Moog LCA's for 3rd Gens?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JonnyBTRD, May 8, 2025 at 4:36 AM.
  1. May 8, 2025 at 4:36 AM
    JonnyBTRD
    JonnyBTRD [OP] New Member
    Jon
    2017 White TRD Off Road
    Hey yall,
    I have a 2017 TRD OR with a 2.5in lift, dirt king UCA's and 33's. Im at 160K and my original OEM LCA's have finally went so I am looking to replace them. I do light off-roading but not very often, so I don't need any crazy high end LCA's. I just purchased a set of Moog LCA (link below to the specific SKU's) and am wondering if anyone else has any thoughts on these for the 3rd gens...? I have a 2017 TRD OR with a 2.5in lift, dirt king UCA's and 33's. I thought about going OEM but they're pretty stupid expensive, and also considered rebuilding my OEM ones but thought it would be worth going with new Moogs instead of the hassle.
    For anyone running them, did you need to get new OEM hardware for mounting?? (cam/caster)
    https://www.moog-suspension-parts.c...wrryIXf8Ts5RQ7_axYC76JDIWPyts0_UOFL6FMpE5KFuQ
    https://www.moog-suspension-parts.c...N68TK2PKYXeMOwSES95XAAASptN2igLx9tGAj25hiLxCp
  2. May 8, 2025 at 11:20 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    What went wrong with your arms? The bushings and ball joints are replaceable and much cheaper. It would be cheaper to buy a shop press and all the bushings than to replace the arm with chinese junk. Moog has really gone downhill lately with quality.
    TacoDell60 likes this.
  3. May 9, 2025 at 9:41 AM
    TacoDell60
    TacoDell60 Well-Known Member
    Why would you pair a high quality aftermarket UCA like DirtKing with a Chinese junk LCA? It doesn't make any sense.
    drizzoh likes this.
  4. May 9, 2025 at 12:32 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Funny timing and same truck, I’m getting some loud creaking that is either the lca or sway bar bushings, seems off for 68k.
    I have fox pes, deavers and accutune uca’s, and called accutune to see if they had any upgrade to the oem LAX’s….they said that the oem are good and what they designed around.
    I guess I’ll be looking to replace the lca bushings.
  5. May 9, 2025 at 12:36 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    If there is a poly upgrade available, I would upgrade to poly.
    Agreed that MOOG has been going downhill since they went international. Usually if a part that says MOOG all over it you're good to go, but if it's a random part that isn't branded then stay away.
    So many places these trucks can creak from up front, I've gave up trying to help diagnose those issues online lol. But helix if your suspension is that beefed, you have no reason for a front sway bar anyway. :)
  6. May 9, 2025 at 1:18 PM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    I just got through rebuilding my brother's lower control arms on his '07 Tacoma last weekend.
    He ended up giving the "affordable" complete LCA assemblies a miss, and purchased new OEM bushings and ball joints.
    He figured if the OEM products lasted 200k miles, why put anything else on.
    The job is straight forward, especially if you have a press (which we do). A press makes installing the new ball joints a breeze.
    Removing the bushings were straight forward as well...press them out, press in the new ones. The job is certainly doable without a press (bottle jack and vice will do the trick).
    Cheers
