Moog Ball Joint ( Why the hate?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PandaYota, Nov 6, 2023.
  1. Nov 10, 2023 at 5:09 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    There are threads on here pointing to sources in Japan for just the LBJ. Or wait for a cheap set of low mile OEM takeoff arms to pop up on here
  2. Nov 10, 2023 at 6:56 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Did that before. Low mileage oem upper arms. Pressed out the ball joints, pressed them into my Camburg upper arms. Threw away the rest of the oem upper arms.
    Just trying to avoid that if possible.
  3. Nov 10, 2023 at 3:46 PM
    chubbydude
    chubbydude Active Member
    There are quite a few on ebay. Search for 43330-09510. They seem to be legit for the most part.
  4. Nov 12, 2023 at 6:02 PM
    Taco'09
    Taco'09 Well-Known Member
    ^^^ this.
    beaverdamland likes this.
  5. Nov 14, 2023 at 5:11 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
  6. Nov 18, 2023 at 6:15 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Got lazy…went and ordered the Camburg ball joint upper A arms, complete with the Camburg ball joints.
    Just makes for less work and effort since I already have Camburg upper A arms on the truck.
    Expensive ball joints, and even more with new A arms, but should be an easy swap.
  7. Nov 25, 2023 at 12:51 PM
    PMK
    Florida
    10 DCLB TRD Sport
    The Camburg upper arms arrived today. Has the Camburg ball joints already installed. Should be an easy swap since I already have Camburg ball joint type A Arms installed.
  8. Jan 19, 2024 at 1:55 PM
    beaverdamland
    beaverdamland Well-Known Member
    97 Xtracab MT 3.4
    I’ve had mine Moog LBJs for about 2.5 years now I’ve probably put 50k miles on them and I’m just now getting play in the passenger one. Reading this thread to see how normal that is…
  9. Jan 20, 2024 at 8:48 PM
    beaverdamland
    97 Xtracab MT 3.4
    Decided to go OEM this time so hopefully they last.
