MOOG Upper Ball Joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by PcBuilder14, Feb 26, 2013.
  1. Feb 26, 2013 at 3:18 PM
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    quetzal likes this.
  2. Feb 26, 2013 at 3:35 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    In the antique chevy world MOOG is considered good USA stuff. Cant help on P/N tho. Why're you replacing them?
  3. Feb 26, 2013 at 3:40 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    sort of a thread hi jack but will be replacing lowers soon and have a few related Q's
    1 - what are moog and oem lower ball joint part numbers for 4wd
    2 - from what i've seen oem is around $85 online and i'd imagine more from dealer over phone. How do moog and oem compare? Are oem worth the extra cash? Has moog reliability dropped off recently?
    3 - do you have to get an alignment if just replacing lowers, or just uppers?
    4 - how much extra time to replace uppers, inner and outer tie rod while in there? Any write-ups? I think i know how to get lower joint and outer rod out but not sure on inner rod and upper joint
    5 - do you need to use loctite on the 4 bolts that connect lower ball joint to the spindle/steering knuckle?
  4. Feb 26, 2013 at 3:41 PM
    PcBuilder14
    Brent
    Nor Cal
    I tore up the passenger side boot when I separated the a-arm from the spindle. And the driver side is leaking very little. The driver side one would probably be fine, but I figured I'd go ahead and get both replaced at the same time.
  5. Feb 26, 2013 at 3:42 PM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    On my lil sis toyota camry we did not use loc tite on bj bolt things (cant remember if it specified in the instructions (if thre was any) year or so later still holding up fine (last I heard).
    EDIT-Pickle fork f'd up her bj boots as well (changin cv axle)
  6. Feb 26, 2013 at 3:44 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    if you can replace the outter tierod end you can replace inner. The inner just screw off. I think there is a set washer or whatever its called. Basically is bends over to keep the end from turning. Break that loose and then screw the end off.
  7. Feb 26, 2013 at 3:44 PM
    PcBuilder14
    Brent
    Nor Cal
    I wouldn't use loctite personally, just torque everything to spec when you do it. That way if you ever do have to work on something it won't be a huge pain to do...
    Same thing I did, pickle fork tore through the boot, although I wasn't changing a cv.
  8. Feb 26, 2013 at 3:59 PM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    Be shore to hit the out side of all the ball joints and tie rods with clear coat paint or it will rust and look bad.
  9. Feb 26, 2013 at 8:57 PM
    CUtacomaTIGER
    San Diego
    i was thinking not to use locktite but i've seen pics where the bolts loosened up. but not sure they loosened because they were taken out and just not re-torqued correctly.
    you can use the forks or pullers but from what i can tell just beating on the ball joints and outer rod joint to break them use is the way to go. but i've heard the uppers don't like to come out as easy for whatever reason.
    found this sweet vid on tie rods:
    http://www.youtube.com/watch?v=AVQHgcXEhpE
    and other useful docs: http://parksoffroad.com/tacomamods/upballjointout/balljoint.htm
    http://parksoffroad.com/tacomamods/allpro1inuni/allpro1inuni.htm
    http://www.bajataco.com/tech/control_arms_01.html
    apparently since the uppers are pressed in removing is more difficult, maybe not out as much but in.
  10. Feb 27, 2013 at 6:32 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Sticky that video....
  11. Feb 27, 2013 at 6:42 PM
    PcBuilder14
    Brent
    Nor Cal
    Well since nobody was able to answer my question... :rolleyes:
    I went ahead and ordered them. Should be here Friday, and if they are I'll have them installed when I get my lift installed.
  12. Mar 2, 2013 at 11:48 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I used those moog ones you had the part number in the OP, worked fine, old out and new in around 30 mins. Super simple
  13. Mar 2, 2013 at 11:56 AM
    PcBuilder14
    Brent
    Nor Cal
    Awesome, getting them installed next Saturday with my lift.
  14. Dec 7, 2015 at 7:17 AM
    Greattaytay
    Greattaytay HoosierTaco
    Taylor
    Indianapolis
    2004 DCSB Lunar Mist 4x4 TRD Limited
    What was the verdict on oem vs moog on lower bj's?
  15. Dec 7, 2015 at 10:59 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I went with oem on the lowers and then moot on the tie rods both inner and outer. No problems so far. When I first did my 4wd swap I used cheapo upper bjs and they held up fine lasted until I replaced them with moots after destroying my boots on accident
  16. Mar 14, 2016 at 1:03 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Was this the correct product number for Moog? I'm getting ready to order today. Thank you.
