog01
    04 4x4
    You won't be disappointed!
  6. Nov 1, 2011 at 2:58 PM
    #2346
    MTgirl
    Weesa
    Bob's secret mod lair
    I should have ridden in your truck for a bit Garret. I'm convinced its my shocks that are squeaking in my front end now and if thats the case they are getting traded out for OME's. I think :(
  7. Nov 1, 2011 at 3:04 PM
    #2347
    YellowDog01
    04 4x4
    It is a little bit of a firm ride with the 881s with my 4 cylinder but I like it. I think I'm going to get the AAL for the 5 leaf pack this winter because with the weight of everything and the camper shell in the bed I'm starting to get some sag. :(
  8. Nov 1, 2011 at 3:13 PM
    #2348
    MTgirl
    Weesa
    Can't be any worse than my truck...the Bilsteins have always been too harsh for me. I'd like to see what the OME's are like before diving into that project though.
  9. Nov 1, 2011 at 3:52 PM
    #2349
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    did you put in new bushing when you had it done?? Don't see how the shocks could be squeaking otherwise..
    i love my 5100s, they soak up stuff at higher speeds great. course knowing your driving style..you might like the softer OMEs..
  10. Nov 1, 2011 at 4:39 PM
    #2350
    MTgirl
    Weesa
    New bushings? Yes.
    I thought it was the ball joints so I had them replaced but that didn't fix the problem. So now I'm thinking its either the shocks (maybe got some water in them?) or the UCA's... Funny thing is that when the truck is wet - like after a car wash - the squeak is gone. The rest of the time it squeaks just as loud as the rear end! :annoyed:
  11. Nov 1, 2011 at 5:02 PM
    #2351
    Blackdawg
    Monte
    Wyoming/St. Louis
    huh..thats odd..doesn't make much sense..UCAs are too pricey to just throw in a set and i doubt your planning on a good mid travel setup anytime soon so maybe it is the shocks?? Or the lower a arm...
  12. Nov 1, 2011 at 9:54 PM
    #2352
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Sounds like upper control arm bushings to me. Water acts like a temporary lubricant. Very temporary. :eek:
  13. Nov 2, 2011 at 7:20 AM
    #2353
    MTgirl
    Weesa
    Sooo....I need new bushings or the current ones just need to be lubed?
  14. Nov 2, 2011 at 5:47 PM
    #2354
    swiss
    swiss Well-Known Member
    Try lubing them to isolate the issue before you tear into it. If the sound goes away with a little lubricant then you've got your culprit. Good luck.
  15. Nov 2, 2011 at 8:38 PM
    #2355
    Digiratus
    Roaming the PNW
    The RedHead
    :rain:
    Its probably time to replace. If they are stock, they are rubber and probably worn, hence the noise. I'd try as swiss suggested before you do anything. Us a thin lube, like a penetrating oil on the bushings. If they quite down, you know the problem. But a thin lube wont last very long. The squeak will return. :eek:
  16. Nov 4, 2011 at 6:42 PM
    #2356
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Going to be in Bozo tomorow for the ski swap with some friends. If anyone in the area wants a deckplate for their yota or knows someone who would let me know tonight and Ill bring one over.
  17. Nov 8, 2011 at 3:29 PM
    #2357
    swiss
    Ever get the squeak muffled?
    Picked up a new Digital SLR...I need a good excuse to get out and get some screen time with it. You guys doing anything exciting in the near future? I've got a very open schedule as of late, and an itching to do some wandering/exploring. (maybe we can cover some recovery stuff)
  18. Nov 8, 2011 at 3:30 PM
    #2358
    memario1214
    Colton
    Missoula, MT
    I may be down for something this coming weekend or Saturday of the next... Nothing crazy, as I still don't even have my winter tires on yet. Haven't been home
  19. Nov 8, 2011 at 3:36 PM
    #2359
    MTgirl
    Weesa
    its been quiet ever since saturday...maybe something to do with the snow/cold :notsure: and good thing too! its too damn cold to be out working on anything this time of year.
    i'd be up for some exploring but will most likely be in Butte this weekend borrowing dad's garage for a bit....Sunday maybe? or next weekend?
    :spy: Want me to pick up yer tires this weekend?
  20. Nov 8, 2011 at 3:49 PM
    #2360
    memario1214
    Colton
    Missoula, MT
    No, that would leave me with even more tires here... I'm going back home here in a week or 2 to get fitted for braces rd. 2 :(:(:(:(:(. Preparation for le jaw surgery!
