Moog LCA Bushing Failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by Red_03Taco, Nov 22, 2021.
  1. Nov 22, 2021 at 10:02 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    130 ft lbs.
    chowwwww[QUOTED] likes this.
  2. Nov 22, 2021 at 10:07 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I'd honestly send it on the white lines, and take the savings to get OEM cam bolts. Both the Moog bushings and cams are a downgrade.
    I've wheeled the shit outta my rig and I will say that the OEM rubber bushings squeaked just as much as some of the poly bushings others have run. I haven't heard a peep out the whitelines LCA bushings, nor the ES UCA / leaf spring bushings. I'm all poly at this point without squeaks.
    ohcaltexscar likes this.
  3. Nov 22, 2021 at 10:56 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    my whiteline bushings have never made any noise. neither have the poly bushings in my jba uca. but like said. torqing bolt at full droop cause bushing to tear. nothing actually "spins" with a rubber bushing. the rotation is simply the rubber stretching between the inner and outer sleeve. this applies to any rubber bushing for future reference. shock bushings, leaf springs, etc.
  4. Nov 23, 2021 at 4:34 AM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    This is true, I just pulled my LCAs to reapply grease and add the zerks, the whitelines still look brand new. They’ll probably last the rest of the truck’s life.
    Like I said, my case is anecdotal. I hear more positive stories about whiteline than negative.
    I do too! I started to think it was something else but every time I add more grease through the zerks the squeaks stop for a bit. Then they just come back, I don’t get it :annoyed:
  5. Nov 23, 2021 at 7:44 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Same. My Deavers and their supplied poly bushing like to make some racket but I can mitigate it as needed. The front is quiet.
  6. Nov 23, 2021 at 7:52 AM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    I had Moog lca bushings as well, 6 months in and they were done. Worse part is it cupped my 6 month old Firestones as well. I am running whitelines now.
  7. Nov 23, 2021 at 8:29 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    After only a month you either installed them wrong, or you'd be due for a refund/return. Even cheap shit shouldn't do that. Moog is cheap, but generally not garbage.
    I'd start with calling Rock Auto.
