Monthly So Cal Off-Road Run
Discussion in 'Southern California' started by schecter517, Apr 4, 2019.
  1. Aug 16, 2019 at 10:39 AM
    #1921
    eon_blue
    Azusa, CA
    crap I just remembered I have an indoor skydiving thing with my dad on the 25th...I can do the 24th or the weekend after Labor Day weekend in Sept.
    oni06 likes this.
  2. Aug 16, 2019 at 11:49 AM
    #1922
    bprout
    bprout Well-Known Member
    Brian
    SoCal
    2014 SR5 4x4
    Runs off Hopes and Dreams
    Where is this run? I might be interested too :anonymous:
  3. Aug 16, 2019 at 12:22 PM
    #1923
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    :wave: Let me know too, usually have Sunday’s off so probably can make it
  4. Aug 16, 2019 at 3:23 PM
    #1924
    Trah
    Trah Licensed Class C Driver...
    San Diego
    2017 Barcelona Red TRD Sport ACLB
    stuff and things...
    i want in! :bananadance: i need to test out my new camera mount...
    Norsemanvike likes this.
  5. Aug 16, 2019 at 4:06 PM
    #1925
    Jaycee619
    Jaycee619 Well-Known Member
    JC
    San Diego, CA
    21 Tacoma TRD OffRoad 4x4 6spdMT DCSB MGM
    I'd like to join in September date.
  6. Aug 16, 2019 at 7:58 PM
    #1926
    lesterb315
    lesterb315 Well-Known Member
    Lester
    SoCal
    2012 DCSB Off-Road
    Hey guys, quick question. First of all, I’ve yet to really do any major maintenance to my truck since everything has worked great until about now, I think. I’ve recently gotten this creaking sound when I turn the steering wheel to the right, but only when stopped. I’ve looked it up and it lists a couple of things, so my question is what should I look for to see what may be the problem?
  7. Aug 16, 2019 at 8:04 PM
    #1927
    eon_blue
    Azusa, CA
    A 'creak' to me is pretty specific to bad bushings at least in my experience. My lower control arm bushings creak pretty bad on dips like old barn doors or something. Maybe those or your UCA bushings?
    edit - I missed the part where you said it only happens when you're stopped. Is it coming from the steering pump or rack? Might be time to change the PS fluid
    If it doesn't sound like a power steering whine then I'd jack the front end up and see if you can recreate it by moving things...check for tie rod play, see if you can isolate the sound to one of your bushings, etc.
    lesterb315[QUOTED] likes this.
  8. Aug 16, 2019 at 8:21 PM
    #1928
    lesterb315
    Lester
    SoCal
    2012 DCSB Off-Road
    Yeah, i read up on it maybe being the power steering fluid, so maybe I can start there. I just wanted to see if there was anything else it could possibly be. Thanks man
  9. Aug 16, 2019 at 8:23 PM
    #1929
    eon_blue
    Azusa, CA
    yeah it's likely the power steering if it's more of a whine kind of like a ghost going "wooOOOOOoooo" haha
    Mine was doing that awhile back and changing out the PS fluid made it go away. When it gets old and worn it makes the pump noisy
    Flushing it is the best way to get it all out and replaced with new but the procedure is more complicated. I just bought a bunch of new PS fluid and did the turkey baster method...pull some old fluid out, pour some new fluid in, turn the steering wheel a few times, repeat 10 or 12 times until most of the fluid is replaced with new.
  10. Aug 16, 2019 at 8:30 PM
    #1930
    lesterb315
    Lester
    SoCal
    2012 DCSB Off-Road
    Gotcha, I’ll go ahead and try that then and hopefully that works.
    eon_blue[QUOTED] likes this.
  11. Aug 16, 2019 at 9:58 PM
    #1931
    Nicklovin
    Nick
    Tacoless
    Huh I’ll have to try that, the silver truck’s pump is making a bunch of noise when at parking lot speeds. Although it might need replacing all together since the power also fades when at low speed.... ehhh
  12. Aug 16, 2019 at 10:01 PM
    #1932
    eon_blue
    Azusa, CA
    With the miles it has I would replace that PS fluid first, I bet that'll help. Who knows if it's been done before, and if that's original fluid or really old fluid it will definitely make the power steering noisy AF
  13. Aug 16, 2019 at 10:03 PM
    #1933
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Cleaning the screen in the reservoir will eliminate the whining. It gets clogged and makes the pump work harder. Replace the fluid after you clean the screen.
    Prayn4surf and eon_blue[QUOTED] like this.
  14. Aug 16, 2019 at 10:07 PM
    #1934
    eon_blue
    Azusa, CA
    Yeah I probably need to do mine again now that we're talking about it, been a couple years and it makes that ghost 'woooo' sound in the AM when cold/turning sharp
  15. Aug 16, 2019 at 10:19 PM
    #1935
    Nicklovin
    Nick
    Tacoless
    Probably, everything else on that truck was original. Thanks
    Thanks, I need to remove and take apart the reservoir to pop that screen out right?
  16. Aug 17, 2019 at 9:33 AM
    #1936
    Bumble Bee Tuna
    Bumble Bee Tuna Well-Known Member
    SoCal
    18 4x4OR M/T
    1 dumb driver
    Alright I'll make a list for the 2wd friendly route potentially August 25th.
    And I copy @eon_blue you're busy that Sunday funday with pops. That sounds amazing by the way.
    List so far is:
    Sunday August 25th
    @Norsemanvike
    @Trah
    @eon_blue
    @Nicklovin
    @bprout
    Disclaimer: I'm a weirdo and I usually stay away from big group runs (like instagram/facebook groups) so I'll try keep it to just you folks and some buddies of mine. I'm also a FNG at 4x4. I just crawl around trails and try to take safe lines:fingerscrossed:....so please dont use me as a guideo_O. It sounds like @eon_blue is the most trail rated person in this group and he's not coming. That being said, if yall are looking for a fun time of exploring pilot rocks easier routes and just figuring shit out let's roll! :thumbsup:
    I'm up in the bay area right now but when I return monday I'll message you guys to get some logistics down. :cheers:
    **if anyone of you guys on the list know pilot rock like the back of your hand I'm gonna tag you in at the meet up. I just know the LEFT harder route....until it leads to fire trails and beers in arrowhead.
    bprout, yodataco and Nicklovin like this.
  17. Aug 17, 2019 at 10:16 AM
    #1937
    theesotericone
    Bishop CA
    You need to to remove the reservoir. There's an o-ring where it seats into the pump that you'll probably need to replace as well. You don't pop the screen out. If you try you'll put a hole in it. Just get the reservoir out and spray the screen from the backside with brake cleaner.
    Prayn4surf and Nicklovin[QUOTED] like this.
  18. Aug 17, 2019 at 12:05 PM
    #1938
    eon_blue
    Azusa, CA
    Wish I could make it but yeah got plans with my pops that day. If you stick to the main road you won't have any trouble. Bout halfway through you start coming up on a lot of offshoots that have some more challenging parts if anyone wants to give them a go...all the offshoots eventually wrap around back to the main road.
    If just sticking to the main fire road you can take Pilot Rock from the staging area to the bottom of Lake Arrowhead mountain (not sure exactly what it's called) in about an hour and a half, less if you aren't stopping for anything. You get to a point where you go right to take the fire roads up into Lake Arrowhead (also 2wd friendly if it's dry) or go left and you'll eventually get to the highway, which also goes up into Lake Arrowhead.
  19. Aug 17, 2019 at 3:22 PM
    #1939
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    My photography assignment for church in Carlsbad is done at 11am. I can meet at about 12 noon"ish." What time were you planning on getting started?
  20. Aug 17, 2019 at 4:07 PM
    #1940
    yodataco
    yodataco Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    Possibly count me in too. A meet got cancelled, and want to go wheeling before the summer is out.
    bprout likes this.
