Montana Tacomas
Discussion in 'North West' started by Mondwa, Dec 29, 2009.
  1. Mar 29, 2019 at 9:14 PM
    Montanahunter
    Montanahunter Well-Known Member
    Zhaun
    Helena Montana
    2009 DC TRD off-road
    OME lift Stealth custom wheels ARB bullbar Allpro Apex sliders Prismo design roof rack.
    Yes your brakes are good run them till t bgg so notch is almost gone.
  2. Mar 30, 2019 at 10:56 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can take your truck all the way to blue lake. I doubt it open yet though. Probably won't be clear of snow till early June.
    Iron mountain is cool too but same deal lot of snow
    I think you'd be lucky to get 24k for it. It's old news Tacoma now with 3rd gens being out.
    Modifications don't add value they take away from it. Unless you find the right buyer and this place will be the best place to do that. Otherwise if you're serious. Take it back to stock as much as possible and sell it. You'll get more money for the parts and truck seperately than you would together.
    Zeke588[QUOTED] likes this.
  3. Mar 31, 2019 at 5:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Seems like a crazy amount of brake pad left for 53k miles on the truck doesn't it?
    The brakes aren't completely smooth either. At slow speeds and light braking I can feel a pulse a bit (I think most folks call this "warped rotors").
    I figured I'd need pads and or rotors soon. But holy cow..
    Zeke588 likes this.
  4. Mar 31, 2019 at 5:53 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    I'm still on my original brakes at 129k. Took Runner in to get them changed and they said I still had about 30% left
    w.adventures likes this.
  5. Mar 31, 2019 at 6:01 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Holy moley! Probably because you use crawl control all the time? o_O
    Zeke588 likes this.
  6. Mar 31, 2019 at 6:03 PM
    MTgirl
    Weesa
    Sure thats it :rolleyes:
    The OEM stuff they build these vehicles with is like nothing else.
  7. Mar 31, 2019 at 6:04 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    OEM I'm pretty sure is a balance. Quieter braking, lesser brake performance, but longer life.
    I've considered finding better braking for my truck since it doesn't stop that great. But I was never really impressed by it's stopping ability brand new off the lot.
  8. Mar 31, 2019 at 6:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You must have cooked them to warp them. Oem rotors last forever.
  9. Mar 31, 2019 at 9:10 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    <<<Brake front end guy here FWIW.
    "Warped" rotors can be one of many things and the term is sort of a misconception. Yes rotors can get warped from heat this is referred to as "runout" where the rotor has a "wavy" parallel surface. Usually caused by uneven/over torquing wheel nuts or rust build up on the hub surface. Rotors can also wear unevenly where they are thicker or thinner from one spot on the rotor to the next,usually between the vents where there is less material thickness this is called "parallelism" this will usually give you a very fast shudder/pulsating feeling.
    The most common is actually caused by pad buildup on the rotor. When the brakes are hot and you stop with your foot on the brake,the pads leave a small amount of pad material on the rotor surface when you release the brakes. After time this buildup can cause the sensation of pulsing brakes much like parallelism....
    ETA And yes the pads they are using these days last a very long time. I have seen vehicles with over 100k on them with more than 50% of pad life left. This is also very subjective to how the vehicle is driven ie. highway vs stop go traffic.
  10. Apr 1, 2019 at 4:55 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I think it's the MT air. :D
    As said, usage and driving habits probably, when I lived there I never ran a set of pads out. I've lived in a 'burb/metro area now for a long time and brake pads tend to wear out much quicker. On my 09 the original front pads lasted 85k, and they were worn out.
  11. Apr 1, 2019 at 5:04 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I am about to do a 5th Gen T4R Budget Big Brake Kit on my truck. The last of the parts should be here tomorrow hopefully. Going with Napa Eclipse reman calipers, factory backing plates and hard lines to the calipers, TRD brake pads and dba 4x4 Suvival slotted rotors. Because yes, the second gen trucks brakes suck.
    Kyitty[QUOTED] likes this.
  12. Apr 1, 2019 at 8:46 PM
    Montanahunter
    Zhaun
    Helena Montana
    If the uneven feel you have on the pedal both you you can take the rotors off and have them turned. If you can live with the pedal feel run them until the pads are toast. At that time can have them turned if they are thick enough (most likely) or replaced. It's all up to you.
  13. Apr 9, 2019 at 7:53 AM
    Zeke588
    Zeke588 Well-Known Member
    Zeke
    Billings, Mt
    Bluerunner
    03 V8 limited
    UGH. Moving sucks. With the nice weekends coming up all I want to do it get out with the family.
  14. Apr 9, 2019 at 11:48 AM
    Effenglide
    Effenglide Well-Known Member
    Effen
    Montana
    2015 TRD Sport DCLB
    Here we go again!
    Let me know if you need help!
  15. Apr 9, 2019 at 12:26 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Same, let me know if you need any help as well. Got the Lexus pretty well setup for adventures now.
    RoaminRoman, uurx and 90yota like this.
  16. Apr 9, 2019 at 3:32 PM
    phatfisher
    phatfisher Member
    2018 Cement Tacoma TRD Off-Road
    What's up everyone! Looking to upgrade my stock goodyear tires to some nitto ridge grapplers. Located in Missoula and just wanted to double check to make sure if the only dealers for nitto's were discount tire in Kalispell and Bozeman before I make a trek for them?
  17. Apr 9, 2019 at 3:32 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Discount is also in Helena now
  18. Apr 9, 2019 at 3:33 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    And soon to be in Billings as well
    90yota[QUOTED] likes this.
  19. Apr 9, 2019 at 3:35 PM
    phatfisher
    phatfisher Member
    So sad Missoula doesn't have one (yet :fingerscrossed:)! Seems like it's pretty similar distances to any Discount store from Missoula
  20. Apr 9, 2019 at 3:53 PM
    MontanaTacoTruck
    MontanaTacoTruck Montana Taco Truck
    David
    Bozeman, MT
    2016 Tacoma Sport Custom
    2016 Toyota Tacoma Sport 35x12.50R20LT TOYO OPEN COUNTRY M/T TIRES 20" CALI OFFROAD® - 9100 BUSTED Satin Black Rims with Milled Accents FABTECH 6" lift and Dirt Logic Shocks PREDATOR Side Steps
    Last weekend started the drive up to Cataract Lake toward the Hollow Top Mountain area. Part way up on Cataract Rd it was getting sketchy slippery cause of snow and ice still on the road did a hillside back up and turn around. Maybe another week or two and i can access the area further up into that area. Also reporting Patosi Springs Road was also Closed last weekend due to washouts.
    RoaminRoman and 90yota like this.
