More engine whine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guspsi, Mar 5, 2014.
  1. Mar 5, 2014 at 8:57 PM
    guspsi
    guspsi [OP] New Member
    Psi
    Kansas City
    2008 Tacoma
    New to the site - great info, great comments!!! Now my problem - 2008 V-6, 105K and no supercharge. Like many other posts, has a whine coming from engine. Used stethoscope to check idlers, found tension pulley bad and replaced (note: cannot buy JUST pulley - also center bolt is LH thread - but swapping in pulley taken off new ass'y beats pulling alt & compressor to install whole new tensioner ass'y).
    Got rid of PART of the whine, but main noise remains - sounds like the ol' hotrods that replaced the timing chain with timing gears!!! Seems to be less noisy when warmed up, and terribly loud when cold. Again, stethoscope does not find any other bearing noise, including alt & PS pump. Also does it worse at idle, lessens when in gear.
    Saw note thread pointing harmonic balancer….how does one check that??
    Any other suggestions???
    Thanks from Kansas City!!!!
  2. Mar 5, 2014 at 9:02 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    How old is your serpentine belt?
  3. Mar 5, 2014 at 9:04 PM
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    CHeck your power steering pump and fluid?
  4. Mar 6, 2014 at 7:56 AM
    guspsi
    Psi
    Kansas City
    2008 Tacoma
    The Serp belt was replaced when I replaced the tensioner pulley. Power steering seems fine and has plenty of fluid. Does not get louder when I turn, leading me away from the PS pump.
    Also, the noise is coming from the driver-side. Putting the mechanic-scope to the alt, slight noise. But when I put it on the valve cover, toward the front where the oil-fill tube is, it's significantly louder, leading me to believe it's either the timing chain or valve noise from the front of the head…..
  5. Nov 1, 2014 at 8:15 PM
    azbugeye
    azbugeye Member
    Cave Creek, AZ
    06 prerunner SR5
    Did you ever find/fix your problem? I have the same whine on the drivers side. Not sure if mine is one of the tensioner pulley, alternator, or A/c comressor pulley.
  6. Nov 6, 2014 at 4:39 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
  7. Nov 6, 2014 at 5:24 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    How Old is the Water Pump??
