Montana Tacomas
Discussion in 'North West' started by Mondwa, Dec 29, 2009.
  1. Feb 6, 2012 at 1:01 AM
    #3521
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    god damit. i have changed my mind to fawking much! i was told all i would have to do is cut some front inner fender plastic and pound down a pinch weld. EVERYONE IS LYING!!!!!!!!!!!
  2. Feb 6, 2012 at 1:01 AM
    #3522
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm at 3.75 lift no problem clearing 285s
  3. Feb 6, 2012 at 1:03 AM
    #3523
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    AGAIN 2nd gen, your argument is invalid
    ben can run 32" M/Ts with no lift and old man sagging suspension, so why is it so hard to run 1 " bigger A/Ts with 2.5" of lift:confused:
  4. Feb 6, 2012 at 1:03 AM
    #3524
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Every truck is gonna be different no matter what, but prepare for the worse. Jon had about 2.5'' of lift and he had to cut out a ton all around on his truck. But i had 3 and 4 out back and didn't have to do anything to the rear and had to do a bit of trimming of plastic and the pinch weld mod. Now i have to go cut off part of my wheel well due to my spacers..
    just be prepared. You could have to..and might not...
    Are you still running your sway bar?
    you don't know that yet..and your a 2nd gen..haha
  5. Feb 6, 2012 at 1:04 AM
    #3525
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you'll have to run 255/85s and you should be fine who cares if you have to pound on the truck a little
  6. Feb 6, 2012 at 1:05 AM
    #3526
    Blackdawg
    Monte
    Wyoming/St. Louis
    his are also super skiny. width has to do with a lot of it, as does the rim and lift. There are a lot of factors. sway bar too and the fact your an I4 and im a V6 could make all the difference.
  7. Feb 6, 2012 at 1:06 AM
    #3527
    Blackdawg
    Monte
    Wyoming/St. Louis
    he is also and auto and drives like a grandpa :p haha :D
  8. Feb 6, 2012 at 1:07 AM
    #3528
    Blackdawg
    Monte
    Wyoming/St. Louis
    these area actually almost a 34'' tire...but only 9.25'' wide haha a popular expo tire..
  9. Feb 6, 2012 at 1:07 AM
    #3529
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Even with an extra 200# up front i doubt i'll lose much lift. The spring rates were designed for a 4x4 DC V6 and I'm already 4-500lbs less with the reg cab. Even if I lose 1/2 an inch I already have the cab chop plates and ditched the mud flaps. and I'll still be @ 3.25" above stock
  10. Feb 6, 2012 at 1:08 AM
    #3530
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    and i wanted to go to bed..
    yes, sway bar
    i was fine with trimming a little, i saw some article where a guy had a 1.5" lift and fit 33s by cutting a bit out of the plastic guard and pounding down the pinch and a bit out back. i was hoping i didnt need to do anything out back and only trim some and the pinch up front
    bilsteins all around at 2.5 and a 2" lift in the back, either with an AAL or a semi custom leaf pack
    ill pound on the truck a lil, dont want to cut everything to shreds
    ill be on stock rims btw
  11. Feb 6, 2012 at 1:09 AM
    #3531
    Blackdawg
    Monte
    Wyoming/St. Louis
    right..but the width and rim is what could come and bit you in the ass haha i didn't have to do any trimming till after i put my spacers on. And if you don't get the right BS you'll not only rub the UCAs bad(which btw, you should get ASAP with that much lift on a 2nd gen) or the out fenders. You'll just have to see really.
  12. Feb 6, 2012 at 1:09 AM
    #3532
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    check your math again
    from the online tire size calculator
  13. Feb 6, 2012 at 1:10 AM
    #3533
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    new UCAs will be here in two weeks
  14. Feb 6, 2012 at 1:11 AM
    #3534
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mark, it'll be fine. Quit worrying about it and just cross the bridge when you get there. You very well could not have to do much. Keeping the sway bar on will help avoid some trimming.
    and Ben...my 33s stuff...
    :D
  15. Feb 6, 2012 at 1:12 AM
    #3535
    Blackdawg
    Monte
    Wyoming/St. Louis
    huh i read some were they were 33.8 and 9.25...for KM2s..but BFGs do run taller then most tires..and the width..well whatever :D haha :p
    I can only count to 4 and sometimes 7 (i will be shocked if you get that joke)
    oh okay good to hear! Camburg? TC? or what??
  16. Feb 6, 2012 at 1:13 AM
    #3536
    Blackdawg
    Monte
    Wyoming/St. Louis
    and i have a real bumper that'll kill anything before it kills the truck and actually covers my radiator..
  17. Feb 6, 2012 at 1:13 AM
    #3537
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    how does keeping the sway bar minimize trimming.... by limiting travel?
    that's a great idea I'm going to go put mine back on
  18. Feb 6, 2012 at 1:14 AM
    #3538
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yalls is confusing me! The "bridge" will be in a couple of weeks. I will probably start ordering the front lift and getting the rear put together and a week or two after that i will be buying tires. i would rather not buy my 33s and realize i have to mutilate my wheel wells to wheel. where is the thread with people on a 2.5" lift and 33s!
    also we already went over this. i thought we agreed my stock rims have enough BS that i will be gravy
  19. Feb 6, 2012 at 1:15 AM
    #3539
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea, it doesn't let the front IFS really flex at all..and it also take away flex in the rear..idk even know were mine is..and don't care..ill take the flex. I love being able to hit curbs or speed bumps at a slight angle at 20-30mph and barely feel it.
  20. Feb 6, 2012 at 1:18 AM
    #3540
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
