MOOG Part #K100128 Problem Solver Caster / Camber Cam Bolt Kit
Discussion in 'RockAuto' started by tcBob, Feb 21, 2014.
  1. Oct 26, 2017 at 10:21 AM
    #301
    jrp5143
    jrp5143 New Member
    2009 Tacoma
    3'' front coil over, 2.5'' rear 17'' XD Holeshot Rims sitting on 285/70/17 Nitto AT2's
    After spending about a week trying to get the cam bolts out (I got the front 2 however the sleeves stayed in the bushing so really didn't matter), I bit the bullet and cut my LCA's out. I'm picking up the parts today (all new bushings, adjusters, bolts w/sleeves). I'll try to post the parts list when I get it from the dealer since I saw a few of the parts numbers posted earlier in this forum didn't match all of my bushing numbers. The question I have concerns the lubrication. Anyone have suggestions on what is best to use when installing? I was thinking about it the other night and fluid film came to mind. I hadn't heard of people using them for the cam bolts however I use it for undercoating and know people who swear by it for lubrication of other bolts. My only concern is that I know it can cause swelling in certain types of rubbers. I also have anti-seize, white lightning, and would be willing to go buy something else if it works. Any suggestions on what's best? I certainly don't want to have to do this again. Thanks.
  2. Oct 26, 2017 at 10:36 AM
    #302
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Regarding Fluid Film, I don't think it would be ideal. It's not the most tenacious stuff, it would wash out pretty quickly. I'd use anti-seize or ultra tacky grease (like Aeroshell, I have a tube of it from a winch rebuild, expensive but incredible grease). I'd spray Fluid Film all over after installation, it does creep a little and would shield the joint. The only place beside frames I've found Fluid Film works well is as anti-corrosion on electrical connections on the battery. It's not bad there, but even that Anti-Ox, copper anti-seize or dielectric grease is better.
  3. Nov 1, 2017 at 6:37 PM
    #303
    JRSCALIFONTA1
    JRSCALIFONTA1 New Member
    Hr
    Spc dont work ither i went through the same problems like the moogs did
  4. Dec 16, 2017 at 5:57 AM
    #304
    Drew12
    Drew12 Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    Hey Guys, I am going to be pulling both my LCAs to replace bushings and all hardware. Reading all of the horror stories about MOOG, I will go with the OEM bolts and tabs.. That being said, I am not sure if anything is seized, but should I just buy all of the hardware to have on hand if indeed there are some seized parts? Probably good to replace anyways.. Also, will probably go with ultra tacky for greasing them up - what are the areas that need to be greased? the entire shaft of the bolt? Anywhere else?
    I will also be going with the whiteline bushing set (W53312) since I have heard great things about those, and they are $135 on Amazon for a complete kit (both sides). Anyone have anything to say about the whitelines? Looks like they come with all of the proper hardware (washers, sleeves, etc. but their picture only has 3 sleeves included - how many should there be?)
    Will be buying the MOOG ball joints since I will have the arms off anyways. Going with Moog K80827. If there are better joints out there for a similar price please let me know. This is adding up to be a spendy, time consuming job so I just want to get it right the first time. Any input would be GREATLY appreciated!
    Kolunatic likes this.
  5. Dec 16, 2017 at 7:21 AM
    #305
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I've bean on the computer now for hour debating weather to replace the bushings with oem bushing and using a moog lower ball joint or just spending the extra $300 and getting the complete oem lower control arm. Either way I am sticking with oem cam bolts.
  6. Dec 16, 2017 at 7:26 AM
    #306
    Drew12
    Andrew
    Sisters, Oregon
    I feel ya man. All of the days of researching is getting to be a headache. I am kind of in the same boat with you about just pulling the trigger on new arms with OEM shit already installed. Then getting new cam bolts and what not and calling it a day. Would save tons of time. Then I guess you could work on replacing the bushings and ball joints with new stuff and selling them here on TW. Sell them for slightly cheaper than dealer and re-coup some $$
    All I know is that I have a horrendous clicking noise coming from my drivers rear cam and its driving me freaking nuts. Just want to get this problem dealt with quick.
  7. Dec 16, 2017 at 7:39 AM
    #307
    jrzyshore
    Scott
    SNJ
    I was thinking about that too. You would be spending a couple hours pressing ball joints and bushings. I need new tires and the old tires are destroyed from the alignment not being correct due to frozen cam bolts. I also have 98k on my truck and this year I've replace the front eibach springs with a set of Icons and replaces all the bushings and the uni balls on my TC uca's. After I am done everything should be close to new.
  8. Dec 16, 2017 at 8:03 AM
    #308
    Drew12
    Andrew
    Sisters, Oregon
    Well atleast youll have a whole new suspension/tire setup after that. Ive recently done the same with my suspension. New uniballs/bushings on the UCAs, wheel bearings/seals, eibach coils/5100s... But now for these dam LCAs. Cant wait to get those all squared away so then Ill have an all new setup as well. My alignments have been fine so far and went in the other day to have it checked and its right where it was in august when I put new suspension parts in. My question is: do you think my cams are frozen? Or the mere fact that they can re-align means they are not? They dont use salt on the roads here in Oregon - instead they use cinder/sand type material. And the truck was in CA for most of its life. I just developed this clicking noise whenever I drive and have isolated it to the LCA. I just wonder what is causing that noise? Its driving me nuts.
  9. Dec 16, 2017 at 8:40 AM
    #309
    jrzyshore
    Scott
    SNJ
    Your cam bolts may be fine. A bad ball joint can develope a click over time. It probably wouldn't hurt to replace the bushings. Here on the East Coast "The Salt Belt" cam bolts are prone to seizing. Usually everything gets a nice coat of anti seized.
  10. Dec 16, 2017 at 9:07 AM
    #310
    Drew12
    Andrew
    Sisters, Oregon
    Gotchya. Will definitely be changing the joints while I am at it but I stuck my phone right under the lca cams and bounced the truck up and down. Click comes from the rear drivers cam I just dont understand why. Regardless I will change the bushings/cams but for now I am just stumped.
  11. Feb 7, 2018 at 1:01 PM
    #311
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I recently did the install with the Moog greaseable cambolt kit. 1 kit is good for one side so I ordered 2 kits. They had the front and rear bolt. The cam disc had these markings:
    Fronts: 826-2
    Rears: 826-8
  12. Mar 20, 2018 at 2:53 PM
    #312
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    update
    now have 60k on my bolt kit and moog bushings
    seem ok to me
    pro tip :dont let people who do not know what they are doing touch your truck
    DoorDing likes this.
  13. Mar 20, 2018 at 2:54 PM
    #313
    jrzyshore
    Scott
    SNJ
    :bananadead:
  14. Mar 31, 2018 at 1:46 PM
    #314
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Oh how I know that feel. :(
    scottalot and DoorDing like this.
  15. Mar 31, 2018 at 2:50 PM
    #315
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Nope. Oem and a bunch of anti-seize is the way to go.
  16. May 3, 2018 at 9:15 AM
    #316
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
    Where do you apple the anti-seize? Just found out mine are seized. The way I understand it the bolt is seized to the sleeve?
  17. Aug 7, 2018 at 11:02 PM
    #317
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Update: Moog has replace these free of charge multiple times for the same issues. Stick with a anti-seized/greased OEM setup! I switched back to OEM this last weekend after 3 sets failing the same way OP stated. Do not buy these.
    lo2hi and DoorDing like this.
  18. May 6, 2019 at 5:28 AM
    #318
    gti2taco
    gti2taco Well-Known Member
    Brian
    Va Beach
    14 trd offroad, stock
    subbed so I can read more about this.
  19. Sep 25, 2019 at 2:48 PM
    #319
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    15+ alignments, 3 sets of LCA's, same moog cam bolts :)
