More Interior LED woes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gnarltoof, Nov 12, 2020.
  1. Nov 13, 2020 at 7:17 PM
    18Tacos
    18Tacos Well-Known Member
    New Port Richey, Florida
    18’ Tacoma SR5 DCSB Silver Sky
    3” lift, 265/70/16 Wildpeak ATs on stock dipped SR5 wheels (for now). Meso stuff (puddle pods, Gasshole, stage 1 taillights) Pro grille, 5% tint, some other stuff
    i’m not going to say exactly how I did it but I fried my body control module in my 18’. I had it replaced and the dealer blamed it on my leds. That’s 100% not what fried it and I wasn’t going to share with them what really caused it. Either way it was an expensive lesson.
  2. Nov 14, 2020 at 5:34 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    This is true
    Tacospike[QUOTED] likes this.
  3. Nov 20, 2020 at 11:34 PM
    LiftKit
    LiftKit Well-Known Member
    Screw buying any interior lights from Amazon.
    Buy once, cry once.
    Big shout outs to MESO and all his work.
    Skydvrr, daltondrose and Tacospike like this.
  4. Nov 21, 2020 at 7:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What purpose does that serve?
  5. Nov 21, 2020 at 7:20 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well? What did fry it?
    We won't tell. ;)
  6. Nov 21, 2020 at 9:51 PM
    erok81
    erok81 Well-Known Member
    Imposter
    You are really going to post that and not say what actually happened?
    I highly doubt the dealer knows who 18tacos is.
  7. Nov 21, 2020 at 10:12 PM
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    Small little aftermarket electronics can sometimes make the truck go haywire. I installed the anytime front/rear camera mod a couple years ago, no issues initially. Then window switches stopped functioning, then radio, then Air conditioning, then headlights until each system continued to shut down with the exception of the power train luckily. All within a couple days. Removed the new wiring camera harness and switch and replaced the blown fuses and it all went back to normal thankfully. In the two years since that happened, I’ve been hesitant to install my interior led light kit I got from Caliraised. From now on, anytime I have an electronic mod I install or device I power off the truck, I power it directly to my battery and just have the switch ran to the interior of the truck. I’ve experienced similar issues with my motorcycles too.
    I’d double check all your fuses again OP, under the dash and in the hood, it may be a simple fix. Then hold off on installing a new interior light kit to you find one with a good reputation that has worked on your model year before. Good luck, hope it all works out.
    daltondrose likes this.
  8. Nov 22, 2020 at 5:42 AM
    18Tacos
    It wouldn’t matter anyway. I paid for the repair, not the dealer.
    Skydvrr likes this.
  9. Nov 22, 2020 at 5:45 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Yeah but we want to know what it was
    Skydvrr, erok81 and Jimmyh like this.
  10. Nov 22, 2020 at 6:25 AM
    18Tacos
    I had something jumped into the interior fuse box with an add a fuse. Not entirely sure what exactly happened but it came out, arched on something and everything went dark, literally and figuratively speaking.
  11. Nov 22, 2020 at 7:32 AM
    Rx7turbo2
    Rx7turbo2 Well-Known Member
    Canada
    2020 TRD OR DCSB (Current) 2005 TRD OR DCSB (Sold)
    A full power clear after you've gone back to OEM components? What purpose does it serve?
    Probably none. I've seen devices that measure and store resistive values. Can't say there's a system doing this in the Tacoma but it's a pretty easy task that's worth a shot.
  12. Dec 1, 2020 at 7:59 PM
    Velequez
    Velequez Well-Known Member
    Austin
    2020 TRD Sport DCLB - Quicksand
    OP, what came of this? Did you figure out what was going on??
  13. Jan 8, 2021 at 12:29 PM
    gnarltoof
    gnarltoof [OP] Member
    jay
    2020 tacoma off-road
    none
    Solution was a replacement of the overhead console.
    Under warranty ;)
    Lesson learned.
    Velequez and Skydvrr like this.
