Moon Roof Problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eeyore, Jun 1, 2018.
  1. Jun 1, 2018 at 1:33 AM
    Eeyore
    Eeyore [OP] Member
    Justin
    New Mexico
    2017 Double Cab Short Bed TRD-Off Road
    None yet.
    Well gang I have a little problem.
    The moon roof in my 2017 DCSB-OR is leaking. I first noticed the issue when I took my taco through a touch-less washer. The jets managed to blast water straight down into the cab, and onto the back of my neck. As the truck is still under warranty I took it to the dealership, where they determined the factory seal was deformed. The dealership ordered and replaced the seal with a new one, but it also leaked when I took it through the same car wash. I've never had a vehicle with a moon roof before so I don't know if it's normal for them to leak a little from the water jets. I am not sure if regular rain will cause the same leaking, I'm in New Mexico and rain isn't something we get on a super regular bases.
    Any insight is appreciated, and thank you!
  2. Jun 1, 2018 at 1:36 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Moonroof are not supposed to leak any liquids. Return to dealership and have them figure it out.
  3. Jun 1, 2018 at 1:39 AM
    Eeyore
    Eeyore [OP] Member
    Justin
    New Mexico
    None yet.
    That's what I was thinking, but I wanted to make sure lol.
  4. Jun 1, 2018 at 1:53 AM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    It should NEVER leak. Keep taking it back til it gets fixed. My Porsche is 22 yrs old. In Hawaii, we get a lot of rain . Never a drop of water gets past the seals.
    xxTacocaTxx and Grand dude like this.
  5. Jun 1, 2018 at 4:33 AM
    Frank32
    Frank32 Member
    Frank
    2011 Tacoma sport
    Porsche in Hawaii man must be nice! Lucky!
  6. Jun 1, 2018 at 7:17 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Actually, many times moonroofs do leak a little in a car wash situation. They are designed to handle a small amount of water bypassing the seal. There are drip rails and drains built into the system to channel that small amount of water out of the vehicle. All moonroofs I have owned have dripped a small amount at the corners (in a carwash), but that was always handled by the drip system and never a concern to me. However, what you are describing is definitely a seal failure. As the vehicle ages, maintenance of those drains is important.
    tacotech72, 2016Tacoman and peavey02 like this.
  7. Jun 27, 2018 at 11:42 PM
    Eeyore
    Eeyore [OP] Member
    Justin
    New Mexico
    None yet.
    The dealership adjusted where the moonroof sits in its rails, so it should sit better against the roof and make proper contact. Unfortunately this has not worked as today I found water again leaking in. As a matter of fact it was a lot more water than with the original seal. I don't know what to do. I called the dealership, but no one in the service department was available to schedule me another follow up. I will call again in the morning, but this is starting to worry me.
    LostHusker likes this.
  8. Jun 28, 2018 at 12:45 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    Stop taking it through that particular car wash, I would say.
  9. Jun 28, 2018 at 1:50 AM
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    I recommend upgrading to a TRD Pro. I've had no leaks at all. :anonymous:
  10. Jun 28, 2018 at 6:47 AM
    Boosted_Carrera
    Hawaii
    At this point I would write to Toyota North America.
    Log down everything from 1st time taking it dealer to last and if able to attach , send copies of service tickets. If can, take picture or video of the leak. That leak is not normal. My truck and car both have sunroofs and not a drop gets past the seals.
    There is as lemon law which may apply .
    xxTacocaTxx likes this.
  11. Jun 28, 2018 at 6:51 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the owners manual recommends against taking it through the high pressure car wash.
  12. Jun 28, 2018 at 6:56 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    does it leak when you put a garden hose on it? to simulate a more natural environment? ( like not a pressurized stream of water shooting directly on the seal, but more like a typical rain storm )
  13. Jul 7, 2018 at 1:14 AM
    Eeyore
    Eeyore [OP] Member
    Justin
    New Mexico
    None yet.
    Okay gang, a quick update.
    I have tested the seal with a more relaxed water stream. I took a glass of water and poured it over the roof. Unfortunately the results were the same. The seal still leaked a fair amount of water.
    I have exhausted the dealership with the complaint. After three separate appointments, and speaking with the service manager I have been told there is nothing more they can do for me. The dealership has replaced the seal and re-positioned the glass twice. The service manager told me that he has referred the issue to Toyota, and in the next 2 to 3 weeks a TFS (Toyota Field Service) Representative would be coming into the area to inspect it.
    Now get this! I have found two more defective seals around the driver and passenger door jambs. The seals have started to peel back away from the glue holding them in place. The dealership has ordered replacements and will replace them when they arrive. When I showed the service manager all he said was that, "the truck must have been assembled on a Friday." Granted I did laugh, but this is getting out of hand. This is the second Tacoma I've owned and unfortunately I'm rapidly losing my trust in the brand.
    I'll try to post some pics sometime over the next day or two.
    Check your seals folks!
  14. Jul 7, 2018 at 5:12 AM
    phsycle
    phsycle Well-Known Member
    CA
    That sucks. But I’m sure Toyota will get it right. Especially with water issues due to potential problems with mold. Some people with leaky 3rd brake light ended up with new trucks because of that.
  15. Jul 7, 2018 at 5:27 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    So they’ve just been screwing around with replacing small parts and then adjusting the seal? Sound to me like they should just replace the whole moonroof setup.
    I’d start looking into lemon law for your state.
    Leaking ass roof is a no-go.
  16. Jul 11, 2018 at 7:30 AM
    Eeyore
    Eeyore [OP] Member
    Justin
    New Mexico
    None yet.
    I’m back at the dealership. At least it’s for a simple service this time, the truck is due for its 10k. I’m sorry I never got pics of the door seals up, life and work got in the way. The dealership is going to replace the door seals today.
    As for the moonroof I’m still waiting for the TFS rep to make it back down to southern New Mexico to check it out. We have entered our monsoon season and the rain has really been coming through the moonroof a lot. To the point where the “drip tray” has been overflowing. The dealer rep has told me that Toyota will handle the issue from here on out, and that the dealership has been told to no longer touch the moonroof at all.
    I guess I’ll start to look into lemon law stuff, but I really have no idea how any of that works. Any advice is, as always, appreciated.
    DustStorm4x4 likes this.
  17. Jul 11, 2018 at 8:08 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    You'll never get a lemon law for a roof leak. Only applies to safety issues.
    I don't see how the channels and drain holes aren't catching it. Car wash streams hard at an angle.
    If it doesn't leak in a storm I wouldn't sweat it. If it does than its an issue.
  18. Jul 11, 2018 at 10:27 AM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    My moon roof does NOT leak on my '17 DCSB OR. This is NOT normal, contrary to previous posts.
  19. Jul 11, 2018 at 12:47 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    This sounds like Toyota acknowledges and is owning the issue which is probably as good as it gets.
    I've never had a moon roof leak. Even in 15 year old cars that are always parked outside.
    shakerhood likes this.
  20. Jul 11, 2018 at 1:04 PM
    dab86
    dab86 Member
    Dave
    2018 White Tacoma TRD Sport
    Speaking of moon roofs, can you tell the Toyota rep they seriously need to add some headroom and or make the dang seats height adjustable? A 40k dollar vehicle and no power seats or height adjustable seats is a joke. I just bought a Tacoma and im trying so hard not to sell it due to limited head room. Yes I know...I should have test drove it more and I should have bought one without the moon roof. But I wanted leather and I had no choice. By the way im 6'4".
    Good luck on the leaking issue though! So far I have not had any leaking.
    burntcremebrulee likes this.
