MOOG Tie-Rod Ends vs OEM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Oct 13, 2015.
  1. Feb 3, 2016 at 6:52 PM
    #81
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Great info, thanks!
  2. Feb 3, 2016 at 8:31 PM
    #82
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Curious, those with splitting and/or leaking boots are your trucks lifted?
  3. Feb 3, 2016 at 8:44 PM
    #83
    olegoat#1
    olegoat#1 Well-Known Member
    Put the grease in after the install and weight on the wheel = see if that helps
  4. Feb 3, 2016 at 8:45 PM
    #84
    olegoat#1
    Put grease in until the boot starts to swell, not squirt out.
  5. Feb 4, 2016 at 1:28 PM
    #85
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    last time I checked I believe they have a lifetime warranty on those parts but I could be wrong. I bought mine from rockauto. I called them the second time and told them these were under warranty and that this was the second time it has happened. I had to buy two new ones shipped to me and then when I ship the old ones back they'll give me credit for those, minus the shipping of course. kinda like the how it happened the first time.
  6. Feb 4, 2016 at 1:30 PM
    #86
    esse10
    Texas
    no I have no lift on my truck , just running original factory stock level.
  7. Feb 4, 2016 at 2:02 PM
    #87
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I never checked mine before the lift, but I also didn't have a clunk before the lift, which is what led me to looking around for broken parts.
  8. Feb 4, 2016 at 2:46 PM
    #88
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Serviceable rod ends are a big plus over stock, but not if the boots split. You'll do more damage with an open boot than one without grease.
  9. Feb 12, 2016 at 11:16 AM
    #89
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Back to the inner tie rods for a moment. Once again as far as I know, in speaking with a Moog Applications Engineer, the inner is not made by them.
    If you do use the part that comes in their box for a 4x4, and If you have access to a mill, you may want to mill flats in the socket side so that you can use the locking tabs. I would aslo recomend polishing any cuts you make since a scratch can propegate into a crack and one wheel steering sucks.
    Otherwise, you will want to clean the threaded area real good (I use brake cleaner) and use red lock tight.
    If you don't understand what I am saying, please have a qualified mechanic look at it.
    Crom likes this.
  10. Feb 15, 2016 at 3:48 PM
    #90
    Connormc11
    Connormc11 Jangler
    Connor
    Norfolk VA
    2010 DCSB TRD-Offroad
    i have had my Moog tie rod ends for a long time now (more than a year). i did NOT grease them until after they are installed for that very reason and i haven't had any issues. usually add a little grease to them every 3000 miles or so when i do my drive shafts.
  11. Mar 19, 2016 at 7:53 AM
    #91
    Wolftaco
    Wolftaco Well-Known Member
    Luke
    Philadelphia, PA
    06 Overland Build
    Old Man Emu, Leer 100cc, Blacked Out Billet Grill, ARB Bumber, Warn M8000-s winch with under hood solenoid relocation, Stubbs HD Standard Sliders, diff breather
    Exactly two weeks after installing Moog tie rod boots split. Stupid mechanic did not install the greasable zirk fitting, so all the grease spewed out before I could get more grease in them. I think the taller boot is a design flaw, but like everyone else I was sucked in by the fact that they are greasable. So now I am left to rebuild the boot, has anyone rebuilt the boots on these? If so what boots did you go with? Thanks!
    Crom likes this.
  12. Mar 20, 2016 at 7:26 AM
    #92
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    IMO the MOOG products have become garbage, I personally won't buy them. I had a buddy replace all of his front suspension on a Dodge with MOOG and he ended up removing it all and doing the job all over again. It's a shame, MOOG used to be the shiznits back in the day.
    Crom likes this.
  13. Mar 20, 2016 at 7:36 AM
    #93
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    My Moog parts are still holding up, but I don't feel like their quality is the best either.
    Any good alternatives? I'd hate to have to pay OEM prices and lose the ability to grease the parts.
  14. Mar 20, 2016 at 8:43 AM
    #94
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Wolftaco, see the post above,.. Measure and see if they will fit.
  15. Mar 20, 2016 at 2:45 PM
    #95
    Wolftaco
    Luke
    Philadelphia, PA
    06 Overland Build
    Thanks. I saw those just don't want to buy a dozen. Might give them a try if I can order just 1 or 2.
  16. Mar 20, 2016 at 3:22 PM
    #96
    HBMurphy
    Paul
    So California Coast
    None
    Next time I'm at 4wd's warehouse, if they have them in stock I may check to see if they would work and then maybe split with some folks. :)
  17. Mar 21, 2016 at 10:09 AM
    #97
    Wolftaco
    Luke
    Philadelphia, PA
    06 Overland Build
    Looks like you can order the energy suspension dust boots by the pair for about $5, not bad. Just need to do some measurements.
    DaveInDenver and Crom like this.
  18. Mar 21, 2016 at 8:24 PM
    #98
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Moog tie rod ends are garbage. I had Moog tie rod enda and sway bar end links on a diff vehicle. Both failed in less than 20k miles. I know several others that have experienced the same.
  19. Mar 21, 2016 at 8:53 PM
    #99
    HBMurphy
    Paul
    So California Coast
    None
    Not all in a MOOG box is made by MOOG. I spent years in the biz and just like the MOOG inner (for 4wd), there are too many parts for one manufacturer to make them all. There is a lot of cross buying. If the part itself says MOOG, then it was made by MOOG. I have had very good luck with them and they, like all moving parts, are meant to be changed as they wear. :)
  20. Mar 21, 2016 at 9:53 PM
    #100
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    :popcorn: Got new moogs sitting on the work bench. My stock ones are still on with no grease and a pancaked boot. But have no play and seem to be fine. Prob put the moogs on before next alignment. :fingerscrossed:
