Moog Lower Control Arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, May 12, 2017.
  1. Feb 14, 2022 at 4:14 PM
    #121
    MACKT28
    MACKT28 Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Absolutely. Just know that getting those uppers off are a pain but once off getting the new ones on is a piece of cake
    my2coma[QUOTED] likes this.
  2. Feb 14, 2022 at 6:21 PM
    #122
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    I believe the bushings on the Moog LCA assemblies are NOT replaceable, and instead requires that you replace the whole LCA assembly since they are basically just cheap throwaways. Moog does however make replacement bushings for the OEM LCAs.
  3. Feb 14, 2022 at 6:46 PM
    #123
    TacoTuesday1
    SD CA
    update
    apparently they might be the wrong shape and messing up my alignment
  4. Feb 14, 2022 at 6:50 PM
    #124
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    Thanks for the reply. I thought that might be the case.
    Fortunately I still have my OEM LCAs, maybe I'll just leisurely rebuild those...
  5. Feb 15, 2022 at 6:08 AM
    #125
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    The oem LCA's aren't hard to rebuild, I have rebuild mine two times over by now. I ran pro-forged ball joints and those boots failed after like 30k to I went with Moog ball joints. I pressed in the whiteline bushing set with the initial rebuild and keep them thoroughly coated in never-seize yearly so the alignment hardware never freezes up. Pressing the ball joints out/in is a bitch and even harder with those c-clamp style kits so I use a 20 ton shop press I have access to.
    Tectonic[QUOTED] and my2coma like this.
  6. Feb 15, 2022 at 10:41 AM
    #126
    my2coma
    my2coma Active Member
    Jim
    Republic of Texas
    97 Tacoma 4x4 ext cab
    ARB front bumper, custom rear bumper, sliders, 4" lift, OME shocks, TRD e-locker rear axle, K&N cold air intake, Cobra CB, PIAA lights up front, Budbuilt skid plate, and several other goodies.....
    That sux!
  7. Feb 15, 2022 at 1:18 PM
    #127
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    My Dorman LCAs are starting to snap crackle and pop. I too kept my oem LCAs and will rebuild them. Then take apart the Dormans to see if they are rebuildable. I got what I expected out of them, about five years. The BJs I had to replace within a year though.
    Tectonic[QUOTED] likes this.
  8. Oct 26, 2022 at 10:52 AM
    #128
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    Bumping this because i am going to need new control arms. I understand there is much hate for the Moog pieces...but are the Napa lower control arms good? For the price I would expect them to be better than Moog.
  9. Oct 26, 2022 at 11:00 AM
    #129
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    In my research go with the premium "CK" Moog or ACDelco.
  10. Oct 26, 2022 at 11:16 AM
    #130
    bryanh69
    The CK stuff is listed on the MOOG website but actually trying to buy it....that is a different story. The RK stuff seems to be available.
    Guess I will try the ACDelco stuff.
  11. Oct 26, 2022 at 12:00 PM
    #131
    BusyBee212
    BusyBee212 Member
    Doug
    2010 Tacoma 4x4 2.7L
    The only difference I found between the CK and RK was the ball joint, cheaper one has no grease fitting. I installed the Moog arms a few thousand miles ago without a grease fitting. They seem fine and look just like OEM. You can always get the better ball joint in the future and put it in. Just make sure that you torque the control arms when the suspension is under load not jacked up.
  12. Oct 26, 2022 at 12:59 PM
    #132
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Try Rockauto.com
    BusyBee212 likes this.
  13. Jun 24, 2023 at 7:21 PM
    #133
    Rooivalk16
    Rooivalk16 New Member
    2011 Tacoma Access Cab, base.
    Question for those with Moog lowers. I recently purchased a set of Moog RK line LCAs and there was a grease fitting inside the package. Should I just use that to fill the ball joint then remove it, or does it stay installed?
    I may be doing something wrong but there seems to be a clearance issue.
