MOOG Part #K100128 Problem Solver Caster / Camber Cam Bolt Kit
Discussion in 'RockAuto' started by tcBob, Feb 21, 2014.
  1. May 20, 2015 at 9:27 PM
    #241
    BCTRD
    BCTRD Well-Known Member
    Drew
    Kelowna, BC
    2008 TRD SPORT
    Thank you! yes too much work. happy its over haha.
  2. Jun 17, 2015 at 7:36 AM
    #242
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    nj636 likes this.
  3. Jun 18, 2015 at 5:36 PM
    #243
    Sommes
    Sommes Active Member
    Canada
    08 Mica TRD OFF-ROAD
    Just read this entire thread, thinking of doing a 3 inch OME lift and am now terrified to check out the condition of my CAM bolts... Being up here in the north makes me know im doomed...
    Good work BCTRD.
  4. Jun 19, 2015 at 4:29 AM
    #244
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    nothing to be terrified of. If the bolts are seized I would say as of right now your best bet is to burn the old bushings out & install the Energy Suspension kit or install OEM bushings.
    V5ioV likes this.
  5. Jun 27, 2015 at 6:39 PM
    #245
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'll be pulling these piece of shit cam bolts out and installing OEM ones in the near future. Got an alignment prior to heading to Uwharrie last weekend & the drivers side is now rounded out. :frusty:
    People: Go OEM for this. Moog's kit is garbage.
  6. Jun 27, 2015 at 6:40 PM
    #246
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Yes, I'll post pics once I swap them out.
    Fortunately I've got a very good alignment guy & the truck drives straight for now.
  7. Jun 27, 2015 at 6:42 PM
    #247
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    SPC alignment bolts have lasted so far. I'll keep an eye on em.
  8. Jun 27, 2015 at 8:29 PM
    #248
    Bonomonster
    Bonomonster Well-Known Member
    Albany NY
    2007 FJ Cruiser
    3" lift, Skids, Sliders, 33" tires
    I've had both sets in my hands, and the factory parts are far superior. I had several issues trying to get a matching Moog set.
  9. Jun 27, 2015 at 8:30 PM
    #249
    Sandman614
    Tim
    '06 SR5 Off Road
    I've not had the moog side by side with SPC. I don't know anyone that has.
  10. Jun 28, 2015 at 7:12 AM
    #250
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I honestly don't know...
    Understand my entire front suspension is brand new as of last August when these were installed and I've driven less that 10K on it since then.
    This should not happen and the Moog parts are garbage.
  11. Jun 29, 2015 at 7:46 PM
    #251
    nj636
    Kev
    Jersey
    I am losing faith in Moog :frusty:
    Sandman614 likes this.
  12. Jun 29, 2015 at 8:32 PM
    #252
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Already gone...
  13. Jun 29, 2015 at 8:48 PM
    #253
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    unsubscribe
  14. Jun 30, 2015 at 10:14 PM
    #254
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Mine is also gone after round 2 of failure
  15. Jul 2, 2015 at 2:03 PM
    #255
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I've had problems with Moog products in my wife's car too. I have gone through 3 sets of sway bar end links and each time the joint completely separate. That's not THAT big of a deal on a sway bar but imagine if one of these camber bolts completely failed like the parts in my wife's car. That's why I refuse to but the new version of Camburg A-Arms.
  16. Jul 2, 2015 at 2:49 PM
    #256
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Nah; they have the Moog parts in them as well. I just wish I could get a set of the 1st gen Camburg arms but I called them and they are all out of them. :( I have a set of low mileage arms that I can press the ball joints out of.
  17. Jul 2, 2015 at 4:23 PM
    #257
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    My issue is with the bolts. I've got Moog tie rod ends and do not have any issues there.
  18. Jul 2, 2015 at 8:43 PM
    #258
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I had read about those some time ago but I don't think I ever saw a picture of them. Wow they are big
    I know I was just stating my problem with Moog even though it's another product. I'll round up a picture to show whats been happening to them.
  19. Jul 2, 2015 at 8:51 PM
    #259
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    This is caused by incorrect or incompetent alignment procedure
    The rear bolt must be loosened before u crank the fronts to move them or corrosion due to improper maintenance
    Bolts should never be an issue
    Period
    32k on mine now and jot a problem
    And
    F u guys
    Problem with the bolts happens when someone with little to no knowledge tries to loosen the head of bolt
  20. Jul 3, 2015 at 6:34 AM
    #260
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    They are still crap Scott :p
