Moog Lower Control Arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, May 12, 2017.
  1. Jul 6, 2017 at 4:08 PM
    #41
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    PM @gunny1005
    gunny1005 likes this.
  2. Jul 9, 2017 at 11:09 PM
    #42
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Replacing my LCAs with a set from TC just waiting on new ones to arrive and then make time for install. Itll probably be 2-3 but you can buy mine if youd like. 113k on them right now. Would likely need rebuild though. PM me if you're interested
    #42
    PapaBear[QUOTED] likes this.
  3. Jul 10, 2017 at 8:26 AM
    #43
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    @BadDNA ^^ might be selling them.
    BadDNA likes this.
  4. Jul 10, 2017 at 8:29 AM
    #44
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I'm also looking for a set of LCAs if anyone's got some spares kicking around. I can get them at a few local recycling yards for $100-$150 each so I'd be interested in something a little less expensive.
  5. Jul 10, 2017 at 9:04 AM
    #45
    ProForce
    Anthony
    Alaska
    Some people realize that the Moog ball joints and bushings don't last, so they'd rather get oem arms and rebuild them. Yes it's more work but will significantly outlast the moog arms. Even to buy new moog arms and just rebuild them with oem bushings and or ball joints you're still gonna put in the same amount of work so why not rebuild an oem arm. Hence why people are looking for used take offs.
    BadDNA and Bruce988jl like this.
  6. Jul 10, 2017 at 9:22 AM
    #46
    ProForce
    Anthony
    Alaska
    Getting a little defensive over a simple observation. You've been on the forum 3 months, relax a bit. Not everyone has to do it your way.
    camdenthekid likes this.
  7. Jul 10, 2017 at 9:26 AM
    #47
    Muddinfun
    Muddinfun Well-Known Member
    OK, I concede. You win.
  8. Jul 10, 2017 at 9:27 AM
    #48
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Good to know. I took my LCA's off when the truck had 40k on it just to clean and lube the cam hardware and inspect the bushings. Only an extra 15-20 min if your taking shocks off. So far so good. If you haven't done that don't wait till everything seizes up! I think I'll go with the Moog assembly as I'm starting to hear some noise when hitting bumps hard. When I do I'll either rebuild or sell the stock LCA's. Only 67k right now though.
  9. Jul 10, 2017 at 11:31 AM
    #49
    ProForce
    Anthony
    Alaska
    Wasnt trying to get into a pissing match with you or say you are wrong, was just trying to explain the thought process behind some people wanting OEM arms thats all. It wasnt about "winning" you just came off a bit defense over a simple reply. Some dont mind spending more money then necessary and more work then necessary just to know they have OEM parts without going oem replacement from the dealer. Its not always about what the cheapest option is. Im sure many greatly appreciate your input though.
  10. Jul 10, 2017 at 12:09 PM
    #50
    BadDNA
    Eammon
    Cabot, VT
    This^^^
    I do appreciate the alternate option. If I'd done more reading up front, I wouldn't have put the MOOG bushings in my OE arms. Now that I have, and they're popping all the time, I'm looking for a second set of OE arms to reinforce and seal up, install some Whiteline bushings and ProForged ball joints into before installing back into the truck to never worry about again. Second set because my truck is my daily driver and I can't have it down while I do any work to it.
  11. Jul 10, 2017 at 1:26 PM
    #51
    ProForce
    Anthony
    Alaska
    @BadDNA ill have my OEM set off in a few weeks since im installing TC lowers. Im sure bushings and balljoints will nees to be replaced so if that's the plan anyways then ill have what you're looking for. Ill message you once they are off the truck see if you're still interested
    BadDNA likes this.
  12. Jul 10, 2017 at 1:29 PM
    #52
    BadDNA
    Eammon
    Cabot, VT
    Please do. I appreciate it.
  13. Jul 10, 2017 at 3:03 PM
    #53
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    I'm interested. I'll pm. Pics when you can.
    ProForce[QUOTED] likes this.
  14. Jul 10, 2017 at 7:40 PM
    #54
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I have a 5 lug but I've been on some Mevotech Supreme LCA for a little bit now. Greased them and then ran them a bit then added a bit more grease. Been fine so far and I drive like an idiot.
  15. Dec 23, 2017 at 11:13 AM
    #55
    Drew12
    Drew12 Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    Got my moog complete LCAs and just picked up all new hardware for them from the dealer. DAMN that stuff is expensive but looks much higher quality than any aftermarket brand. I think the difference is that there are channels on each side of the bolts that the tabs fit onto. This design must greatly decrease the chances of rounding them out like the aftermarket ones. Its expensive, but I think worth it to not have to mess with it again. What kind of grease do you guys recommend for the hardware?
  16. Dec 23, 2017 at 2:13 PM
    #56
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Did this same setup last weekend. I just lined everything with wheel bearing grease, except for the surface of the cams against the adjustment plate in case the grease makes it easier to bump out of alignment.
  17. Dec 23, 2017 at 2:27 PM
    #57
    Drew12
    Andrew
    Sisters, Oregon
    Awesome! Ill do the same. Did you use moog lowers and Toyota hardware?
  18. Dec 23, 2017 at 2:38 PM
    #58
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Yup! Everything fit together nicely and I expect it to last just as long as the oem arms. One tip, tighten the caster/camber bolts after you let the truck off your jack stands.
  19. Dec 24, 2017 at 9:51 AM
    #59
    Drew12
    Andrew
    Sisters, Oregon
    Awesome. Does that just make sure you don’t over tighten? Also, I was test fitting all the bolts and what not into the lowers last night and noticed that it’s not a super snug fit like you’d expect. You could rattle them around in the bushings slightly. This normal?
  20. Dec 24, 2017 at 10:14 AM
    #60
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Just so the control arm bushings are compressed in a neutral position, rather than under tension all the time.
    Mine were like that too, even when I took the hardware out of the old ones, they were the same. Once everything is tightened properly it's solid.
