more front end pics
Discussion in '1st Gen. Tacomas (1995-2004)' started by ontarioyota, Oct 12, 2011.
  1. Oct 12, 2011 at 5:56 AM
    ontarioyota
    ontarioyota [OP] Well-Known Member
    SW Ontario, Canada
    01 reg cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs with D6XL AAL (removed), summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Very bad rad...75% fins crumbled to the touch!!
    New one tomorrow...very easy removal...also easy was the thermostat removal as I will be installing a new one with new hoses on the new rad
    When I removed the fan shroud an air hose/line was located on top of the shroud coming from the air box.
    The opposite end of this line was loose and not connected to anything???....is this normal?
    I found the loose end hiding under the throttle body...the pic shows the loose end (circled in red)...I placed it there for the photo.
    Can anyone help on info about this hose? Thanks for any input...I have studied the service manual to no avail.
  2. Oct 12, 2011 at 10:56 AM
    ontarioyota
    SW Ontario, Canada
    01 reg cab 4x4
    Bump...anyone know where this hose goes?
    Thanks!
  3. Oct 12, 2011 at 11:40 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    That hose is supposed to go the the EVAP/charcoal canister (black boxy thing on the drivers side that has two round things on top of it. At least that is where mine goes.
  4. Oct 12, 2011 at 12:11 PM
    ontarioyota
    SW Ontario, Canada
    01 reg cab 4x4
    Thanks TacoMX...I will check that out!
  5. Oct 12, 2011 at 12:54 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Good reason to rinse the radiator in the winter, when you wash your vehicle to get the salt off it that is sprayed from the vehicle in front of you!
  6. Oct 12, 2011 at 1:02 PM
    ontarioyota
    SW Ontario, Canada
    01 reg cab 4x4
    Good point...I will be doing this with the new one!
