Montana Tacomas
Discussion in 'North West' started by Mondwa, Dec 29, 2009.
  1. Jun 20, 2021 at 2:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Like shops to install?
    Not really. I do everything myself, haven't had a shop touch my truck for anything other than an alignment in 10 years.
    So I'd say do it yourself! Front kit isn't too hard to do yourself honestly.
  2. Jun 20, 2021 at 3:17 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    If installing LT is anything like installing MT, then it's just basic hand tools, wrenches, sockets, ratchets, torque wrench, jack stands, jack, (depending on stubborness of hardware penetrating oil, or impact). Then there is the hand cleaner, beer, pizza, and pretty swear jar if you have kids or grandma around.
    Zeke588 likes this.
  3. Jun 20, 2021 at 4:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah 2nd/3rd gen have cv axles to worry about and build. Most come with longer shafts that need swapped out.
    But it's all bolt in otherwise.
    Unless you want to do some welding of cam gussets, tower top plates, spindle gussets (though some kits have fully built ones) and stuff.
  4. Jun 21, 2021 at 1:04 PM
    tacotruck2005
    tacotruck2005 Goodolboys 4x4 section
    Bozeman Mt
    Just looking for a good place to buy the full kit not to install I can do that myself.
  5. Jun 21, 2021 at 10:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah gotcha.
    Well that depends on the kit you want and what type of kit. Some you can get at just about any offroad retailer like Wheelers/Low range or something. Others are buy direct like Dirt King or LSK or MCM for instance.
    It all depends on the kit you want and the features you want from it. Of which(lucky for you!) there are a lot. Uniball uppers and lowers. Fully fabbed spindles. Secondary shock mounts. Strike plates. Boxed uppers. Horizontal upper uniball. Extra ground clearance. Beefer steering options.
    Ect.
    Soooo...yeah. What kind of kit you thinking?
    tacotruck2005[QUOTED] likes this.
  6. Jun 21, 2021 at 10:18 PM
    tacotruck2005
    Bozeman Mt
    I have been looking at dirt king and total chaos with fox suspension. Fox has been my favorite ever since I started riding motorcycles so thats a must-have. But just trying to figure what kit can handle my love to drive fast and my love for weekend overlanding. I plan on upping the horsepower on it. Also I hear lt kits are cause for a lot of attention is that because of the kit or because how people use their trucks? Also, is best to buy a whole kit are buy parts separately over time?
  7. Jun 21, 2021 at 10:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you can't buy parts separately. And you can't run just the lowers with stock uppers or mix and match. Pretty much all or nothing. Same goes for shocks.
    Foxes are nice. But I'd give ADS a look personally. They hold up much better and are stout all around.
    LT kits are just..bad ass. And they really grab people attention cause they make the whole truck so wide, add bigger wider tires and it just looks big.
    I mean, here is mine vs a stock(albeit wrecked) truck lol
    [​IMG]Christina Lake 2016-12.jpg by Monte Nickles Photos, on Flickr
    It stands out to say the least.
    People assume how you use it just based on how it looks. So yeah.
    And if you go real fast, then a 3.5 kit is for you. But be ready to get turned around here and there due to width. Not often I bet though.
    Also keep in mind in MT you have to have mud flaps that cover the wheels. Highway patrol will nail your ass if you don't have something. You'll need to make something that removeable likely.
    Dirt king makes a solid kit. Super nice setup. You can get the axles assembled there. They don't make spindles though. Neither does TC though.
    Dirt king also makes a decent looking SUA kit. I don't know many folks that are running it though. The TC SUA kit doesn't have a great rep though so I'd maybe avoid that.
    RoaminRoman likes this.
  8. Jun 21, 2021 at 11:21 PM
    tacotruck2005
    Bozeman Mt
    Sorry terrible wording but meant to ask about the reliability if it's terrible because of just being an aftermarket kit or because its the way people use it. Bushing or heim inner pivots?
  9. Jun 22, 2021 at 12:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh gotcha.
    Well the uniballs and/or heims joints do not last as long. Thats just the nature of the part. Exposed bearing vs a rubber bushing of something stock. Much stronger and beefer. But they wear out faster as well. part of that is that you'll be beating on it more. part of it is just the elements.
    So you do have to do more maintenance on the regular with the uniballs and spherical bearings. Depending on useage, every year or every other year. Not super hard to do but does mean you have to tear it down a bit often.
    Race truck parts...
  10. Jun 22, 2021 at 11:22 PM
    tacotruck2005
    Bozeman Mt
    Is it easy and possible to upgrade these kits? Just wondering to see if I should save up and later get the best they got and in the meantime work on other things or work on lt kit now.
  11. Jun 23, 2021 at 9:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not exactly. The only way to upgrade is to either go wider, so from a +2 to a +3.5 or +4.5. Which if you do that, then you need different shocks usually, have to swap out the upper and lower control arms and new CVs and steering extensions anyways. So you basically buy a whole new kit.
    Now you can upgrade the spindle on some of the kits. It just depends on the design. Some that are fully fab spindles use different setup so you have to run the kit it comes with.
    That's really the biggest upgrade you can do on a Long travel kit. The stock spindles can bend and if you don't weld the spindle gussets on right you can shear the spindle as they are a forged piece of metal. So proper heat treatment is important when you do that.
    You can also upgrade the steering rack and inner/outer tie rods to heims often later but that also depends on the kit. Solo and Marlin Crawler sell beefier racks. Various people do the heim steering upgrades. Just remember the more spherical bearings you put in, the more beefy it is but also the more often you'll likely have to replace that stuff. They aren't designed for longevity.
  12. Jun 23, 2021 at 10:33 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    looks like the crews are making some headway on the fires - hope they can keep it up! would be nice to see things opened up before the long 4th of July weekend
  13. Jun 24, 2021 at 7:09 AM
    Clemson55
    Clemson55 Well-Known Member
    Richard
    2015 TRD Pro
    Bumpers Front and Rear, Bed Rack, RTT
    Anyone run Goose Lake Trail north of Cooke City before? Whats your real assessment, not the Jeep d-bag on youtube assessment?
    Zeke588 likes this.
  14. Jun 24, 2021 at 4:45 PM
    MTgirl
    Weesa
  15. Jun 26, 2021 at 9:43 PM
    4x4offroadMT
    4x4offroadMT Well-Known Member
    Casey
    Bozeman, MT/Oregon City, OR
    08 DCSB 4x4 TRD Offroad
    255/85/16 st maxx, uws toolbox, CB radio, 5100s, OME 885s, Dakars, Allpro sliders, ARB bumper
    I’ve run most of it, not terrible if you sliders and good tires. When you plan on going?
  16. Jun 27, 2021 at 6:55 AM
    Clemson55
    Richard
    2015 TRD Pro
    I'll be there Thursday with 2 of my college roommates who are driving out from the east coast. Debating between a couple spots to camp. None of us have sliders though, how much of a need do you think that is?
  17. Jun 27, 2021 at 2:24 PM
    MTgirl
    Weesa
    its still kinda early, might be snow and definitely muddy. couple of water crossings that you may or may not get through. it may not even be open yet - have you called the forest service office to ask?
    and fire danger is high, fire restrictions for the area and no campfires.
  18. Jun 27, 2021 at 4:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Beautiful trail with some fun spots nothing terrible though. Gorgeous area though. If you don't have 33s you'll really want skids and sliders. If you have 33s then you're good.
    Ah..
    No. No you won't.
    Trails don't open till the 15th of July in that area to help keep damage in check from snow melt and people with heavy left feet.
    Sorry man. Bad timing.
    I ran Independence this weekend. Man it's gotten rough. A creek has started flowing though par of the upper section and take half the road with it. Much more of that and it'll be impassible even for utvs. Which seems to be the dominate thing there. But we had the place to ourselves mostly. Was great.
    4x4offroadMT and RoaminRoman like this.
  19. Jun 27, 2021 at 4:43 PM
    MTgirl
    Weesa
    I was up there last weekend...well, as far as Aspen Camp. Chebby isn't so nimble... :oops:
    I was really glad to see that they graded the main road somewhat recently though.
  20. Jun 27, 2021 at 5:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Did that in 2018. I hit the construction and it was a 2-3 hour wait. Didn't go through.
    But yeah much different than when I first ran it in 2012 ish?
