Monthly So Cal Off-Road Run
Discussion in 'Southern California' started by schecter517, Apr 4, 2019.
  1. Aug 7, 2020 at 7:52 PM
    #3841
    eon_blue
    Azusa, CA
    Where does the oil come out from? Maybe with the locker in there it was over filled and puked the extra out thru the breather?
  2. Aug 7, 2020 at 7:59 PM
    #3842
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I wasn’t able to pin point it, it appeared to center from where the air line goes in, but that’s also a low point on the diff so not really conclusive. It’s hard to see up to the breather but there was also oil present on the sides.
    I wonder about overfill, I put in oil to the fill plug, which was maybe a 1/2 qt in total. It’s never done it on the street and I recently did the diffs with fresh oil a couple months back.
  3. Aug 13, 2020 at 8:24 PM
    #3843
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    any meetups/offroad this weekend? thx
  4. Aug 13, 2020 at 11:30 PM
    #3844
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Supposed to be 109 degrees on Saturday. Blah that’s too hot for me.
    whatstcp and eon_blue like this.
  5. Aug 13, 2020 at 11:36 PM
    #3845
    Tacoma1997White4x4
    You might be right, might jist go to the beach
  6. Aug 15, 2020 at 6:05 PM
    #3846
    yodataco
    yodataco Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    Went to anza last night. My bottle of water felt like boiling even at night.
  7. Aug 15, 2020 at 6:11 PM
    #3847
    eon_blue
    Azusa, CA
    You're a brave man
  8. Aug 15, 2020 at 7:50 PM
    #3848
    yodataco
    Alex
    Orange County, CA
    2000 4Runner
    Or stupid. That water bottle was the only one.
  9. Aug 15, 2020 at 10:12 PM
    #3849
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    It’s just so nasty outside. One of the cons of socal’s basin. I’m glad I finished detailing last week. Stay safe out there boys. Tons of fires surrounding the inland empire.
    whatstcp likes this.
  10. Aug 20, 2020 at 9:37 PM
    #3850
    Tacoma1997White4x4
    Whats crackin this weekend?
    theluharlifestyle and whatstcp like this.
  11. Aug 20, 2020 at 9:37 PM
    #3851
    Tacoma1997White4x4
    I imstalled reflectix on my camper shell, idk what help itll do in this heat tho
  12. Aug 21, 2020 at 9:38 AM
    #3852
    eon_blue
    Azusa, CA
    My truck is in need of some work before I can wheel again - need to replace my steering rack bushings (rack is moving a lot with the steering wheel), LCA bushings and figure out a bad pull I've got going on that alignment can't seem to fix. Also need new tires but gotta get the rest taken care of first.
    Should be good to go after the hot weather is behind us
    yodataco and Norsemanvike like this.
  13. Sep 1, 2020 at 11:21 AM
    #3853
    sikTacos
    sikTacos Well-Known Member
    Eric
    SoCal
    2Gen Tacoma (DC/LB/4X4)
    I recently replaced my steering rack bushings on my 2gen as well but still have the death wobble. Now in the process of finding an oem replacement.
  14. Sep 1, 2020 at 11:25 AM
    #3854
    eon_blue
    Azusa, CA
    Just replaced mine over the weekend, wasn't too bad of a job but sucked in the heat. Neck is killing me from holding my head up for so long while under the truck lol.
    I never had the death wobble, just a sort of 'looseness' in the wheel while driving. Seems to have gotten a lot better with the new bushings.
    Are you sourcing a new steering rack or? I wonder if it's your tie rods, inner and/or outer
    yodataco likes this.
  15. Sep 1, 2020 at 11:32 AM
    #3855
    sikTacos
    Eric
    SoCal
    Well I've been chasing this knocking coming from the steering rack on the driver side. Thought it was the inner tie rod so i replaced both inner/outer on both sides of the truck and no luck...changed the bushing at the same time. But the wobble is still there going between 50-65mph. Tires been rotated, rebalanced etc. Went to a friends place with a lift and realized there was a lot of play/movement when moving the wheel left and right with the new bushings. So now I'm debating on getting a new OEM steering rack from dealership for about $600....haven't pulled the trigger yet. :(
  16. Sep 1, 2020 at 11:34 AM
    #3856
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Did you go off of just the tire moving or could you see the rack moving as well?
  17. Sep 1, 2020 at 11:36 AM
    #3857
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Are the wheel bearings good? That could cause wheel movement, a bad one will make noise when spinning with little load like on the inside of a high speed turn.
    theesotericone likes this.
  18. Sep 1, 2020 at 11:37 AM
    #3858
    theesotericone
    Bishop CA
    Yep. LCA bushing also cause wobble and 3 to 9 tire movement.
  19. Sep 1, 2020 at 11:39 AM
    #3859
    eon_blue
    Azusa, CA
    What if they both (wheels) move the same when you move one of them?
    I could see a bad wheel bearing letting one wheel move (the one you're testing), but if both wheels move simultaneously that would be something with the steering yea?
    That's what mine was doing, could also see it in the rack itself...which is why I replaced the rack bushings. But if he's still got movement in both wheels side to side then it could be the LCA bushings?
    Just curious because I might be doing my LCA bushings next and am curious to see if there's still any movement
  20. Sep 1, 2020 at 12:15 PM
    #3860
    yodataco
    Alex
    Orange County, CA
    2000 4Runner
    1st gens had the issue with the slip joint in the steering column, solution is to tack weld it. I believe 2nd gens have a similar problem as there is a rubber bushing between the steering wheel and rack.
    eon_blue[QUOTED] likes this.
