Moon roof rattle
Discussion in '4th Gen. Tacomas (2024+)' started by artin32, Oct 29, 2024.
  1. Oct 29, 2024 at 4:10 PM
    artin32
    artin32 [OP] New Member
    Art
    Trd off road prem
    33 inch tires, recovery hooks from ARB
    Is anyone else having a very annoying clunking noise coming out of the moonroof. If so what have you guys done for a fix
  2. Oct 29, 2024 at 8:08 PM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
  3. Oct 29, 2024 at 8:33 PM
    caribe makaira
    Caribbean, Puerto Rico
    Check the drain hose...might be loose.
  4. Oct 30, 2024 at 5:12 AM
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    Mine rattles on very rough streets, in both open modes, slid back or tilt. But silent when closed. I havent done anything about.
  5. Oct 30, 2024 at 2:45 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Due to no details listed about your truck, I assume you have a new 2024...my question is why would you even consider fixing something on a brand new truck which has a warranty?
    Stevie17 likes this.
  6. Oct 30, 2024 at 2:47 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Cause dealer probably says its "normal", lol.
    shakerhood and Stevie17 like this.
  7. Oct 30, 2024 at 2:48 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    You're probably right, but that wasn't stated.
    TacoBuffet[QUOTED] likes this.
  8. Oct 30, 2024 at 3:33 PM
    Lexpd1145
    Lexpd1145 Active Member
    Charlie
    24 TRD Sport
    I have not had an issue with noise from mine.
  9. Oct 30, 2024 at 5:21 PM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    I had a clunk/rattle coming from mine on rough roads. It wasn't the actual glass part of the moonroof, it was the sliding cover piece. To test this, I stuffed a stack of napkins between the rear of the cover and the headliner and it stopped the noise (the napkins created pressure between the headliner and the sliding cover).
    Once I knew that was where the sound was coming from I took some 2" pipe foam insulation and cut it in half. I made three of these halves and each piece was maybe 12" long. I then fully opened the sliding cover and at the back of it is a plastic piece sort of floating between the sliding cover and the top of the cab. I folded each of the 12" pieces in half and slid them so that one leg was between the sliding cover and the plastic piece and the other leg was on top of the plastic piece and against the top of the cab. I essentially created a "U" with the plastic piece in the middle. Hard to explain in words but I was then able to carefully slide the cover closed and now there's no more rattle.
    This of course only works if you don't open your moonroof... which I don't. I honestly have always avoided moonroofs but unfortunately I didn't have a choice with the premium package. If you regularly use your moonroof or want to keep the functionality then you may need to find a different solution.
  10. Oct 31, 2024 at 4:09 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    I’ve got nothing nice to say, so I’m just gonna shut up…
  11. Nov 4, 2024 at 5:57 PM
    williamBcooper
    williamBcooper Well-Known Member
    2024 Taco TRD OR
    Same. Following.
