More aggressive tires without a lift
Discussion in 'Wheels & Tires' started by Tacoma7677, Jul 10, 2020.
  1. Jul 10, 2020 at 8:10 AM
    Tacoma7677
    Tacoma7677 [OP] Active Member
    Toyota
    2019 Toyota Tacoma SR5
    New seat covers Installed step bars
    Hello all. I need some advice. I own a 2019 Toyota Tacoma sr5 and I want to get bigger and aggressive tires without any lift. I presently have 245/75R16. Any suggestions?
  2. Jul 10, 2020 at 8:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    255 85 16 is a full 33, most are E rated, heavy, expensive. But no rub no cut no lift when on the OE wheels.
    If you are offroading a good bit in harsher conditions, likely a good choice.
    If you are mall posing ('look aggressive', 'installed step bars' is a hint) then you'll need a smaller tire, like a 265
    My thoughts.
    Buy the right tire for how you use the truck 90% of the time, not what you 'might do' someday. Looks can certainly be part of that selection, but low on the list.
    Don't post the same topic in multiple forums. You're new, but mods won't care for repeat performances.
    saucedup, tcBob and Tacoma7677[OP] like this.
  3. Jul 10, 2020 at 8:24 AM
    Tacoma7677
    Toyota
    Thanks for the reply. Are 255 85 16 aggressive tires? And if so, no lift is needed, correct?
    265 is still aggressive enough and bigger than my original size tires?
  4. Jul 13, 2020 at 9:28 PM
    Grampz1962
    Grampz1962 Active Member
    Ed
    2019 BRM DCSB Sport
    Stay skinny my friend
  5. Jul 14, 2020 at 7:38 AM
    Tacoma7677
    Toyota
    Hello. What do you mean by that?
  6. Jul 14, 2020 at 2:27 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Depending on the wheel size your looking at you can also do one of these:
    16" wheel
    265/70/16 - stock size on the TRD OR/Pro
    265/75/16 - 1" taller than the size above
    17" wheel
    265/65/17 - stock size on the TRD Sport
    265/70/17 - 1" taller than the size above
    With the options above you should be fine with stock suspension. You will probably find more tire options if you go with a 17" wheel.
    burntaco215 and Thunder Fist like this.
  7. Jul 14, 2020 at 2:37 PM
    Tacoma7677
    Toyota
    Thanks a lot. I want to keep the same rims. So I can go with either 16" or 17" on my 2019 Tacoma sr5 with no lift ??
  8. Jul 14, 2020 at 2:43 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    If you have 16" rims you need to stay with tires that fit a 16" rim. The tallest you can go without a lift would be the 255/85/16. The aggressiveness of the tire is going to depend on the tread pattern of whatever brand you choose.
  9. Jul 14, 2020 at 2:46 PM
    rblalliance
    08 TRD OR DCSB 4X4
    Yes, either size will work with the stock suspension. The tire size is what will determine if you have any rubbing.
    EDIT: Either wheel size will work, but if you want to stick with your stock rims then you need a 16" tire
  10. Jul 14, 2020 at 2:46 PM
    Tacoma7677
    Toyota
    Yes I presently have 245 75 16 that came with the car. And I want to keep the same rims. Just looking for meaner and aggressive tires. What would be a tread pattern that looks aggressive?
  11. Jul 14, 2020 at 2:48 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    The one I like is the Cooper ST Maxx, which makes one that would fit your rims...
    https://simpletire.com/cooper-lt255-85r16-90000019869-tires
  12. Jul 14, 2020 at 2:57 PM
    Tacoma7677
    Toyota
    I'm sorry, so confused. It's not you guys. It's me. I really don't know what to do. I'm all new to this. I just want to keep the same rims. Put new agrressive tires. And not break the bank. So do I keep 16" with all terrain aggressive tires?
  13. Jul 14, 2020 at 3:01 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Well... if you want to keep the same rims you need to get 16" tires. You can't put 17" tires on a 16" rim. The dimensions (width and height) of the tire and tread pattern will determine how aggressive they are. The link here is a tire that will fit your rim. https://simpletire.com/cooper-lt255-85r16-90000019869-tires
  14. Jul 14, 2020 at 3:09 PM
    Tacoma7677
    Toyota
    So, 255 85 16 will fit on my presently 245 75 16 that I have on now?
    Along with 265/70/16 or 265/75/16 as other options??
  15. Jul 14, 2020 at 3:10 PM
    rblalliance
    08 TRD OR DCSB 4X4
    :thumbsup:
  16. Jul 14, 2020 at 3:12 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Yup...
  17. Jul 14, 2020 at 3:15 PM
    Tacoma7677
    Toyota
  18. Jul 14, 2020 at 3:21 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    They look pretty aggressive but I have never heard of the manufacturer. Maybe others on here know something about Crosswind...
  19. Jul 14, 2020 at 3:22 PM
    opeesha
    opeesha Well-Known Member
    C
    2018 SR5 4x4 DCSB
    M/Ts are going to be really noisy on road just as an fyi.
  20. Jul 14, 2020 at 3:24 PM
    Tacoma7677
    Toyota
    What would be non noisy?
