Moog Lower Control Arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, May 12, 2017.
  1. May 12, 2017 at 6:49 AM
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Anybody have any experience with Moog LCAs? I got a feeling I'm going to need them soon. :(
  2. May 12, 2017 at 8:45 AM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    I have them on my rig, just installed about 3K miles ago, no issues at all Ended up using them to replace a set of Dorman LCAs that had 100K miles on them. I was going to upgrade into something like a ICON or something else much more expensive but I'm not jumping dirt hills or crawling over boulders or even tough trails (at least not on purpose). Figured if the OEM got me 100K miles each time around and are a 1/3 of the price, I'd be dumb to waste the $.
  3. May 12, 2017 at 8:51 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    My thinking too. Some upgraded tubular ones or something like that would be sweet, but way overkill for what my truck is doing. Just need a reliable truck that can handle some off road.
    My other thought is to go the poly bushings and rebuild my current arms. Just hate messing with bushings. It's a PITA to get them out and clean them up.
  4. May 12, 2017 at 8:54 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I have them. Couple thousand miles. They are fine so far I guess time will tell.
  5. May 12, 2017 at 9:11 AM
    azgunrunner
    George
    Arizona
    06 DCLB Sport
    I was going to change the bushings and do the whole poly thing too, but then I looked at the cost of the bushings and the time to swap them out or pay a shop to press them in and out.. By the time I was done, I figured I was within 20 bucks of just buying a Dorman or Moog. May not have the performance of the poly bushings but again, I got 100K miles out of the Dormans, so it's kind of a wash...
  6. May 12, 2017 at 9:19 AM
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
    I rebuilt my OEM LCA's. Used Moog bushings and they were garbage, they twisted in the control arm barrel. Swapped them out for OEM bushings and those seem to be doing okay. If I could do it all over again though I would have just bought the Moog LCA's and called it good. PITA to get everything pressed out, cleaned and painted, and then pressed back in.
  7. May 12, 2017 at 9:33 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    This is exactly why I went this route
  8. May 12, 2017 at 9:40 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    That's all good info guys thanks. Those Moog's look pretty solid.
    @azgunrunner, I'd be doing all the work myself. So will be saving more money than paying to have it done. You can rent the tools for it from most parts stores for next to nothing. But, like you said, time, that's my biggest issue. I've already installed three of my 5100s and dealing with all the rusty bolts and stuff, probably have spent 4 days after work working on them. Finally got the passenger side front shock in. Really discouraged me, when I found my alignment bolts and cams have issues. I'm less than thrilled about having to cut out my LCA. I guess the good thing is that it's only the front. I'm hoping the drivers side doesn't have the same problem. I so wish the original owner of my truck would have put a little more time and thought into the truck. They did at least undercoat everything, so most everything is in great shape. Doesn't look like the toe adjuster seizing could have ever been stopped, unless they took it out as soon as they got the truck and greased it up. But, $100 for a full poly kit from Energy Suspension should improve things I think. I'm also going to change the sway bar bushings to poly while I'm at it and have the skid plate off. That should be a pretty simple job. Remove four bolts, replace bushing, and torque back on. Then enjoy frosty delicious beverage.
    RJ_MacReady likes this.
  9. May 12, 2017 at 12:15 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    I have them with about 5k miles. So far so good.
  10. May 12, 2017 at 4:04 PM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Hmm $100 or so -- Not bad :popcorn:
    TireFire likes this.
  11. May 12, 2017 at 10:01 PM
    NelsonLt1
    NelsonLt1 Member
    Luke
    Seabrook, TEXAS
    '10 TRD Double
    some
    Where is the best(cheapest) place to pick a set of these up?
  12. Jun 29, 2017 at 10:37 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I'll 2nd that. Found my lower arm bushings are cracked so I've been trying to decide my path. Figure replacing the whole arm will be faster and easier.
  13. Jun 29, 2017 at 10:43 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    I just got some off rockauto for $100 each.
    Elwing, Pirhett and Benzdriver81 like this.
  14. Jun 29, 2017 at 10:47 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    my alignment cams are toast from rust. thinking this might be the easy way out just to buy whole new lcas
  15. Jun 29, 2017 at 12:22 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    One thing to remember if you're getting the Moog LCA's is they only come with the castle nut and pin for the ball joint. They do not come with the bolts and nuts for mounting (cam/caster). You are suppose to reuse stock, or get new ones.
    REDdawn6 and coopcooper like this.
  16. Jun 29, 2017 at 1:11 PM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    Have a good source for cam/castor bolts?
  17. Jun 29, 2017 at 1:16 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I got mine from the dealer but they are expensive!
    bski22 and fatfurious2 like this.
  18. Jun 29, 2017 at 1:19 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Oem only
    The others I have seen look ghetto
    singletrack_ftw and KenLyns like this.
  19. Jun 29, 2017 at 2:05 PM
    SpeedoJosh
    Florida
    I wish I did. I searched the forums, and all the third party vendors have poor long term reviews. Dealer has them, but it's expensive. Just one bolt was $11 to give you an idea. I got lucky and snagged a pair of LCAs and hardware from a junk yard for $100. Just going to use the hardware, and save the LCAs as back up.
  20. Jun 30, 2017 at 1:23 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Just installed Dorman LCA's from RockAuto. Best price I could find including Amazon, and I'm a Prime member.
    Got them as I couldn't afford downtime with my truck. Passenger side front cam was rusted frozen and had to cut it out with my reciprocating saw. Used the recommended Freud Diablo blade and it cut like butter, relatively speaking. Replaced both front cams with Febest 0132-005; all other bolts/sleeves were re-used.
    Have started rebuilding the OEM LCA's myself with Moog BJ's and Mevotech bushings. If you have cups from a BJ and/or wheel bearing kit, you can replace the bushings yourself. If you don't have a press; you'll need a BJ C-clamp. The Mevotech bushings press in nice and tight whereas the Moogs went in too easy. I had read the front Moogs slide out; so, I got Moogs for the rear and Mevotechs for the front. Well, the Moogs pressed in too easy for comfort. Gonna remove them and go Mevotech all around. I contacted the manufacturer who said their bushings are a proprietary rubber/poly compound. They are made in Taiwan but look very well made. The Moogs are made in China.
    The Moog BJs are made in the USA and have zerks for greasing. The issue with the Moog BJs is they have a 2.5" diameter 'ring'. This means you need a hard to find 2.5" ID tube if you ever want to press out the Moog BJ's. No one seems to make that size cup; so I had to get pieces cut at a metal supply shop.
    habaneroTrd and Tepster like this.
