MOOG Part #K100128 Problem Solver Caster / Camber Cam Bolt Kit
Discussion in 'RockAuto' started by tcBob, Feb 21, 2014.
  1. Jul 3, 2015 at 11:12 AM
    #261
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Moog lower ball joints & inner/outer tie rods have been holding up quite well.
    I never got the chance to try the bolts/cams because they kept sending me the original kit that didn't work
  2. Jul 15, 2015 at 12:33 PM
    #262
    Kyle_D
    Kyle_D New Member
    Used a set of these LCA bolts from RockAuto and I'm curious about the rounding. They are being used in a 04' 4Runner, and are compatible according to Moog.
    After installation and about 40 miles of driving, I began noticing some clunking on the drivers side when braking or accelerating. If I stopped, the clunk would happen. It would happen again if I accelerated from a stop, but wouldn't happen again until I stopped. I inspected it on the alignment rack, and noticed that the rearward LCA bolt was actually sliding axially (front and back, not side to side as indicated by a failed bushing). Tightened the bolt beyond what I was comfortable with, and the clunk went away.
    Drove another 500 miles, and started getting the clunk back. It is intermittent at this point, and is now occurring on both sides. What gives?! Are these bolts stretching or what? If the cam is rounded, would it cause this issue?
    I will be contacting Moog today.
    -Kyle
  3. Jul 15, 2015 at 7:58 PM
    #263
    Kyle_D
    Kyle_D New Member
    Talked to them, and they don't have a torque spec beyond the OE, which is 103 ft/lbs IIRC. They are torqued well beyond that, and I am absolutely stumped as to how these bolts can move forward and back like this.
  4. Jul 16, 2015 at 4:24 AM
    #264
    nj636
    Kev
    Jersey
    Are you using the Moog LCA bushing as well?
  5. Aug 17, 2015 at 4:56 AM
    #265
    nj636
    Kev
    Jersey
  6. Jan 24, 2016 at 7:47 AM
    #266
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Revive a thread!
    It sounds like your lower control arm bushings need replacing...
  7. Feb 16, 2016 at 5:51 PM
    #267
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    so i've had an issue with my right side wheel camber being a lot more positive than the driver's side (which if fine). after taken to dealership for alignment and inspection, they said that the camber bolts were maxed out. i was wondering how they managed to get one side to factory spec and the other, not. would new camber bolts with washers help?
  8. Feb 16, 2016 at 8:38 PM
    #268
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'm swapping out this product back to stock LCA cam bolts. Once I do I'll post up pics of the Moog ones.
    I'd never recommend these to anyone - the design is shitty.
  9. Feb 16, 2016 at 9:22 PM
    #269
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I went back to stock bolts too. On account of Toyota not putting my SPC bolts back in lol.
  10. Feb 21, 2016 at 3:31 PM
    #270
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Sure, go ahead and get this product. Here's what happens:
    Swapped out to OEM - coated them in anti-seize prior to installation.
    scocar and Large like this.
  11. Feb 21, 2016 at 4:47 PM
    #271
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Mine have been holding up good so far... (no seize yet that it) but I guess the day I have to remove them to weld cam tabs I'll have a better report to provide
  12. Feb 26, 2016 at 7:23 PM
    #272
    pseudomike
    pseudomike Well-Known Member
    Michael LaValley
    2012 DCLB TRD Sport
    I had this bolt kit on my old Tacoma. I too had a washer round out...happened right after I watched the tech but the impact gun to the bolt side. Probably had 3 alignments prior to no issues. If your washers are rounding out from driving you have much larger issues as there should be not rotational force on them once installed and torqued.
  13. Mar 6, 2016 at 8:27 AM
    #273
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    Still don't see how spc bolts are crap.....
    36+k on mine and fine
    I can see user error being a problem if one does not know how they function
    And I am no spc fan
  14. Mar 6, 2016 at 11:32 AM
    #274
    Large
    Large Red
    DB .. sawzall to the rescue
  15. Apr 18, 2016 at 7:29 AM
    #275
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    So is there any sort of consensus here? I'm changing out the bushing here in a couple weeks. Thinking I need new alignment cams as well. Which one should I be grabbing? Dealer hasn't called me back with a price on the oem toyota ones.
  16. Apr 18, 2016 at 7:32 AM
    #276
    Sandman614
    Tim
    '06 SR5 Off Road
    If you want aftermarket get the SPC bolts, Moog==garbage, most people seem to revert back to factory.
  17. Apr 18, 2016 at 7:34 AM
    #277
    TacoBurrito07
    Jake
    Arizona
    I'm just not sure I'll be able to reuse my factory ones. I think they are seized in the bushing but I don't know for sure. I just know the bushings are shot so I'm replacing those. Anybody have a part number for the factory bolts?
    Also, is that SPC set for both sides or just one?
  18. Apr 18, 2016 at 7:36 AM
    #278
    Large
    Large Red
    If you're swapping the bushings just swap the bolts too. Better to do it all at once IMO.
    TacoBurrito07[QUOTED] likes this.
  19. Nov 20, 2016 at 10:28 AM
    #279
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  20. Nov 22, 2016 at 2:17 PM
    #280
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    Good looking out man, I definitely do.
