MOOG Part #K100128 Problem Solver Caster / Camber Cam Bolt Kit
Discussion in 'RockAuto' started by tcBob, Feb 21, 2014.
  1. Feb 25, 2015 at 9:50 AM
    #181
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    make it slippery as well :notsure: idk all the benefits
  2. Feb 25, 2015 at 12:13 PM
    #182
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I think it'll do well. I'll keep updating my build as the years go and alignments happen.
  3. Feb 25, 2015 at 10:17 PM
    #183
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    There's a theory the grease will be less likely to wash out than antiseize if you go off road often and submerge the joints in water. However, my concern is the grease will dry out on its own after a couple of years.
  4. Feb 26, 2015 at 5:49 AM
    #184
    Sandman614
    Tim
    '06 SR5 Off Road
    The thought is to regrease once a year.
  5. Feb 26, 2015 at 8:05 AM
    #185
    KenLyns
    Belly of the Beast
    ^That is too burdensome for a joint where the greased interface doesn't see rotation when the suspension cycles.
  6. Mar 2, 2015 at 9:22 AM
    #186
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    So you say regreasing once a year is no good?
  7. Mar 2, 2015 at 12:40 PM
    #187
    Wpg07TRD
    Wpg07TRD Canadian Member
    Neal
    Winnipeg
    '07 TRD Sport, DCLB
    5100s and 885x coils, Trail Gear Add-A-Leafs/5125s, interior light LED swap, rcbs204 illuminated 4x4 switch
    Could anyone send me a copy of the installation instructions for this kit? I got 2 kits with all the correct parts, but no installation instructions. A pic of each page would be awesome!
  8. Mar 3, 2015 at 1:14 PM
    #188
    MTopp
    05 SR5 4x4
    I doesn't has these, but BuMp for ya
  9. Mar 3, 2015 at 7:41 PM
    #189
    Bonomonster
    Bonomonster Well-Known Member
    Albany NY
    2007 FJ Cruiser
    3" lift, Skids, Sliders, 33" tires
    I have this if it helps.
    I'll check to see if I have the full instructions around.
  10. Mar 3, 2015 at 9:27 PM
    #190
    Wpg07TRD
    Neal
    Winnipeg
    '07 TRD Sport, DCLB
    Thanks for that! It at least shows which one goes where. Still would like to take a peak over the whole thing if you can find it. I can't believe it's so hard to find these instructions. Haha. Even the Google machine couldn't help me so far!
  11. Mar 4, 2015 at 9:39 AM
    #191
    MTopp
    05 SR5 4x4
    Yeah, that's kinda ridiculous
  12. Mar 5, 2015 at 8:57 AM
    #192
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Just installed mine, that is all there is, not really any thing else needed besides the assembly order. Torque to 100 ft*lbs.
  13. Mar 5, 2015 at 8:59 AM
    #193
    Sandman614
    Tim
    '06 SR5 Off Road
    SPC says 150 ft*lbs for theirs, dunno if it makes a big difference.
  14. Mar 5, 2015 at 9:00 AM
    #194
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  15. Mar 5, 2015 at 9:25 AM
    #195
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Hmm. That was the factory spec, didn't see one for Moog specifically.
  16. Mar 6, 2015 at 5:49 AM
    #196
    Wpg07TRD
    Neal
    Winnipeg
    '07 TRD Sport, DCLB
    I think I'm going to try to get my old bolts out this weekend. I've got to get my truck in for an alignment! Hopefully all goes well!
  17. Mar 6, 2015 at 2:05 PM
    #197
    MTopp
    05 SR5 4x4
    Good luck! ::
  18. Mar 15, 2015 at 12:07 PM
    #198
    BCTRD
    BCTRD Well-Known Member
    Drew
    Kelowna, BC
    2008 TRD SPORT
    ok I'm just trying to figure this all out... you can take out the LCA bolts and put them back in and not have to get truck aligned ?
    thanks.
  19. Mar 15, 2015 at 12:17 PM
    #199
    Sandman614
    Tim
    '06 SR5 Off Road
    Potentially. Mark you're tabs and do one at a time and torque after.
  20. Mar 15, 2015 at 12:33 PM
    #200
    BCTRD
    Drew
    Kelowna, BC
    2008 TRD SPORT
    Great thanks,
    also I noticed my cam/bolts on the passenger side front have slid over and flattened my cam alignment tabs... SO id like to pull the bolts and bent them back up and reinstall the bolts...
    my question is, If I put the truck on jack stands then pull the bolt on the front of the control arm will I be able to man handle the arm and move it over so its in place where I can reinstall the bolt after I bend up the cam tabs??? or will I have to loosen or remove the rear control arm bolts to be able to move the arm slightly?
