Monthly So Cal Off-Road Run
Discussion in 'Southern California' started by schecter517, Apr 4, 2019.
  1. Jun 24, 2019 at 1:46 PM
    #1121
    bprout
    bprout Well-Known Member
    Brian
    SoCal
    2014 SR5 4x4
    Runs off Hopes and Dreams
    If we did white mtn it wouldnt be a problem for you. and from the looks of it Heartbreak Ridge would only have one section where you would just need some spotting to get around it but nothing too gnarly..
    EDIT: I just saw that youre stock... without a lift you would probably be smacking some stuff with you stock skid
  2. Jun 24, 2019 at 1:53 PM
    #1122
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    You'll want sliders for any of the trails mentioned.
  3. Jun 24, 2019 at 1:54 PM
    #1123
    yodataco
    yodataco Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    Seems like sliders is become a more and more important mod for me.
    bprout and eon_blue like this.
  4. Jun 24, 2019 at 1:55 PM
    #1124
    eon_blue
    Azusa, CA
    Or even removing the steps and just going sans steps/sliders would be better than having the steps on, since those will reduce clearance and if they do get smashed they're going to increase the risk of body damage. I would only do that for White Mtn or Heartbreak though, I wouldn't do Gold without any sliders.
    Norsemanvike likes this.
  5. Jun 24, 2019 at 1:55 PM
    #1125
    eon_blue
    Azusa, CA
    Was the first offroad related mod I did to my 04, got me some @Shmellmopwho sliders welded to the frame
    The tin can stock IFS skid can take a surprising beating and still do it's job but the transfer case is in a precarious position and very open to damage if there's nothing there to protect it.
    Between the back of my Budbilt IFS skid and my Skidrow t-case skid, there's maybe a foot or so of exposed transmission but most of the trails I do don't pose a threat there unless I'm being very careless.
    I'd actually like to get some kind of rear diff protection one of these days, the rear diff is the most vulnerable most of the time if you pick the wrong line or slip off your line and onto a rock. Front of the diff is pretty beefy but the back plate of the diff is relatively weak, at least on 1st gens.
    Shmellmopwho likes this.
  6. Jun 24, 2019 at 2:02 PM
    #1126
    So Cal Trucker
    So Cal Trucker Member
    2019 TRD OR 4X4 DCSB
    Long time lurker, first time posting. So I've been following this thread and would like to tag along. However, my truck is absolutely 100% stock right now. I have no offroad experience, but hey, everyone starts somewhere. Let me know if any of these 3 trails are beginner friendly and doable with a completely stock truck, although it looks like Gold is out of my reach. I live where the 605 fwy meets the 91 fwy. Great to be a part of this forum and look forward to gaining offroad experience with you vets.
  7. Jun 24, 2019 at 2:02 PM
    #1127
    desertjunkie760
    Shane
    Check My Sig.
    Should be one of the first mods done if you’re planning on going on trails. These trucks aren’t very high stock and typically have a long wheel base so sliders just give you the extra insurance.
    Shmellmopwho and Norsemanvike like this.
  8. Jun 24, 2019 at 2:04 PM
    #1128
    eon_blue
    Azusa, CA
    I think the 3 being talked about right now probably wouldn't be the best place to start for a stock truck...a beginner driver sure, but a stock truck with no added clearance, protection or good AT tires is going to take a beating. I would look into some lift kits because at the very least, for most any 4x4 required trail you're going to want some additional ground clearance. Bigger tires helps with that too.
    Welcome aboard btw :cheers:
  9. Jun 24, 2019 at 2:05 PM
    #1129
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Shane wouldn't steer my wrong, so I'll take his advice and pass.
  10. Jun 24, 2019 at 2:09 PM
    #1130
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Just seeeend it!
    Nicklovin and Prayn4surf like this.
  11. Jun 24, 2019 at 2:13 PM
    #1131
    So Cal Trucker
    Much appreciated. I guess I'll check back after getting some work done on my truck. Thanks for the feedback, Eon.
    eon_blue[QUOTED] likes this.
  12. Jun 24, 2019 at 2:17 PM
    #1132
    Norsemanvike
    Escondido, CA
    And when "But Aaron said.." makes the problem worse, I'll put her on the phone with you. LOL
    eon_blue likes this.
  13. Jun 24, 2019 at 2:18 PM
    #1133
    bprout
    Brian
    SoCal
    2014 SR5 4x4
    I think we should do heartbreak ridge. It looks like a super fun place to explore with old mines and sweet views. It also looks like most of the real technical stuff is bypass-able. None of it looks too technical anyhow.
  14. Jun 24, 2019 at 2:19 PM
    #1134
    eon_blue
    Azusa, CA
    It is cool to stop and see the mines. I've only done it once and there's a lot of little dirt roads that cross each other out there in the desert near the start of the trail so we'd have to lock down some good directions/coordinates, as I'm not familiar enough to do it off memory. I really need to get a good GPS system for my truck for this kind of stuff.
    bprout[QUOTED] likes this.
  15. Jun 24, 2019 at 2:22 PM
    #1135
    bprout
    Brian
    SoCal
    2014 SR5 4x4
    I was going to try to map it all out on Google Earth/Gaia GPS to get a better idea of the trip... the trails offroad page has a pretty detailed write up on a lot of the waypoints as well.
  16. Jun 24, 2019 at 2:41 PM
    #1136
    bprout
    Brian
    SoCal
    2014 SR5 4x4
    When you ran the trail, do you remember if you ended up taking Broom Flats(2N01) to the 38?
  17. Jun 24, 2019 at 2:45 PM
    #1137
    eon_blue
    Azusa, CA
    I honestly don't remember, maybe Shane @desertjunkie760 will recall, he led us both to the trail and then back to the highway toward the end
  18. Jun 24, 2019 at 2:55 PM
    #1138
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    I'm getting excited haha
    bprout likes this.
  19. Jun 24, 2019 at 2:57 PM
    #1139
    desertjunkie760
    Shane
    Check My Sig.
    Yes, we took broom Flats back up to the 38. It was snowy and it took us longer than expected to run the trail so we cut the trip short. Came up through Rattlesnake Canyon.
    Pappy and Harriet’s is a good meeting spot if you want to start from the desert side.
  20. Jun 24, 2019 at 3:05 PM
    #1140
    oni06
    oni06 Well-Known Member
