MOOG Tie-Rod Ends vs OEM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Oct 13, 2015.
  1. Oct 13, 2015 at 6:36 PM
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I recently replaced the TREs (Tie-rod ends) on both sides. I used the Moog Part # ES80895, since they are greasable, and Moog has a good reputation.
    I immediately noticed how tall the boot is compared to the OEM boot. I didn't think much of it at the time, so I filled them with grease and swapped them out.
    After torque'ing them down to 67 ft.-lbs, the boots did not bellow out and just smashed down. Less than 2 weeks later, one of the (Moog) boots has split completely, and I'm suspecting this is due to how compressed the boot is.
    Why is this happening?! This seems like a design flaw to me, especially with how much taller the Moog boots are compared to OEM - that rubber has to go somewhere when torqued down, and it just puts extra strain on the boot itself.
    I was shipped a replacement TRE, but I am hesitant to swap it out if the same thing will happen again. I've had the OEM ones on there for 65k with no torn boots.
    Here are some comparison pics of OEM vs MOOG. Notice when I compress the boot it collapses and does not bellow out/expand. Same thing happens when I torque them down:
    Pass. Side - Moog Boot split within 2 weeks of install.
    Drive's Side
    Has this happened to anyone else? Any suggestions what I should do, i.e. - add air to the boot, more grease, contact Moog directly?
    Crom likes this.
  2. Oct 13, 2015 at 6:48 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    That boot looks like it would crack from the get go seeing how tall it is without any creases for it to fold at. I went with OEM and I haven't had a problem after a few thousand miles.
  3. Oct 13, 2015 at 6:54 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I have the MOOG TREs as a spare set...seeing this they will only be a spare set until I can get an OEM part. Not sure why that boot is so tall.
  4. Oct 13, 2015 at 7:22 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I recently replaced Jasmines inner tre's on her 4runner with a pair of these. These are definitely better quality the OEM. I ordered from Parts Masters and got super lucky that they were inside the box. I guess Parts Masters is just like ordering stuff from Beck Arnely that they usually will have the OEM version packaged in their branded boxes and for a lot cheaper then ordering from the dealership..
    Crom likes this.
  5. Oct 13, 2015 at 8:18 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Any other pictures of these?
    Crom likes this.
  6. Oct 13, 2015 at 8:26 PM
    MonkeyProof
    SoCal- SGV
    20151008_102122.jpgonly this one lol..
    Crom likes this.
  7. Oct 13, 2015 at 8:59 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Lol that one is so much better.
  8. Oct 13, 2015 at 9:57 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I know we already talked about this a bit but after reading your post one thing came to mind... I didn't grease mine till after they where installed. I've ran mine for more then 10k miles with no issue and they're small and ballooned out with grease(which you probably noticed when looking at them).
    Benson X[OP] likes this.
  9. Oct 14, 2015 at 6:30 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    I was thinking about this as well. I wonder how well they would do if greased after they were installed. It seems like if you install them, the boot will compress some to sort of seal itself. Then grease it up. If it's greased before installing then the boot can't really compress and it just splurges all over the place. This does make me nervous about buying Moog though. I've always heard better things about them and an considering buying their ball joints.
  10. Oct 14, 2015 at 12:06 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Nick! That's the only other thing I could think of - shove more grease in there until they are bloated and obese!
    I might send this info. to Moog as well to see if they have any feedback or info. why the boot design is so different than OEM :)
    DoorDing likes this.
  11. Nov 3, 2015 at 7:13 PM
    yzftorti
    yzftorti Active Member
    08 prerunner
    any feedback from moog? am considering their tie rods also.
  12. Nov 3, 2015 at 7:26 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    I replaced all my tie rods and balljoints with moog. The only ones that split the boots have been the upper ball joints. I was told by my auto parts guy to bring in the boots and he would replace them under warranty.
  13. Nov 4, 2015 at 11:05 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    No response from Moog (yet).
    I replaced the side with the split boot and pumped more grease into them (after install). It took A TON of grease, but both sides are full and ballooned out now. I will keep an eye on them to see how they hold up.
    Crom likes this.
  14. Jan 25, 2016 at 2:57 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    How are they holding up?
  15. Jan 25, 2016 at 6:25 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I'm curious as well since I've got 2 of these coming this week and plan to install them this weekend.
  16. Jan 25, 2016 at 6:55 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Mine haven't split *yet* but it looks like it's only a matter of time. The boot is a horrible fit. I wanted to put my worn out factory ones back on after seeing that boot squished into a ball of ass. :facepalm:
    Crom likes this.
  17. Jan 25, 2016 at 7:13 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks.
    All moog had to do was faithfully copy the OEM design and add a zerk fitting, and it would seem that they can't even do that right.
  18. Jan 25, 2016 at 7:21 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Just checked, Mevotech had some ends for us,
    Mevotech MES80895
    I'm gonna look into those...
  19. Jan 25, 2016 at 7:32 PM
    Eldo
    Eldo Well-Known Member
    Calgary
    TRDoffroad Double Cab
    a few
    I'm not sure why you wouldn't go with OEM for tie-rod end replacement? I just did an entire rack, urethane bushings, and rack ends,.. and up here in Canadaland, the price difference between OEM & Moog was negligable. Looking at the Moog TRE boot, I don't know how it wouldn't crack (cycling suspension on an already folded-over boot). :notsure:
    Bummer that the parts didn't work out. Fingers crossed for an easy solution.
  20. Jan 25, 2016 at 7:39 PM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I was looking for one that was greasable...which won't matter if the boot splits and the grease pours out.
    And I already ordered 2.
